Question about Bryant 462AJC021BA Air Conditioner
Air conditioner does not seem to flow to bedrooms anymore
  • 49 Answers
Check filter. also sounds like you may have obstruced duct line or a damper closed. if it is flex duct, it may need to be replaced.
Posted on Oct 13, 2010
Why is condensate flowing into the bedroom non- stop?
The A/C should have been installed with a downward slope toward the drainage hole. If it is level or slopes downward inside the bedroom, you will have drainage problems.
Dec 16, 2015 | Heating & Cooling
Why is my air conditioner blowing white smoke?
Smoke or frost? More than likely frost make sure the air filter is clean and evaporator coil is clean this is a sign of low air flow across evap coil or turn fan speed up.
Aug 06, 2014 | Dometic Rooftop RV Air Conditioner
The heating for some reason doesnt come through all the ducts anymore, I used to be able to feel the heat coming through in all the rooms (even if it was just a little bit in the bedrooms). now no heating...
Have you checked the air filter???
Or is there and air filter in the system that you do not know about???
Do you have an A/C coil that is plugged with dirt???
There is an air restriction somewhere in the system...or the blower is so dirty it does not work properly anymore...
heatman101
Jun 27, 2011 | Heating & Cooling
We installed a 12,000 btu Frigidaire unit last night and it doesn't seem to blow 'cold' air. And it doesn't cool our tiny 12x12 bedroom...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 26, 2010 | Frigidaire FAC126P1 wall/window Air...
Air Duct seems to be clogged
Tell them to get it out and do what you are paying them to do. If it is routed to supply a outlet register than there is no reason they should just say oh well.
Oct 28, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Air on heat pump not cool outside unit humming but not kicking on
This could be an inoperative condenser fan.System will kick off on high pressure without proper air flow.The hum indicates voltage is present. Providing the fan motor is not locked up and will spin,Check your run capacitor which helps boost the motor voltage initially and will get it turning.If the cap is good,you may be faced with motor replacement....good luck
Aug 19, 2009 | Carrier 38CKC042 Air Conditioner
A/c doesn't get cold anymore
usually means your as unit has lost its charge and can not effectivly cool your home anymore..advise to call a certified ac tech.to find , repair and charge your units.( but in some cases a "starter relay that sits on top of the ac compressor has gone bad..this holds true to fridges also
Jul 30, 2009 | Heating & Cooling
Does not seem to cooling very well
clean both the evap coil and the condensor coil
Jul 13, 2009 | Amcor NanoMax A12000E Portable Air...
Window unit air conditioner kicks in only when its really hot out
I would consider replacing the t'stat if it does not seem to cycle at the desired temps. Also, the outside air allows fresh air to be introduced into the conditioned space but it will also effect, to a degree, the units ability to cool the conditioned space. Once you get the unit running, try it with the baffle on and closed and see which one you like. Remember, the outside air has and add humidity and can make it seem hotter than it really is in the room.
May 21, 2009 | Whirlpool Electronic Window Air...
Air compressor does not kick in unless ambient temp is > 80
Do not operate low fan and maximum temperature as the coils will freeze up stopping air flow.
Bryant 462AJC021BA Air Conditioner Logo
Top Bryant Heating & Cooling Experts
christian nielsen
Bill Long
Mike Squire
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
