How far does a rennai 26 have to be from a air condition unit motor?
    Novelist:
  • 120 Answers
Distance from the flue to a mechanical air inlet for the Rinnai which has a fan assisted flue is one metre. I this is just the air con motor on a split system it is not really an inlet. However exhaust flue temperatures are hot so I would use the 1 metre rule in this case.
(Just for your reassurance i and I also used to teach gas fitting at the trade schools on occasions am a licensed gas fitter. Also worked for Rinnai for a few years)
Posted on Jul 29, 2010
Haam air conditioning split then I switch on come to E7 what is the problem in my a c please give me answer any parson
Malfunction of Outdoor Unit Fan Motor ( E7)
Remote Controller
Display
E7 Method of
Malfunction
Detection
Abnormality of fan motor system is detected according to the fan speed detected by hall IC when the
fan motor runs.
Malfunction
Decision
Conditions
?? When the fan runs with speed less than a specified one for 15 seconds or more when the fan motor
running conditions are met
?? When connector detecting fan speed is disconnected
?? When malfunction is generated 4 times, the system shuts down.
Supposed Causes ?? Malfunction of fan motor
?? The harness connector between fan motor and PC board is left in disconnected, or faulty connector
?? Fan does not run due to foreign matters tangled
?? Clearing condition: Operate for 5 minutes (normal)
Troubleshooting
Caution
Be sure to turn off power switch before connect or disconnect connector, or parts damage may be
occurred.
Replace the outdoor unit fan motor.
Connect the connector.
Remove the foreign matter.
YES
NO
Are fan motor
connectors
disconnected?
NO
YES
Is the pulse input?
Check No. 11 Check for pulse input
for number of rotations
on the outdoor unit
PC board.
Replace the outdoor unit PC board.
YES
NO
NO
YES
Is there
any foreign matter
around the fan?
Can the fan be
easily rotated by hand?
(S2584
Jun 07, 2016 | Heating & Cooling
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
I urgently need a air-conditioned condenser fan motor
Depends where you live you can contact united air conditioning this is a parts store. Grainger would have it. You need to have the horse power of the motor and the RPM of the motor and the amps. you will be able to find a replacement for it with this information. Be sure to tell them its a dual shaft motor.
Sep 10, 2014 | Heating & Cooling
Rennai hot water heater very slow to heat up!
I would check the gas pressure at the burner. It should be 3.5 inches water column on the manifold. Hope this helps.
Sep 09, 2014 | Water Heaters
I have a rennai infinity that flashes error code 12. What would be the cause of this.
Error code 12 on a Rinnai means the unit lit, sensed a flame but then failed to sense it some time later whilst in operation.
Secondly,when you get a 12 immeadiatly you turn the tap on. This is caused by a short circuit on the low voltage side of the heater.
Dec 06, 2010 | Heating & Cooling
How to replace the heater core of a volvos40 with a 2.5 engine
Volvo Cars 1999-05 - S40 And V40 Models
Heater Core - Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. In the engine compartment:
    1. Remove the top splashguard.
    2. Install two hose clips on the hoses to the heat exchanger. Remove the hoses.
    3. Remove the air conditioning pipe in the engine compartment from the support.
  3. In the passenger compartment:
    1. Disconnect the wiring and the connectors located on the center support.
    2. Remove the mounting bolts from the center support. Remove the support.
    3. Remove the control panel.
    4. Disconnect all the connectors.
    5. Remove the power unit
  4. Cars with air conditioning remove the air conditioning pipe in the engine compartment from the support.
  5. Remove the bolts and the nut from the power unit. Pull the power unit backwards as far as possible
  6. Remove the upper section from the housing.
  7. Remove the section that connects with the floor heater.
    Fig. Heater unit-S40, V40
  1. Press the pipes down. Remove the lower section.
  2. Remove the four mounting bolts.
  3. Pull off the housing. Press the floor heater down. Remove the housing.
  4. Remove the control lever on the valve side.
  5. Remove the mounting and the clips around it.
  6. Carefully separate the components.
  7. Replace damaged components if necessary.
    NOTE Do not disassemble damper motors when adjusting.
  8. Replace the refrigerant temperature sensor.
  9. Replace the heat exchanger.
  10. Check the seals (also on the dampers).
  11. Install the control mechanism last.
  12. Install in reverse order.
  13. Check the setting of the damper motors.
Hope this help (remember comment and rated this).
Jul 27, 2010 | 2000 Volvo S40
Compressor runs slow when cold
hi there, if there is a steak running of compressor check the the lubrication oil or change oil if neccessary.also check the motor condition by loosening the belt from pulley and run alone the motor if still tripping off,replace bearing of the motor.have a nice day and fix my rate thanks a lot
Apr 17, 2010 | Campbell Hausfeld 26 - Gallon Air...
2001 v70 erratic air conditioning
ALL 850 and S-70 models with climate control have these issues and i am an ASE VOLVO MASTER TECH and you must have a lot of experiance to troubleshoot and fix these systems and 20 pages of tests it sounds like one of the damper motors is not working these motors direct air flow to different duct outlets
Jun 07, 2009 | 2001 Volvo V70
Blowing circuit
Does it sound like it's running the usual speed? If it's at lower speed, it may have a problem in the motor, or a voltage drop condition exists. If speed is near normal, check the reeds in the compressor, or the checkvalve between the head and the tank.
May 22, 2009 | Campbell Hausfeld 26 - Gallon Air...
Compressor will not start
It is a good sign that the motor turns freely with and without air. That indicates that you have good bearings and that the intank check valve is in good condition. Next you should check the capacitors and the condition of the windings. Some motors have start and run capacitors and others only have run cap. Remove from the circuit and test with meter having cap. test setting. Most shops will test them for free. The cap should test within 95% of stated ( uf ) value. Replace as needed. Finally check that the flyball switch at rear inside of motor is functioning correctly. At rest, switch is at start winding, then a split second after start, it shifts to run winding. Check contacts are not stuck and that switch is working and lastly that the winding are the color of new penny. Good luck.
Jan 06, 2009 | Campbell Hausfeld 26 - Gallon Air...
Heating & Cooling Logo
46 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
