Question about OKI B4350 Laser Printer
THIS PRINTER IS SHOWING MI A PAPER JAM ON THE SCREEN I ALLREADY CLEAND IN AND STILL SHOWING PAPERJAM PLEASE HELP............
    Problem Solver:
  • 5 Answers
Canon printer? You can try to reinstall the printer driver
Posted on Jul 29, 2010
  • 2,517 Answers
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage.
Now Remove the ink cartridges from the printer head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
___
Paper jam printer
kindly check it what shows in the display:
"paperjam 0" , its related to pick up roller related problem.
"paperjam 1", its related to cartridge unit, kindly re inserted the cartridge.
"paperjam 2", its related fuser unit, kindly open the rear cover of printer, ther you can see the fuser unit. check the one liver from fuser unit to HVPS .
kindly check all these things and contact
Jan 29, 2014 | Samsung SCX 4521F All-In-One Laser Printer
I've got a paperjam HP Deskjet 3050A--no instructions on how to fix. Please help! I have an impending deadline!
check paper loading area and printing area is there any paper jammed? remove any viable objects, If printer in warranty surrender to HP. check paper path sensor...
Jan 30, 2012 | HP Office Equipment & Supplies
I had a paperjam. I successfully removed the jammed paper, but now the screen still says that I have a paperjam and won't allow me to use my printer
If you haven't already try removing the power cord from the back and wait 10-15 seconds and that will allow it to reset. Let me know what happens!
Jun 10, 2011 | Office Equipment & Supplies
Paperjam in a hp photosmart c6380 all in one , how do I open to clear out paperjam ?
I could provide you with written instructions to clear paper jam, however i thought it would be good to provide you with a link to solve it for better understanding.
Click on the link below and it will give you step by step instructions to clear a paper jam with video demonstration.
Clear Paper Jam
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 03, 2011 | HP Photosmart C6380 All-In-One InkJet...
How to deal with paperjam. The printer is not printing and is showing paperjam
Hello and Welcome to FixYa!
You have to follow the steps described by the HP in there support article here.
Be careful with the jammed paper, do not force the paper more then required that may mis-align the carriage assembly.
I hope this will help you out.
If you are having any problem/questions, do ask me.
Thank you for using FixYa!
Concerned, Nooh
Aug 17, 2010 | HP Deskjet D2360 InkJet Printer
Says paper jam but NO paper is in the machine
One problem i found with those printers is that over time the casting around the paper tray is wearing off and printers starts to show paperjams when there is no paperjam.
One way to fix is try and positions the paper tray better or perhaps raising it a bit with piece of wood or paper.
Cast unfortenately is too expensive to replace so if this doesnt work and you are sure there is no paperjam and nothing obstructing the sensor then replace the printer.
Nov 02, 2009 | HP LaserJet 2200D Printer
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
Printer wont pull paper down then says paper jam
Dell does not make printers. They put their name on Lexmark printers.
I just repaired a 926 which had a paperjam alarm...and no paper jam. The paper sensor microswitch had been bent up onto a paper roller so the printer thought a piece of paper was stuck under it. It was hard to get the little lever off the roller and back, hanging free, without breaking it. This did not happen on its own so I can't fault the printer.
Look for this tiny black plastic lever hanging down right in the middle of the upper paper rollers, just behind where the carts run.
Jul 03, 2009 | Dell 926 All-In-One InkJet Printer
HP Laserjet P2015n error
If paper jam light is solid or printer shows paper out light solid all the time,
Then try these suggeted steps:
Take the Tray 2 out and check if all the paper guides are moving freely if they are than remove the toner cartridge and check if any toner sensor is not align correctly.
If they are aligned correctly than next to the pickup roller there is a small piece of plastic make sure it should be hanging freely if it is than we need to perform cold reset of the printer.
Switch off the printer press and hold down the go button and switch the printer on keep holding down go button till the time three lights lit up on control panel, as soon as three lights lits up release the go button and let the printer initialise of it s own.
If that doesn't fix than Formatter Board of the printer is faulty.
Logic:
If there is no paper jam and printer rep[orts the jam means either any of the sensors is not aligned correctly and reporting the jam or formatter Board(Motherboard) of the printer is faulty and showing incorrect display.
Thanks and Regards
Jun 30, 2009 | HP LaserJet P2015dn Printer
False Paper Jam
I have a problem with a canon printer MP460 its saying I have a paperjam but there is no paper to be seen cartridges move back and fore manually with ease please help
Nov 04, 2007 | Canon MultiPASS MP700 All-In-One InkJet...
OKI B4350 Laser Printer Logo
107 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
