Question about Roper RT21SKXLQ Top Freezer Refrigerator
Water is draining from the freezer into the refrigerator. Is there a drain or line that is plugged somewhere that I do not see? It is a RT21SKXLQ02 roper whirlpool top freezer refrigerator bought in 2004.
  • 4,070 Answers
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Posted on Jul 29, 2010
This unit flows continuously thru the drain line that returns to the waste drain is this normal
What's causing this refrigerator problem? [Archive] - Straight ...
boards.straightdope.com > ... > Main > General Questions
Mar 16, 2012 - 32 posts - ‎16 authors
The drain line should come out of the unit some where and empty into a .... water generally goes down the back wall of the fridge and through a ...
How To Repair A Freezer Dripping Water Into Refrigerator ...
removeandreplace.com/.../freezer-drain-frozen-water-dripping-into-refri...
May 27, 2015 - The freezer drain hole and drain line in the bottom of my freezer keeps icing up. ... is to simply run hot water through the drain line to allow water to flow. ..... Divert Water Dripping Outside From Air Conditioner Window Unit June 30, 2015 ..... How To Fix A Toilet That Is Constantly Running - DIY Toilet Repair ...
Refrigerator Troubleshooting & Repairs ' HomeTips
www.hometips.com/repair-fix/refrigerator.html
May 22, 2015 - Refrigerator Runs Too Much ... If your refrigerator runs without stopping, it may be too low on refrigerant to ... 4Make sure the drain line isn't plugged. ... Instead, the unit may have dirty condenser coils, a door that doesn't seal tightly .... on the tubing and, eventually, restricts airflow through the refrigerator.
Dec 29, 2015 | Refrigerators
Model et18pkxfno1 serial eg4024334 type c18tfa97\r\nwater drips into refrigerator compartment somewhere from freezer (inside). Occurs daily. Tried to adjust temp in both refrigerator and freezer but...
The problem is that your fridge's drain line (which is located in the freezer) is iced over. So water can't drain out of the freezer when your fridge enters it's defrost cycle. The freezer and drain line needs to be defrosted by hand. Or you can unplug the fridge and open the doors for a 2-3 hours. Eventully, if no action is taken, the ice build up in the freezer will block the cold air flow to the refrigerator compartment .
Feb 19, 2011 | Whirlpool Refrigerators
At times, there is water that freezes under the vegetable/fruit drawers that are at the bottom of the refrigerator. Also, at times there may be a thin layer of ice on the floor of the top freezer. I'm...
Your freezer drain is clogged or frozen up with ice blockage. Need to remove the freezer floor liner, usually 2-4 1/4" screws holding it in - slide it out. Next slowly pour hot water over ice build up and melt all ice. The drain is under the evaporator coils (small hole near center) this connects to a pan under the refrigerator that then evaporates on its own. I usually place a couple of bowls inside fresh food area on top shelf to catch excess water dripping through ceiling of fresh foods.
Next you will need to attach a heat probe from the heater under the freezer coils and feed it into the drain in order to prevent freezing up again. Use part #819043 heat probe or strip some #14 gauge copper wire and wrap around heater once and place down through drain. Recommend the heat probe 819043 to get it right the first time.
Jan 30, 2011 | Roper RT21SKXLQ Top Freezer Refrigerator
Water dripping into the refrigerator
Sounds very common. Without seeing your refrigerator I can only imagine that you have a drain pan leak below refrigerator, defrost condensate drain line loose or missing the drain pan, frozen over drain opening inside rear wall of freezer or the defrost condensate line is blocked somewhere along its route to the condensate collection tray below refrigerator. I am not finished so plaes don't rate me until I complete. Sea Breeze
Apr 09, 2010 | Kenmore 64802 Top Freezer Refrigerator
It is leaking water out of the bottom. It does not appear to be coming from inside the fridge or freezer. It does start on the bottom on the freezer side.
Apr 09, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water is pooling in the fridge from the icemaker, line is not plugged or leaking. It just seems like too much condensation from somewhere
behind the freezer wall is a drain to the bottom condensate tray under the refrigerator this is clogged remove the plastic inner wall remove the ice buildup on the coils and, coil shelf then: clear the drain with hot water poured into the drain hose with a funnel
Sep 03, 2009 | Refrigerators
Freezer leaks water even after water supply turned off
Remove the food from the lower portion of the freezer and remove the 2 screws which hold the rear freezer panel on . Remove the panel and use a hair dryer to defrost the ice built up over the drain . Once you see the black drain hole , concentrate on defrosting the hole . Once defrosted , the ice water will drain into the hole . I would use a small hose inserted into the drain and blow thru , to remove any debris built up inside the drain . Reinstall the panel and food .
Aug 09, 2009 | Maytag MSD2454G Side by Side Refrigerator
Our whirlpool refrigerator is leaking water out the back. We have turned off the water source but there still appears to be water leaking from somewhere. Everything is still frozen and the freezer is at...
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Jul 11, 2009 | Refrigerators
Water is dripping inside the refrigerator from one of the holes in the top in the area back from the light
The drain is plugged and in defrost the water has to go somewhere. Try to blow out the drain with air. Or you might have to remove the evaporator cover to get hot water down the drain. First try to clear the line.
May 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Kenmore # 63142 Fridge -- Water in Freezer
If water drains out, then there is always a blockage somewhere on drain line.
Defrost the unit completely to get rid of ice building inside drain lines.
If that does not work , then the drain line must be unlocked using a flexible shaft.
Apr 04, 2009 | Kenmore 63142 / 63144 Top Freezer...
Roper RT21SKXLQ Top Freezer Refrigerator Logo
183 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
