Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Ice maker not working
Ice makeer quit woking, it doesn't seem like any water is going to it , but I can''t hear it woking, I changed the water filter with a matag brand filter, it looked the same and I replaced it once already with the same brand filter but its not woking now
    President:
  • 1,218 Answers
Good day,
You'll need to follow the steps below to isolate the problem. It's important that the freezer is at normal temperature since if it goes above 10 degrees the ice maker will lock out.
I will have to assume the filter is passing the water flow properly.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Posted on Jul 29, 2010
Why is ice maker making small cubes?
Low water pressure can make small cubes.
Feb 14, 2016 | Refrigerators
Not enought water to ice maker
Can you provide a make & model # for the unit?
Feb 08, 2014 | Refrigerators
I changed the water filter, now the ice maker won't work.
Probably water Inlet Valve is bad and needs replacing.
Nov 27, 2017 | LG Refrigerators
Ice Maker Doesn't Work
Is there ice in the ice tray? If so the heater is not working to allow the scooper to push the ice out into the tray. If no ice in tray then the fill solenoid is not opening to allow water into the tray. Replace the solenoid.
Sep 19, 2017 | Refrigerators
I have a whirlpool side by side model ED5PHAXSB00. The ice maker has quit working. You can hear it running but no making ice. I changed filter hoping the would solve proble but has not. Any advice?
This means the fill tube is frozen or the water valve on the rear is bad. Check the little hose that brings water into the ice maker. Often the hose will freeze. if the hose is clear, replace the valve on the rear.
Apr 22, 2011 | Refrigerators
GE Profile TFT25 PR. Ice maker quit producing
Had the same problem. Replace the water filter and is should begin making ice again.
Mar 05, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
mnnmbnm
Jan 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice machine quit making ice
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 12, 2008 | GALAXY Microsystems 25.4 cu. ft....
what filter? drying filter? Water filter? Dust Filter?
Jun 24, 2008 | Frigidaire FRS26R4A Side by Side...
Kltchen aide icemaker
check controls make sure no one has changed settiings should be around middle setting
Is your freezer keeping the right temps?? If freezer temp has changed it will affect ice production, stick themomator and check freezer temp
Look at ice maker make sure theres no blockage of pieces of ice slowing ice maker
Oct 23, 2007 | KitchenAid KSRS25IL Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
525 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
