Vista Sonic Solutions DLA Blocking - Computers & Internet
  • jose_c_m80 Aug 17, 2008
    Sonic Solutions DLA
  • Anonymous Apr 01, 2009
    same problem, anyone able to help?
I just put roxio on my pc vista but says dla driver is bloked is there any way to fix it
Posted on Dec 05, 2008
I installed Roxio and my computer says driver not compatable
Posted on Nov 01, 2008
Warning and standby indicator of JVC D-ILA Projector model DLA-X70RBE flashing simultaneously.
Johan, Below are links to your model where you can access,manual,instructions and get support.
Press the helpful button and follow me on fixya for more tips and info.
4K shift ILA Projector DLA X70R Introduction
Replacing lamp on JVC Series Projectors
JVC DLA X3 Warning light issues
Feb 11, 2016 | JVC Televison & Video
JVC DLA-RS1U Projector turns off
I have a similar problem. JVC Project (DLA-RS1) shuts off after about 30 min to 1 hour of use. Everything turns off - bulb, fan, even the little light on the projector near the buttons. After 10-15 min the red light comes back on and you can start the projector.
I have seen this happen when I had installed a knock-off bulb. I believe the bulb runs a little hotter and the projector over heats. Now I am seeing it happen even with a JVC bulb.
I am in the process of taking the cover off the projector to see if anything is blocking the air flow (like a piece of broken bulb, which did break a while back). If a problem doesn't show up there I am going to check the fan to see if it is turning at full speed (maybe replace with a beefier fan?).
Does anyone have instruction on dis-assembly?
Apr 17, 2012 | JVC DLA-RS1U Projector
Deleted Sonic DLA because of crashes and now computer won't recognize unformatted disc in drive
Go to the registry and delete the lower and "upperfilters"for the CD/DVD drive option. you can access it by going to this option. REGEDIT >> HKEY Local Machine >> System >> CurrentControlSet >> Control >> Class >> Select for the option which is the first {4D36.....}. After deleting the upper/lowerfilters, close the Registry Editor and restart the laptop. Then there try inserting a blank disc or any disc. Thank you.
Oct 07, 2009 | Dell Inspiron 6000 Notebook
I purchased a Dell Computer back in 2004 which came with Sonic Digital Media Plus v7. My PC has Windows XP Operating System. A few days ago I decided to install Version 6.0 of Roxios Easy CD/DVD Burning...
Try uninstalling Roxio and the Sonic drives and run Fixit. Then reboot and install Roxio first then the Sonic driver.
If this doesn't work uninstall again as previously, install Roxio and check the CD/DVD if necessary run Fixit then install Sonic driver.
Aug 01, 2009 | Computers & Internet
After CD burning process nearly done write error ruins CD-R disc
I think u can identify this problem by checking step by step. At first change ur cd brande. If probelm still
then setup windows.. then try to write.
May 09, 2009 | Toshiba Satellite A105 Notebook
Driver compatibility problems with dvd/cd drive dell 5160
You have given very little information regarding the actual driver, I do know that there was an issue with the original Roxio DLA.
You can uninstall the DLA or Drag to Disc feature in programs and features, or install the upgrade patch as per this dell link
Mar 24, 2009 | Dell Inspiron 5160 Notebook
I keep getting a message from Sonic saying, Installation package for the product SONIC DLAcannot be found. Try the installation again using a valid copy of the installation package. It says that ...
Article Details ID Number: 000131CR Products: Easy Media Creator 9
Easy Media Creator 9 Deluxe
Easy Media Creator 9 Trial Version
WinOnCD 9
WinOnCD 9 Trial Version (Not available publicly)
Easy CD & DVD Burning ("Vista Compatible" labeled boxes only)
RecordNow 9 Music Lab Premier
OS:
Cause: Through a clerical error, a driver is incorrectly being blocked as incompatible with Windows Vista®. If you do not have one of the above applications, you will need to upgrade to a Windows Vista® compatible version of the software. For Dell Customers
The patch is not intended for a customer base other than Dell. If you do not own a Dell system, it is being offered "as is" and to be used at your own risk.
To download and install the Roxio DLA Update:
  1. Click here for the DLA patch. When the file Download window appears, click Run. Note: If a Security Warning window appears, Click Run.
  2. Follow the installer's on-screen instructions.
  3. When prompted to restart your computer, click Yes.
  4. The computer restarts, and the update is complete
Pleae post here again when you have more issues and ill assist you as long as it takes.
Oct 15, 2008 | Computers & Internet
Sd card reader does not work
you might need to remove upper and lower filtrs with filtercheck 4.6
then repair sonic dla (if it has sonic burning software you use)
www.cdr-zone.com/forum/about4719.html&highlight=filtercheck
Aug 19, 2008 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
298 people viewed this question
David Payne
David Payne
