Question about Westinghouse LTV-27W2 27 in. HD-Ready LCD Television
Tv doesnt come on
Everytime i turn on the tv its a blue light then a couple sec later it goes yellow. I need help plz !!
  • 11,361 Answers
You may have power supply module problem or short circuits in the inverter board, those are the two areas you need to check.
Right now the 5vdc standby is working but nothing else.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=Westinghouse+LTV-27W2+&limit=100
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Please post back what you find.
Posted on Jul 29, 2010
Why does it turn from blue to black after 10 sec.?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
Dec 15, 2015 | RCA Televison & Video
My samsung dlp turns on, then after 10-15 sec turns back off
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Mar 04, 2011 | Samsung HL-S5087W DLP TV
Tv lights blink, tv not turning on
HI, the fly back transformer has failed in your unit. this will occur if the dust level is high inside the set. the dust will settle on the cooper windings and, create an arch that will short out the entire power sector of this unit.
The fly back is usually the first to take the hit. replacing this will fix this issue.
Jul 11, 2009 | Televison & Video
My RCA D52W20 turn on with a blue screen and then turns off within 3 sec's. It goes off like someone has switched off the TV. The light blinks and goes off. Can anyone help
Your blue tube has a short. What you are seeing is the TV turning on and the blue tube going to full brightness. It then draws enough current that the television's protect circuits shut it down.
Need the full model number which should include a BYX or just YX followed by a number. Going off the D52W20BYX1 the blue tube would be part number 263049 which https://www.encompassparts.com still has a few for $220 before shipping.
Jun 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Television
what is wrong? its damaged internally on one of the pcb boards most likely the power board, you will need to take it in to a service center to know what is exactly wrong
May 10, 2008 | Sony 21" Trinitron P202 Flat Screen...
Blue doesn't seem to line up
Blue convergence IC is bad....change both,,,original number
Stk392-110 replace with upgrade Stk394-160E Hitachi part
# CZ 01341 ....also check B+ feed resistors for over-heating
................................T.
Jan 27, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Powering on
needs a new flyback
Jan 01, 2008 | RCA HD52W58 52" TV
Zenith lcd with a yellow dot
CALL LG I HAVE THE SAME PROBLEM WITH MY TV AND THEY EXTENDED MY WARRANTY FOR A NEW LIGHT ENGINE I HAVE HAD MY TV SINCE 2004 AND THEY PUTIING A NEW LIGHT ENGINE FOR FREE IN 2009
Dec 13, 2007 | Zenith E44W46LCD 44" Rear Projection...
Ps3's green light turns on usually screen stay's black
Call Sony so they can fix it. This sounds like multiple problems. Good luck.
Nov 17, 2007 | Sony PlayStation® 3 (60 GB) Console
Westinghouse LTV-27W2 27 in. HD-Ready LCD Television Logo
121 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
