Question about Kenmore Ovens
Oven takes long time to heat up and smell gas odor
  • 106 Answers
That means the pilot flame is not directed towards the main gas orifice or tthe first main orifice next to the pilot burner is blocked with dirt
Posted on Jul 29, 2010
A tenant of ours is saying that their Maytag 27" single oven of: Every time we turn on the oven, there's a very strong gas smell for at least the first few minutes. The oven is heating ok.
you should probably go over or send someone ASAP to pull it out and check the lines are connected properly and haven't become damaged.
Could you imagine the lawsuit and property damage if their was a gas leak. This is the very reason gas has an odor added, it is the only warning sign of a potential leak and explosion.
I would take this very serious and give immediate attention.
Nov 15, 2016 | Maytag Ovens
Strong gas odor only when oven is in operation?
If you're talking about the acrid smell immediately after starting the oven, that's aldehyde gas, a byproduct of cold gas combustion where the flame contacts the cold metal oven surfaces. That smell should disappear within the first minute or two, and it's entirely normal for a gas oven. If you're talking instead about the smell of fuel gas, then your burner may need to be adjusted; it may be running much too "rich".
Aug 23, 2014 | Electrolux Ovens
I have a Maytag Advanced Cooking System (Super Capacity) gas stove. The oven takes an incredible amount of time to preheat & then smell an odor of gas. What could be wrong?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 04, 2011 | Maytag Ovens
Our oven doesn't heat and smells like gas
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 02, 2010 | Maytag Ovens
When I turned on my frigidaire oven today I smelled a strong odor of gas, I never smelled that before. The oven is about 6 years old.
Have it checked immediately for a leaking gas line in your oven. The situation is very dangerous, gas accu-
mulation can explode and cause fire. Get is touch
for a technician immediately.
Sep 24, 2009 | Ovens
Co smell during oven use
What you are smelling is the protective grease against rust or corrosion that came originally with your oven. the odor is normal if you are just purchase the oven.
Dec 18, 2008 | Frigidaire FGB24S5A Gas Single Oven
Gas Odor coming from oven
The reason you can't smell it when the oven is on is because the gas is being ignited. DO NOT USE YOUR STOVE until you get this fixed by a gas fitter. You have a gas leak, which is either a loose fitting or faulty valve or line.
Call your appliance dealer IMMEDIATELY or you could have an explosion!!!!
Sep 06, 2008 | Ovens
Gas smell at start up
Be sure that the igniter has a good ground. I mean make sure you clean it well. Be sure its fastened well. And of course that it is close enough to burner. Air flow in building can also hinder lighting.
Nov 14, 2007 | Blodgett DFG-100 Gas Single Oven
Crosley gas oven will not heat up
That's my mom!!! Go Sheila!!! Hehe.. -RET-
Aug 08, 2007 | Maytag CWG3100A Gas Single Oven
Ovens Logo
136 people viewed this question
Top Kenmore Ovens Experts
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
