Question about Exercise & Fitness
I need to replace the damaged treadmill belt measuring 42cm (17'') x 298cm (117'') in circumference.
    Problem Solver:
  • 6 Answers
We are dioing the servicing for all kinds of treadmills and We can change the belt for you also...
My conatct No is 9986202487
Dini
Posted on Jul 29, 2010
What is the correct part number?
Have you measured the old belt?
Aug 05, 2014 | Hoover Vacuums
Ministry sound manual
I can find out for you but i need you to measure the old belt if possible and turn the platter upside down (thats the part your records ride on and measure the circumference around where the belt goes (easist way is to take a peice of string put it around where the belt goes and then take a measuring tape make the string straight and measure how long it is repost the length and i will see what i can do to help you
Sep 18, 2013 | Audio Players & Recorders
Need drive belt for a AKAI GXC-709D tape recorder, .015 thick x .150 widex4" D. full circle
Take these measurement and either look on the MCM Electronics web site or Mat Electronics web site. The Diameter does not help much the measurement they use is Inner circumference or IC. The IC is near double the length id the belt is pinch and measured on a scale. Also allow for the belt being stretched so you may need a belt 5-10% less than the old one.
If you can not figure this out then just contact Marrs Communications and tell him the model and he will have the belt kit but this is more expensive.
Feb 06, 2013 | Audio Players & Recorders
C2200 treadmill motor problem
1)measure the voltage input motor, if there are The motor need repair or replace.
2) mEASURE the output voltage board, for input voltage motor, if there are NOT the board is faulty, see the block diagram.
3) Test th drive belt for loose or break and replace.
Jun 28, 2012 | Nordic Track Nordictrack C2200 Treadmill...
Treadmill proform model 831.29605.0 (proform xp 550e was working fine till I Changed the walk belt. After changing belt, display looked ok but treadmiil would non trurn on. Operated incline. incline
1) i recommend that you lube very well deck belt + rollers bearing
2) see the videos.
3) see the block
4) Try to RUN the software calibration, for troubleshooting.
5) measure the input voltage motor, if there are the motor need repair.
6) Measure the output voltage board, for input voltage board, if there are NOT, the board is faulty.
Jun 27, 2012 | Proform Treadmill Motor Controller 241697
I need a replacement walking belt for my NB 1500 treadmill. How do I get this part?
You can order one from treadmilldoctor.com or from Amazon. Just measure your deck length, thickness, and width then search for a matching belt size.
Oct 22, 2011 | New Balance Balance 1500 Treadmill
I have a Troy-Built Rototiller, 7 HP OHV, PONY. The drive belt for the tines is broken and I don't know what size belt to replace it with.
Belt sizes denote the circumference of the belt. Since your belt is already broken the easiest thing for you to do is measure the length of the belt using a tape measure. Get a belt that matches your measurement to the closest inch rounding down to allow for stretching of the old belt.
May 31, 2011 | Garden
Disk drawer will not open
A small motor turns a belt, which then drives the gear that operates the drawer. Over time this belt stretches or breaks, and the drawer doesn't open. Replacing the belt cures the problem.
I've looked at the couple of belt catalogs I have, and nothing for NAD is listed. You'll need to measure the old belt circumference and thickness. Almost all of these are square belts, usually in the range of 2.5 to 3.5 inches circumference. If you're measuring the old belt, take off 10 to 15% since it has stretched.
A local electronic service shop may have a suitable replacement. Otherwise there are many sources online (MCM Electronics is one I deal with frequently here in the US). In a pinch, you can even use a small rubber band until you find the right replacement.
Hope this has helped. Thanks for using Fixya!
Feb 12, 2010 | NAD C542 CD Player
Treadmill noise
If it is a chirping noise it will be the mylar sheet under your walking belt. You will need it replaced after that kind of damage. If it is an actual grinding noise it will be something else.
Apr 14, 2009 | Exercise & Fitness
Regal 6725 belt
I too am looking for a belt. I have measured the circumference and it is 24 in. My belt also disinigrated so I don't know about the width. I think it would be about 1/4 in. Where are you finding these at? Please email me @ EM_920@msn.com
Nov 14, 2008 | Regal Ware K6725 Kitchen Pro Bread Maker
Exercise & Fitness Logo
65 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
