Question about Brother DCP 115C All-In-One InkJet Printer
Always Cleaning... Hello newbie here... Just wondering if there's a tool or software that can disable the auto cleaning of Brother DCP115c. Because every time I open my DCP115c its always cleaning and eventually ink is empty. Thanks...
  • preethigaura Jan 11, 2009
    I have the same problem. The printer is Brother 135C. I don't think I can leave the printer powered ON all the time - as we have power cuts, after which the cleaning will auto-start.
    Is there any other way?
    This is a serious problem as I have taken only 10-15 prints and the ink is half empty. This way I need one cattridge for 30 prints.
    Please help !
  • 832 Answers
No. no tool.
set date and time. leave machine ALWAYS power plugged in.
machine automatically do some cleaning to keep air bubbles away and the nozzles working. this consumes very little amount of ink.
Posted on Apr 24, 2008
2 Suggested Answers
JULIANFIX
  • 975 Answers
SOURCE: DCP 115c How to disable auto cleaning?
did you already install your printer to the PC ?? have the installation disc ?? if yes , go to MY COMPUTER , DO A RIGHT CLICK at the icon of the printer and click PROPERTIES ,THERE you should be able to disable the command .
What's your question?brother dcp115c,machine error51?
Brother DCP115C Code: 50, 51
Description
The purge cam switch does not come ON or OFF even after the purge cam has been driven by the specified number of pulses.
Switching arm assembly not engaged correctly Ink cartridge/purge switch harness not connected correctly Purge cam switch broken Gear(s) on the maintenance unit broken Paper feed motor broken Main PCB defective.
Sep 09, 2016 | Brother DCP 115C All-In-One InkJet Printer
Tip
Tips to clean and speed up your computer.
If you wish to speed up your computer or just give it a good cleaning, you have come to the right place! Follow the tips below and your computer should perform better.
CCleaner is a program I have used for years, and it is an amazing tool. It offers the ability for you to clean out old temporary files, browser cookies, remove unwanted programs, fix registry errors, disable start up programs and even manage system restore points.
Click here to download the program
-Install and open up CCleaner. On the left, you will notice 4 options. The first(top option) is cleaner. We will make sure we are on this tab and click the "analyze" button near the bottom middle. Let the program analyze and once it is done click the "run cleaner option"
*Editing registry information can potentially be dangerous and I always advise to backup the registry before deleting anything from it*
When you install and remove programs, you can leave behind junk that over time can cause problems for your computer. We will clean up the registry now.
-Next, we will run the Registry analysis to see if anything can be fixed. Click on the registry tab on the left of CCleaner and then click the "Scan for issues" button. Once this is done, go ahead and click the "Fix selected Issues" button.
Over time, your computer can accumulate many programs that will start up when windows reboots causing the reboot process to be extremely slow. Some of these programs are non essential and can be disabled from start up. The next step we will disable any unwanted start up programs.
*Disabling essential programs from start up may cause computer issues. Only disable programs that are not needed to be running when the computer starts up. Some examples are Itunes, Windows Media Player, Adobe update*
-Click on the "tools" option on the left of CCleaner. Then click on the startup tab. Expand the CCleaner window to maximize so you get a good view. You do this by clicking the box icon at the top right of CCleaner. In the middle window, CCleaner will list all programs that will start when your computer is turned on. You can go through each program and disable any that you see fit. I gave some examples above of programs you can disable. This can increase your start up time!
Now we can close CCleaner.
-In this step we will run the built in Windows disk cleaner and disk defragmenter to finish our clean up job. In windows 7 you can access these tools by going to Start and in the search box type Disk. The two top options should be Disk Cleaner and Disk Defrag.
Click on Disk cleanup and a program will run, and calculate files to be deleted and how much space you can save. CCleaner will have already cleaned up much of this junk but go ahead and select the options you wish to remove and click the OK button.
Next, run the Disk defrag tool. This tool will show you if your disk is badly fragmented and if so, run the program. It is best to do this overnight while you are sleeping as it can take up computer resources.
Other Tips
A new tool I have started to use is TuneUp Utilities. The 2011 version is very good and is easy to use. You can download it by clicking here. You can use it to basically do anything from disabling start up programs, defragging your hard drive, changing Windows settings and even changing your Windows Login screen. It will guide you through optimizing your computer.
Okay, your computer should be all clean and run a bit faster now. I hope you enjoyed this Tip!
Regards,
G33k
Keywords
Computer speed up, cleaning computer, clean computer, speed up computer, optimize computer, free computer software tools, free computer cleaning tools, free cleaning tools, free computer software, how to clean computer, how to speed up windows, how to clean laptop
on May 06, 2011 | Computers & Internet
I require software for Brother DCP115C to load onto another computer. How can I obtain same.
You can obtain the printer software from this link, just click HERE and proceed with the download.
Nov 02, 2010 | Brother DCP 115C All-In-One InkJet Printer
My printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
Nov 03, 2009 | Brother DCP 115C All-In-One InkJet Printer
I'm using a Brother MFC-5440CN printer-Scanner-Fax. Whenever I clean my registry using various cleaning tools (JV16, Advanced System Care 3, etc.)' the cleaning application deletes one of my printer's...
What you can do is check the registery before you do the cleaning, and compare with afterwards. The registery keys associated with ControlCenter is found in HKEY_LOCAL_MACHINE\Software\Brother\ControlCenter and in HKEY_CURRENT_USER\Software\Brother\ControlCenter
Try taking a screenshot of the keys extracted, or export them, to easier see what's being removed.
Jun 03, 2009 | Office Equipment & Supplies
Apr 24, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother dcp115c. alignment must be out its printing double
No you don't have to take it to be serviced. There is a work around for this. It is not an ideal work around but given the low cost of these printers they probably aren't worth spending the money on at a service center.
OK the Fix is, you simply turn OFF BiDirectional printing in the printer driver settings.
The printer will then print correctly.
Also I'm sure if you could obtain the service software for alignment it's probably not beyond the abilities of a back yarder. :)
Hope this helps.
SiliconJaguar
Apr 18, 2008 | Brother DCP 115C All-In-One InkJet Printer
Finding drivers to download for my dcp-350
http://welcome.solutions.brother.com/bsc/public/SearchResult.aspx?reg=us&TXT=dcp-350c&FLG=0&c=us&lang=en
and have a look around there (faq)
Apr 05, 2008 | Brother DCP-350C InkJet Printer
Brother dcp115c
cause the waist ink absorber box is fed up with ink. you have to replace the box and to reset the eeprom. search error 46 or unable to clean here. its written very often how to do that (same procedure for all brother inkjets)
Mar 17, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
291 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
