Question about Philips Magnavox 27MS343S 27" TV
My philips 29PT4182/94r is not working the power supply is ok picture is not coming sync & no sound kindly tell how to set remot code setting thanks
  • 275 Answers
SOURCE: Philips 28PW6332 28" TV
Simple problem. In all likelihood, The Vertical Output IC has failed. It will be TDA 8177. Replace. Or, it could also be that the Supply to that IC has failed. Unless you are competent in Solid State repairs, do not try this by yourself. get a professional Technician to have a look.IC should not cost more than 15-20$ pluch Tecnician fees.
Posted on Aug 21, 2006
Shuttle83
  • 1139 Answers
SOURCE: Philips 21" L01.2A Chassis HV Shutdown
Hello bashlort, The increase in voltage may be to some circuit loading being removed this is a sign that something may have increased in resistance or something may have opened in the attached circuit. Have you taken any voltage measurements in the video section of the set, if not check the voltages on the pins of the video processor IC and follow the connections up to the CRT socket, be sure to pay special attention to the focus and screen grid voltages. If those are ok check the voltages in the horizontal section including oscilloscope measurements for drive signals. Please inform me of your findings. Thank you, Shuttle83
Posted on Oct 07, 2007
SOURCE: Philips tv
you probably need a hotel master remote, i.e. the philips rc2573gr:
http://salestores.com/philipsr.html
Posted on Nov 09, 2007
  • 489 Answers
SOURCE: Philips 27T500 C101 standard set won't respond
you pluged everything. ?
Posted on May 30, 2009
ramendra34
SOURCE: On switching Philips Tv type:21PT 240B/94R no sound,picture
I have Philips CTV 21 PT 240B/94R. and this time a problem are when set on chenel are not stop to change only forward and bottom right side Display Scan+
Posted on Nov 03, 2009
I need a code for a Philips TV to be programmed to a living solutions remote # atc - 1688
  • Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
  • Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  • Push the power button on the remote. This should turn on the device that you are syncing.
  • Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
  • Press "OK" or "Enter" on the remote once the synced device turns off.
  • Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
Apr 26, 2015 | Philips Televison & Video
Philips 60PP9202 60 in. Rear Projection HDTV-Ready Television no Picture no sound
Are you getting some kind of high pitched squeel from set when you try to turn it on?
The more you tell me the more I can help.
Nov 10, 2011 | Philips 60PP9202 60" Rear Projection...
42 inch philips lcd no picture no sound
Sometime a no picture, no sound still has the power light or some other led blinking. The blinks might be an error code that will isolate the problem.
In general on LCD TVs with no picture, no sound, no blink code, the main power supply has failed. The capacitors weaken and when bad enough, damage the power supply.
If there is a blink code, the most, if not all of the power supply is OK and the blink code could point to the problem.
Jan 19, 2011 | Philips 42PFL7422D 42 in. LCD TV
Shutdown after video comes up the green power light stays on but the set will not shut down while changing channels. (philips 27 pt543s) ic702 eeprom and ic7200 control/signal processor has been...
Re:"shutdown after video comes up the green power light stays on but the set will not shut down while changing channels."
Hi.
I do not think this has anything to do with logic circuits and video processing. When you stay on one channel the horizontal and vertical alignment circuit works more than if you change channels all the time.
This is just a guess, but have a look at convergence ICs. when you keep changing channels the power amp ICs (or transistors) go on and off, if one of them is defective it will overheat and shut down.
Other possibility is an internal tuner failure. Also test using a DVS or VCR.
Nov 01, 2010 | Philips 27PT543S 27" TV
Volume lock of philips vardan tv
I hv philips 21RF vardaan TV ,there is sound on AV channel. and the picture is blinking. even some menu setting have changed.. i tried using the service menu but cudnt understand anything. 2 new av channels have come.. av2 and front which were not present before. sound is not coming even on the other channels but picture is fine on them. only on the av1 channel it is blinking., the philips technision had solved this prob once by pressing some code by remote and i don't know the system code
Sep 10, 2009 | Philips 20DV6942 20 in. TV/DVD Combo
AKAI LCT26Z4AD wont power up.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 10, 2017 | Televison & Video
42 plasma tv model42mf230a/37 blue light on no picture no sound
with solid blue led set could be still powering on but would need to verify by checking power supply voltages. if up and signal is present with no menu or audio would be ssb as audio amplifier, micro processor and eeprom are on that board. if voltages are not present you need to offload x and y sustain boards one at a time from power supply and check voltages and if vs comes up with either board disconnected replace that board
Jul 25, 2008 | Philips Magnavox 42MF521D/37 Television
Philips HDTV
usually the high pitch noiese like this indicate some kind of power supply problem. The power supplies inside are called "switching power supplies" and if they're overloaded will make the kind of sound you describe. It sounds like there's a serious problem within. Probably should have it serviced.
If you had an older set, I'd say the flyback transformer has malfunctioned, but I don't think they're in todays set.
Let me know what happens... please rate accordingly.
Dec 19, 2007 | Philips 60PW9363 60" Rear Projection...
Actually Philips 20PF5320/01 Fault no power, blinking LED
ok you have defective power supply! from the secondary power supply! or hot side.
Oct 08, 2007 | Philips 20PF5120/01 20 in. EDTV-Ready LCD...
Philips Magnavox 27MS343S 27" TV Logo
37 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
