Question about Garden
Three years ago installed more than 30 recessed halogen 12V 50W lamps in the ceilings during renovations. Have since spent a large amount calling the electrician to change the transformers when this or that light fails. My question is: Can I trouble shoot the transformer problem myself (I'm unqualified) and make good any defect? also would you advise the correct methodology for changing the transformer.
  • 700 Answers
It was a mistake to install them in first place, now, if your transformer blows, that meant that it is overloaded!
primary solutionto the problem, without adding cost of re-wiring will be change globes (50w) to these of lower wattage, say 40w or even less and this will protect transformers from blowing up.
another solution will be to what is load on the transformer, it must be at least 20% greater than combined light supported. if it is not, then duiring power fluctuation it can, and will be burn out.
say, you have 30 lights and 3 switches, this meant that you have three circuits of say 10 lights. 10lights x 50w = 500wat!!! that is rather large and costly transformer, to avoid this prohibitive cost, solve problem otherways, buy 120watt or 150watt transformer and wire two globes to each. this will provide margin as well as enough supply to support your light.
please bear in mind that you are legally not allowed to touch anything what is connected to mains except changing the globe! you need to speak with elelctrician and come to solution in cooperation with eleloctrician.
if you find this advice useful, please do not hesitate to leave comment and vote for me, thanx!
Posted on Aug 02, 2010
Humming halogens. I recently installed an electronic low voltage dimmer, 300watt DIVA, to my Kablelight system. I have 4 MR16- 12V- 50 watt bulbs. (200 watts total). When dimmed, the lights hum loudly. I...
Transformer hum with dimmers is a problem. Lutron may offer you an inductor to add to the wire to help. Replacing your 50w bulbs with 12w LED bulbs may help, too. Same light output.
May 06, 2014 | Electrical Supplies
Hampton Bay Mercer ceiling fan keeps buring out bulbs
Halogen bulbs are a lot hotter than other bulbs and have a much shorter life span. It is the nature of the bulb. You can see about changing just the lighting fixture on the fan or look into getting an LED bulb, they run very cool compared to halogen and last forever.
Nov 26, 2017 | Hampton Bay 24002 Ceiling Fan
Replace GE 50W Halogen bulb in ceiling fixture
if fixture is as shown, remove the nut in the middle of the fixture, remove the lamp, and replace it, note donot touch the lamp with your fingers, this causes lamp to fail, use a cloth to install then replace in reverse as you took it apart
Sep 27, 2011 | Universal Lighting and Decor White 11"...
I have just purchased 3 new Philips MR16 10w LED lamps to try in existing 12v 50w fittings - each with its own electronic dimmable 6o v/a elec t/x. As soon as the lights are switched on with the new lamps...
The LED light bulbs operate at 3 to 5 V usually. The noise your hearing is a result of the voltage reduction within the internal workings of the lamp base. The lamps should be installed with an
LED driver vs a transformer power supply.
This is usually on most packaging:
LED MR16 lamps operate in the same fittings as regular 12V lamps. However, they work best when they are mated with an led driver in place of the transformer.
Example of an LED driver:
http://www.google.com/products/catalog?hl=en&safe=off&rls=com.microsoft:en-ph&q=LED+Driver&um=1&ie=UTF-8&tbm=shop&cid=16162019396751156854&sa=X&ei=HzQpTqOWOK_NmAX0-LWqDA&ved=0CEcQ8wIwAg#
The noise will not go away unless you use an LED driver with the MR16 lamps.
Thanks for choosing FixYa.
Kelly
Jul 22, 2011 | Hardware & Accessories
My Eiki lc-xb33 is projecting the image from my computer very dimly. Although the image is in focus, it is very difficult to see the image at all because it is so dim. Even the blue start up screen is...
You need to remove the cover and check where the lamp light is being attenuated in the optical path from the lamp to the front lens. I would try using a 12volt 50W halogen lamp in place of the real lamp and shine it into the optics system, and see where the brightness starts to go bad.
May 11, 2011 | Eiki LC-XE10 Projector Multimedia...
My projector has gone completely blurry and extremely dim. I have no idea what's caused it. It still seems to be able to project the right colors...just very dim and blurry. Is it the bulb (my bulb has...
either the optical parts close to the lamp are getting old and heat affected, or the focus lens system is dirty etc.
switch off the unit and disconnect the power.
remove the lamp. remove the cover off the whole projector.
get a 50w halogen lamp (like in the ceiling of the house) and connect it to a 12v supply.
Then carefully put it into the cavity where the lamp normally goes. and shine it in the direction that the lamp normally shines. be carefull not to burn yourself and the bits inside.
check the strength of the light as it goes through the various sections of the optical path.
see where the brightness seems to drop right off. see if there is any components that seem to degrade the light strength.
this may give you a clue as to where the problem lies. you can then decide what the next step is.
tell us how you go.
Mar 03, 2011 | Epson EMP-TW600 LCD Projector
How to change a recessed halogen lightbulb?
usually the trim ring that rests against the ceiling just pulls off
Jan 15, 2010 | General Electric Ge Lighting 18534 "ge"...
I have a problem with my kitchen's recessed lighting. For some reason, the six bulbs will go out during the evening hours, then come back on. There is no pattern, with one, two, three or four of them out...
It sounds as if you may have higher wattage bulbs and/or the wrong type of bulb installed in the can fixtures than the recessed cans are rated for.
When the wattage of the bulbs is higher than the rating of the fixture, and/or the wrong bulbs are being used, the recessed can's thermal overload device will shut off the light, to prevent damage and a possible fire situation.
It is unlikely that you've got a faulty dimmer, since you state that not all of the lights go off at once, thus it can be narrowed down to each can and thus the thermal overload being the culprit.
I would suggest you look inside the recessed can light fixture and determine what the maximum wattage bulb you can use, (60, 75, 90 watts, etc.) and use the next lower wattage bulb instead. I also install only Halogen bulbs in recessed cans, (they have a flat lens vs. a rounded bulb lens area like PAR type bulbs). Halogen bulbs are also the most efficient incandesent bulb that provides the whitest light possible and directs more light (and thus heat) downward away from the recessed can.
I avoid using a standard light bulb or PAR type bulbs in any recessed can fixtures as they tend to heat up quite a bit and cause the thermal protection to trip frequently.
As a Master Electrician that has installed literally thousands of recessed fixtures and dimmers, I can say that my customers prefer the Halogen light over standard bulbs and they last longer too.
I hope you find this Very Helpful and best regards!
Sep 17, 2009 | Lutron Diva Dv-600P Light Control By
Minka aire ceiling fan
This may not apply. There could be an electrical problem. But if you installed the bulb with your hand, the oil on your skin can cause the buld to heat excessively and fail. I suggest you use the packaging or part of it when installing it, taking great care not to touch it.
Mar 11, 2008 | Dryers
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
