Question about Refrigerators
The defrost cycle seems to stay on too long-ice already made will start melting & then refreeze into 1 big chunk. Eventually the "melt" will build up in the bottom of the freezer & will eventually find its way onto my floor. Also directly behind the icemaker, on the back wall of the freezer, there is an ice formation that looks like water has run down the wall & frozen (this area of ice is on the left of what looks like a vent about 3"x3"-not covering the vent) The icemaker is in the left corner of freezer. I realize this is an old refrigerator.
    President:
  • 1,891 Answers
If think your defrost cycle is ok . there is a defrost terminator that controls the heater at 50 deg in the back of freezer , the problem is the water delivery tube is iceing oven and causing water to run down the back of freezer wall . change the tube to newer style. it will be open on the top side . they work better. and the water valve may be leaking through. and may have to be changed .. ,,
Posted on Jul 29, 2010
Ice build up at bottom of freezer how can I solve this problem
My freezer will build up ice if the door has been left ajar and the freezer begins to defrost. The melted ice runs down to the bottom and then refreezes. If you have an auto-defrost, it could be it is not operating correctly.
Jun 07, 2018 | Refrigerators
Bosch Liebherr Premium Ice
u may have a thermostat issue, try to increase / decrease the thermostat.
Jun 02, 2013 | Refrigerators
I have water pooling in the bottom of my fridge, what would it be
more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. Over time it gradually builds and starts voer a larger area. Being you have a top mount refrigerator(freezer on top) there are air ways that connect the freezer to the fridege, which is how its cooled. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 27, 2012 | Ovens
Water is dripping from freezer down to inside of refrigerator what is the problem
Apr 25, 2012 | Whirlpool Refrigerators
Symptoms: Ice cubes melt, drip then refreeze causing
are you having any cooling problems? take a look at your ice cream, if you have any. does it look like it has melted and refrozen? if so, you have a cooling problem, and that is causing ice to melt, then refreeze. if you have no cooling problems, then you may have a faulty water valve solenoid, or even a faulty icemaker.
Feb 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Kenmore side by side purchased in 1/2002. The freezer section keeps melting and then refreezing again. The ice creams melts then hardens up again. Please assist with what the problem may be. We...
It may be the defrost thermostat...
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
Sep 21, 2009 | Refrigerators
Model #PSS26PSSA SS Freezer frequently defrosts and refreezes. When this occurs, the entire ice bin melts into the freezer compartment and refreezes in puddles. Is this a common issue with this model and...
Absolutely not ! There are two types of defrost systems - timer (which relies on compressor run time) and adaptive (newer models) which relies on sensors and an electronic control and will defrost as needed...... During a defrost cycle your comrpessor and evap fan should be off, everything off - and no, a defrost cycle will NOT thaw your food in the freezer, not even your ice should melt ! To me this sounds like a defrost control problem - First thing service should check is your defrost timer and its components (control board, limiter, defrost thermostat, etc.) something is definately wrong.
Now with the advice above I am assuming that before the defrost cycle kicks in your freezer temp was in the normal range 10F and colder (0F is optimal) and refrigerator section cooler than 40F (optimal 34F). If so, then you should not have melting ICE in your freezer.
Aug 24, 2009 | GE Refrigerators
Build up of ice in bottom of freezer compartment
During the defrost cycle heaters in the wall of the freezer are turned on to melt the frost build up. This melted frost "water" is supposed to run out a drain in the bottom of the freezer and collect in a pan under the refrigerator/freezer where it will eventually evaporate. If this drain is blocked it will cause a lot of water to collect in the bottom of the freezer and that water will eventually turn back into ice. I recommend defrosting the freezer manually, removing all the ice/water buildup in the bottom, and trying to unplug the drain line to the pan underneath. Also check the seal on the freezer door. If it's not sealing well it could be letting a lot of moisture enter the freezer which would lead to more frost buildup and more water during the defrost cycle.
May 22, 2009 | Hoover HCA390FFK Bottom Freezer...
Ice cubes made by ice maker become large fused chunks over time.
Ice cubes will deteriorate over time if not used. They shrink due to defrosting of the freezer and will become stale.
Once the ice bin is full, turn the ice maker off until you use the cubes and or dump the cubes every 3 or 4 days and start over.
Mar 03, 2009 | GE Refrigerators
Refrigerators Logo
105 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
