Question about Vizio VO47L 47 in. LCD TV
I am not getting a signal on my tv when I connect to the receiver using an HDMI cable. What do I do?
    Problem Solver:
  • 11 Answers
First eliminate sources. For example, test another source like a dvd player / xbox,playstation gaming system, etc. If your tv recognizes these sources then it is a problem with your reciever and not the tv. If the tv does not recognize the other devices you tested then the hdmi port on your tv is bad.
Posted on Jul 29, 2010
Why did I lose the video signal from the receiver to the TV?
I assume you have tried both hdmi cables from box to tv. If both works good.Cconnect to amp. Connect cable box also on other hdmi inputs like bd, dvd, etc to make sure the spesific port is not faulty. If still no picture try to lower hdmi video display on cable box. You amp may not be able to display the higher resolution.
May 06, 2015 | Onkyo TX-NR535 Receiver 5.2 Channels, 65...
How do I connect my receiver so that the sound comes from my speakers????
Please read the manual. You should connect speakers to the speaker output of the receiver, or amplifier. You connect the TV with a receiver through a HDMI cable. Depending what would be the source from that you take the output and the place the signal is going to there you should use the input. Don't connect anything without 100% certainty it is correct. You could damage the whole equipment when connected the wrong way around.
Dec 28, 2014 | Samsung 50" Uhd 4K Smart Hdtv
No HDMI video using RX-V575 Yamaha Receiver with Panasonic TV C-P60ST30
Michael, I still think it is a connection problem. Try disconnecting the HDMI and see if you get the video. If no, it is a connection problem. Check the connections carefully.
Mar 24, 2014 | Yamaha RX-V575
Hdmi will not work only use of component cables will.
Hello
The HDMI[1] input on your TV receives digital audio
and uncompressed digital video and audio from an
HDMI device or uncompressed digital video from a
DVI[2] device.
This input is designed to accept HDCP[3] program
material in digital form from EIA/CEA-861/861B-
compliant[4] consumer electronic devices (such as a settop
box or DVD player with HDMI or DVI output).
The HDMI input is designed for best performance
with 1080i high-definition video signals, but will also
accept and display 480i, 480p, and 720p signals.
To connect an HDMI device, you will need:
• one HDMI cable (type A connector)
For proper operation, it is recommended that you use
a short HDMI cable. You should not encounter
difficulty if you use an HDMI cable shorter than 16.4
ft (5m).
HDMI cable transfers both video and audio.
Separate analog audio cables are not required (see
illustration below). Some CDVs (video CDs) may
not output digital audio signals. In that case, you
may hear sound by connecting analog audio cables.
However, if you connect analog audio cables with
this connection, the HDMI terminal on the TV will
not receive the HDMI digital audio signal and you
will hear analog audio only.
To ensure that the HDMI or DVI device is reset
properly, it is recommended that you follow
these procedures:
• When turning on your electronic components,
turn on the TV first, and then the HDMI or
DVI device.
• When turning off your electronic components,
turn off the HDMI or DVI device first, and
then the TV.
To connect a DVI device, you will need:
• one HDMI-to-DVI adapter cable
(HDMI type A connector)
For proper operation, the length of an HDMI-to-
DVI adapter cable should not exceed 9.8 ft (3m).
The recommended length is 6.6 ft (2m).
• one pair of standard analog audio cables
OK
Dec 16, 2010 | Toshiba 30HF84 30" TV
My wii won't play video through my Yamaha RX-V465. The audio comes through OK. I have a normal signal video component cable and i have connected the receiver to the TV with a HDMI cable. i have tried...
This receiver doesn't support processing of video signal, only switching. This means that it can output only the same format of video. Only some more expensive models do upscaling from component/composite to HDMI out.
From HDMI out, you can output only signal that came via HDMI in 1-3. For component out, you can output only component in. The same for composite.
So in order to use wii through receiver to TV, you must connect receiver and TV also via the component cables.
Or other option is to connect component from wii directly to TV and connect only audio to receiver.
May 09, 2010 | Yamaha HTR-5840 Receiver
How do I convert from HDMI-in to Component-Out? Basically, I'd like to have my cable box (Comcast DVR) coming into the receiver using HDMI but would like to output to my TV using Component instead of HDMI....
looking at the manual here that should work for Video http://www.onkyousa.com/download/own_manuals.cfm?cat=Receiver
it looks like on the receiver you would have the DVR connected via HDMI cable to the receiver On the receiver you would select this HDMI as the input. That should automatically allow that signal to be presented to the component out on the receiver you connect the cables from component out to the TV and switch the TV to select the component input -depending on the TV model this may be labeled AV1,2,3,4, etc No sound will be transferred to the TV as component is Image ONLY whats the make and model of the TV
Mar 20, 2010 | Onkyo TX-SR606 Receiver
Getting picture lines across tv that keep scrolling down like old tv's used to do. HDMI connected to cable box. Cable box to tv works fine and dvd to receiver hdmi to tv works fine no picture problems. can...
You will need to run HDMI directly from TV to Cable Box. Then run an optical or digital coaxial from your cable box to your receiver. The version of HDMI in your receiver is 1.1 or 1.2 and will not pass signal correctly. The recording industry has placed many roadblocks in front of HDMI to keep us from recording.... Go figure... That's the fix though. Hope this helps
Dec 19, 2009 | Harman Multimedia AVR-254
I have the following hardware: Marantz SR-4003 Receiver, Samsung LN52A650 HD TV, Samsung BDP-1500 Blu-Ray player, Scientific Atlanta Explorer 8300HD cable box, two Paradigm Millenia 20 LCR Bookshelf...
Remove the HDMI cable (out) to the speakers from the receiver.
Connect regular speaker wire from the receiver to the speakers.
Of course, remove the (now extra) HDMI cable from the tv.
That will remove the loop.
Jan 25, 2009 | Marantz SR-5600 Receiver
Cannot get a connection with HDMI input
When the tv won't scroll to the HDMI inputs, it means that the tv does not detect a signal on those inputs. This either means the tv has an issue and can't receive an HDMI signal(very unlikely) or there is no signal being sent from the source(converter box) The first thing I would do is unplug all output connections from the box except for the HDMI output and see if this gets rid of your problem. If not, I would be more inclined to think you have a problem with your converter box than with your TV. You could also try using the HDMI ouput of a DVD player if you have one.
Jan 14, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Unable to get HDMI signal into TV
In the setup guide, try going to the HDMI option where you turn the montior out to "on" for the HDMI output. I don't believe that the receiver comes with the HDMI out already turned on...
Dec 31, 2007 | Onkyo TX-SR605 Receiver
Vizio VO47L 47 in. LCD TV Logo
527 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
