Question about Apple iPhone Smartphone
Ive had the same issues with "unable to join network on my iphone 3g" and i followed #8's solution and to my suprised it worked ive been without wifi since monday nite and am so relieved now
    Problem Solver:
  • 40 Answers
IPhone 4s is unable to scan/connect/join wifi network. Please help?
Hey there could you be more specific, are you saying thst it won't connect to any wifi network or just already saved ones?
Dec 19, 2013 | Cell Phones
Tip
How to connect an iPhone to the Internet
Connecting your iPhone to the internet is an easy process. You just simply use any application on your iPhone which uses internet service.
Your iPhone can either use WiFi or Cellular for internet access.
- A WiFi network is simply a wireless network. You can find them at coffee shops, libraries or even at your house if you a router setup for wireless access.
- Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
When you use an application on your iPhone that requires internet service it will either connect to the last WiFi network used, or if that network is not available it will list all available networks in range. You can simply tap on the network you wish to join and it will connect. If the network requires a password it will show a lock icon. If no Wifi networks are available your iPhone will connect over the cellular data network and fees may apply.
To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
I hope this article was informative. You can check out more of my tech articles by clicking here then going to the Tips section.
Regards,
G33k
keywords
how to connect iPhone to the internet, connect to internet, iPhone internet, connect iPhone internet, how to use internet on iPhone, iPhone internet application, iPhone wifi, iPhone wireless internet connection, iPhone no internet, internet not working iPhone, iPhone 3g,
on Jul 09, 2011 | Apple iPhone Smartphone
The phone used to connect to the internet with wifi and 3G. Now it only works with 3G. It sees the wifi network, but says that it cannot connect to this network. It does this on every network I have tried...
If your looking to use only wifi at times. You need to go into the setting and shut off the 3g data and have only the wifi option active.
Cellular data over rules wifi at all times. That's their little trick at getting you to use up all your data plan.
Here's the steps:
1. Go to Settings
2. Scroll to Network
3. Cellular Data - slid to OFF
4. Tap General on the top left
5. Tap Settings on the top left
6. Scroll up to Wifi and tap
7. Make sure Wifi is on and finding networks.
(Note: Only networks without the lock are public networks unless you know the pass code to log on)
8. Make sure Ask To Join Networks is to OFF
9. Click the arrow blue arrow on the network you connect too and make sure HTTP Proxy is set to OFF
10. You should Connect just fine
To reverse this and go back to Cellular data. Follow instructions 1 - 5 except you wanna turn Cellular Data back On.
Jul 28, 2011 | Apple iPhone 3G
Not got wifi on my i phone
1. Settings
2. Wifi
3. Wi-Fi to ON
4. Let search for networks, select network without lock emblem
5. Network have check mark? Your connected
6. Below that "Ask to join networks". Slide to OFF
Wifi should work. On the top of the screen by the clock and service name you should see 3 crescents. That's your signal icon.
Hope that helps
Jul 15, 2011 | Apple iPhone 3G
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Jun 03, 2011 | Lands Phones
How do ii conect to my wifi?with a iphone 3g?
Go into the settings program (the icon with the gears). The second menu option should be WiFi. Tap it and turn on the WiFi by tapping the rectangular button on the top right. Your network should show up in the list, just tap to join.
Mar 01, 2011 | Cell Phones
Trying to connect my iPhone 4 to my WGT624 v3 router. My iPhone is detecting the network, but i'm getting the message "unable to join the network" .
Hi chaps,
I did two things to resolve this issue
1. Downgrade the router to a lower version.If your router is Netgear WGT624 v3 use this link to downgrade your router
http://www.davejackson.com/life/cant-access-wifi-with-ios-6-on-iphone-with-netge ar-wgt624v3-fix/
(this help to avoid getting a errro message "Unable to join network")
2. Reconfigure you Wifi network by going to setting ---->under choose a network---> others-----> Enter your SSID name (seen at the back of your router) ----->under the security tab selet the same encyrption standard as that of your router which you can see when you log in to the router (usually router IP 192.168.1.1) ---->setup ------>wireless setting----> security option. This one helps you to join your home wifi as soon as you enter your home.
Dec 29, 2010 | NetGear WGT624 Wireless Router
I cant seem to connect wifi onto my iphone
try forgetting the wifi connection and then try connecting to it again
Nov 11, 2009 | Apple iPhone 3G
Internet on iphone 3g??
Simply go to Settings > Wifi. If Wifi is off, turn it on. You'll see a list of available networks when you're in a hotspot. You can also have iphone tell you when you're near hotspots by turning on "Ask to Join Networks." You won't be able to use the internet when you're not in a wifi hotspot.
Oct 28, 2008 | Apple iPhone 3G
Iphone wifi
You need to select the 'Settings' button on the home screen, then make sure that the 'Ask to Join Networks' option is turned on. Choose your network, and then enter in your password. I've had the same problem before, and it turned out that my phone wouldn't connect without setting the computer to require a password. If this doesn't solve your problem, please let us know.
Feb 20, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
102 people viewed this question
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
