Question about EliteGroup NFORCE4-A939 (NFORCE4A93910) Motherboard
Window 7 networking problem.....
I have installed window 7 after istallatio i m facing the same problem like my computer network and internet icon is set off so i may fix it by going to device manager-network adapter-properties-advance-speed and duplex by changing the changing the speed and duplex setting i may fix it but every time when start the computer i may face this problem plz tell me how can i fix it...........
5 Suggested Answers
SOURCE: ECS GeForce6100SM-M Onboard Network Adapter does not show up in windows???
I had the same problem. Tyr this.. Install windows x64 1st install the ide driver (it's a setup program) reboot 2nd go to device manager, you will see a PCI bridge device, update that driver to the lan driver on the cd. reboot Then install the rest of the drivers. If you don't do it in that order you will NEVER be able to install the Lan driver without reinstalling windows.
Posted on Sep 10, 2007
colliewob
  • 781 Answers
SOURCE: network adpter malfunction
try this
Uninstall any drivers for card shut down remove card restart then shut down reinsert card reboot on reboot it should come up with message new ??? found and go into finding drivers follow instructions to install them from where the driver folder is
when installed reboot normally this will fix problem
Posted on Jul 27, 2008
Geekman
  • 32281 Answers
SOURCE: "my windows cannot detect the harddrive of my computer"
Windows XP does not have a SATA controller driver on the CD, (you need the SATA driver from the motherboard manufacturer), therefore you need to provide the SATA driver on a floppy or CD during the Windows install process (press F6 to install disk controller driver).
The other method that may be available - go into the BIOS configuration and set the hard drive to IDE driver or SATA native driver and install Windows normally.
Posted on Sep 14, 2009
  • 13 Answers
SOURCE: its a geforce6100sm-m reformatted and now its
The computer has an ethernet adapter builtin, in the control panel disable the ethernet connection Device=NVIDIA nForce 10/100 Mbps Ethernet and then make sure the drivers for the usb cable modem are installed.
Posted on Sep 21, 2009
Which service has to be active in order to access my network?
In order to access your network, you need to make sure that your router or modem is turned on and Internet is working. Additionally, you must ensure that network adapter on your computer is enabled.
To know how to connect to Internet, refer to the instructions mentioned on the links below:
http://windows.microsoft.com/en-in/windows/connect-internet#1TC=windows-7
http://www.wikihow.com/Connect-to-the-Internet-Wirelessly-in-Windows-7
In case you are facing issues connecting to Internet, refer to the link below for troubleshooting options:
http://windows.microsoft.com/en-in/windows/cant-connect-internet#1TC=windows-7
GuruAid.com
Jan 07, 2016 | Microsoft Windows 7 Professional Service...
Tip
How to connect your wireless computer to the wireless network ?
Connecting your wireless computer to the wireless network:
Make sure the wireless switch is turned on in the laptop, now look for the available wireless Networks in range, select your network name, enter the security key and get connected. You may also follow the navigation below according to your Operating System
WINDOWS XP: Start > Control Panel > Network and Internet Connections(Network connections) > Right Click Wireless Network Connection icon > Click on View Available Wireless Network
WINDOWS VISTA: Start > Control Panel > Network and Internet (Network and Sharing Center) > On your left hand side click on Manage Network connections > Right Click on Wireless Network Connection icon > Click on Connect/disconnect
WINDOWS 7: Start > Control Panel > Network and Internet (Network and Sharing Center) > On your left hand side Click on Change Adapter Settings > Right Click on Wireless Network Connection icon > Click on Connect/disconnect
MAC OSX: Select airport icon from desktop, turn on Airport, you will be able to view the available networks in range. Select your network name enter key and get connected.
You may also click on Apple logo > System preferences > Airport > select network name
You will be able to see the Network name (SSID) which you gave in the Router, try to connect to this it will ask for password type it and click on Connect. You will get connected wirelessly and able to go online.
on May 19, 2010 | Computers & Internet
Tip
Belkin F5D7234-4 v1 (important thing)
In Belkin f5d7234-4 v1(only version 1) router, do not disable "WiFi protected setup" learn more about wps
  • If you do so, then the router will no longer work in 90% of cases.
  • The WiFi protected setup is enabled by default in this model.
  • The computers using XP,vista,win7 may not connect to the wireless network. 96cff88.jpg
Solution:
In that case you can add the wireless network manually in the computer.Still if it says error message as "windows cannot connect",then follow these steps according to your operating system.
WINDOWS XP:
Start>
Control Panel>Network and Internet Connections(Network connections)>Right Click Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS VISTA:
Start>
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side click on Manage Network connections>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
WINDOWS 7:
Start >
Control Panel>Network and Internet (Network and Sharing Center)>On your left hand side Click on Change Adapter Settings>Right Click on Wireless Network Connection icon>Click on Properties>authentication tab>uncheck IEEE authentication
  • Now try to access wireless network.
  • If it still says windows cannot connect then no other go.
  • You need to disable WiFi protected setup.This will fix the issue for sure...
Click here to know how to disable wifi protected setup...
To learn more about WiFi protected setup, please click here...
on Apr 19, 2010 | Computers & Internet
How to install epson l210 printer on windows 7 correctly?
go to add printer wizard,select windows update option,this take few minutes according to your internet connection,after it select your printer model and and after installing check if there is another printer installed in your devices folder,uninstall all unnecessary printers.
Apr 24, 2015 | Epson L210 - multifunction printer /...
How to go to wifi
Wi-Fi technology enables wireless Internet and network access through public and private hot spots. These hot spots are widely located in homes, restaurants, bookstores, coffee shops and other businesses, so you can keep connected wherever you may travel. To connect to Wi-Fi, you must have an enabled wireless adapter on your computer. Most modern laptops and many desktops have this adapter built into the system, but many lack such capabilities. However, a wireless adapter is easily installed via USB, which allows you to connect to available networks through Windows 7.
Enable your wireless adapter. Most laptops have a hot key labeled with a radio antenna. Hold the "Fn" key and press this key to toggle wireless on or off. Desktops likely have a physical antenna on the back of your computer that is typically always on. If you don't see such a hot key or antenna, you need to acquire a USB wireless adapter. Attach the USB wireless adapter to an available USB port on your computer. Windows 7 will automatically install the necessary drivers for most adapters. If it does not, insert the CD that came with the USB wireless adapter into your drive and choose to install their drivers. Restart your computer if you do not see a wireless icon in your Windows 7 notification area. Click the wireless icon in the Windows 7 notification area and click the network name to which you want to connect. If this is your home network, the correct network will likely be the one with the strongest signal. Click "Connect" and enter the wireless security passphrase, if required. Only secured networks will ask for a passphrase, but some public networks will require browser authentication instead. Open your browser and navigate to any website. If the hot spot requires browser authentication, your website request is redirected to an information page. Follow the instructions on this page to get Wi-Fi. This may entail clicking "Accept," entering a given password or entering a cell phone number. After authentication, attempt your website again to verify accessibility. Hope this helps
b>
Dec 22, 2012 | Computers & Internet
On my WIndows 7 computer it shows that my wireless is connected, but it also says, "Unidentified Network, no internet access" and I can't get on
Click on the network icon (five vertical bars, next to the speaker icon, bottom right of screen). When network window opens, click on name of network. If a blank box opens with a message asking for the network key, enter the security code that you entered after the WEP setting on initial installation.
If this doesn't work then I suggest that you re set the modem to factory default and go through the initial set up again, choosing a new name for the network.
Nov 22, 2012 | Computers & Internet
Cant get on the internet and network icon disappear
Sounds to me like a cable issue. Try swapping out your cables.
May 23, 2012 | Dell Ethernet Card Network Adapter
My notebook cannot connect to the wireless router. its on my wifi but i cannot connect to the internet. it says dns server error
Hi Dear Being able to connect to a wireless network or wi-fi hotspot is fundamental for mobile work and play. The step by step directions in the wi-fi tutorial below will help you set up your laptop so you can connect to a network wirelessly for Internet access or to share files with other computers on the network. Examples are given for Windows XP, Vista/7, and Mac.
  1. Find the wireless network icon on your computer (on Windows, you'll find an icon that looks like 2 computers in your taskbar on the bottom right; Macs will have a wireless symbol in the top right).
  2. View available wi-fi networks by either right-clicking the icon and selecting "View Available Wireless Networks" (Windows XP) or left-clicking the icon and selecting to "Connect or disconnect..." (Windows Vista). On Mac OS X and Windows 7, all you have to do is click on the wi-fi icon to see the list of available networks.
  3. Choose the network to connect to by clicking the "Connect" button (or just selecting it on Win7/Mac).
  4. Enter the security key -- if the wireless network is encrypted (with WEP, WPA or WPA2), you'll be prompted to enter the network password or passphrase. This will be stored for you for next time, so you'll only have to enter it once.
  5. On Windows 7, select the type of network this is -- Windows 7 automatically sets up security for different network location types (Home, Work, or Public).
  6. Start browsing or sharing! You should now be connected to the wi-fi network; open your browser and visit a website to confirm.
Tips:
  1. Make sure you have a firewall and updated antivirus software especially if you're accessing a public wi-fi hotspot. Open or unsecured wireless networks are not safe at all.
  2. In Windows XP, make sure you have updated to SP3 so you have the latest WPA2 security drivers.
  3. Some wireless networks are set up to hide their SSID (or network name); if you don't find the wi-fi network in your list, ask someone at the establishment for the SSID information.
  4. If you are able to connect to the network but not the Internet, make sure your network adapter is set to automatically get its IP address from the router or try other wireless troubleshooting tips.
  5. If you can't find the wireless network icon, try going to your control panel (or system settings) and the network connections section then right-clicking on the Wireless Network Connection to "View Available Wireless Networks". If the wireless network you're looking for isn't in the list, you can manually add it by going to the wireless network connection properties as above and clicking on the selection to add a network. On Macs, click on the wireless icon, then "Join Another Network...". You'll have to enter the network name (SSID) and the security information (e.g., WPA password).
Sep 20, 2011 | D-Link DIR-600 Router
I got a wrt54gh router just less than a year now. it is connected to our desktop being used by my son & grandson in our living room, while i'm using my laptop in my room. it just happened that i...
If you have Windows XP then try this, for Windows 7 and Vista also the procedure is similar. If you have Vista or 7 then tell me I'll post the tutorial for that also.
  1. In Windows XP, click the Start button and select Control Panel.
  2. Click the Network and Internet Connections category.
  3. Note: If you are using Classic View, you will see the control panel icons instead of categories. Double-click the Network Connections icon.
  4. Click the Network Connections control panel icon.
  5. Double-click Local Area Connection, listed under LAN or High-Speed Internet.
  6. When the Local Area Connection Status window is displayed, click the Properties button.
  7. In the Local Area Connection Properties window, do the following:
    • Verify that the Internet Protocol (TCP/IP) box is checked.
    • Note: If your Ethernet adapter is not listed in the Connect using box, you need to install your adapter.
    • Click Internet Protocol (TCP/IP) once to highlight it and then click the Properties button.
  8. In the Internet Protocol (TCP/IP) Properties window, do the following:
    • Click Obtain an IP address automatically.
    • Click Obtain DNS server address automatically.
Apr 11, 2011 | Linksys Wireless-G WRT54G Router
My Laptops Internet switch has stopped working
Then install your USB device with your CD
Then do this
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
Nov 17, 2008 | Compaq Presario 700 470024-192 Notebook
EliteGroup NFORCE4-A939 (NFORCE4A93910) Motherboard Logo
41 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
