Question about Sony Playstation 3 (PS3) Console
When i turn my ps3 on only a blue screen appears with no loggins also the controllers are not synching with the ps3 what do i do??!!???
    President:
  • 1,139 Answers
Have you tried using the PS3 recovery menu. If you are not sure what this is, press and hold the power button. If the console is on it should beep once, then once again then turn off. Release the power button and then hold it again. The console will turn on, keep your finger on the button, it will beep once then beep two times quite quickly, release your finger as soon as you hear two beeps. This will now enter recovery mode. You have several options, usually restore file system or PS3 software works for most problems.
Hope this helps
Posted on Jul 29, 2010
Hi eveyone i have a ps3 and a Logitech wireless controller but won't connect to the ps3 please help
If there is a USB cable /charging port plug into PS3. If this doesn't have a USB cable /charging cable using your other ps3 controller turn ps3 on, scroll over to the settings, manage blue tooth accessories, turn controller on in discovery mode , and follow steps on screen to pair your PS3 and controller
Aug 11, 2014 | Video Game Consoles & Games
How to program this controller for a ps3
If its a bluetooth device, meaning came with adapter plug in adapter to a usb slot of the PS3 then go to manage blue tooth device inside the settings of your PS3. If its just a wireless no adapter needed you can plug it straight into the ps3 with a charge cable and they should synch automatically. If not another is to go into your settings page of PS3 and add or reassign assign controllers.
Feb 04, 2011 | DreamGear Playstation 3 Wireless...
How do you connect a motorola H17 to a ps3 slim
Turn on your PS3 and go to settings. Accessories, add blue tooth device, Turn your bluetooth to discovery mode. go back to PS3 to scan mode. Select the H17 that shows up and enter the bluetooth pairing code 0000 that is right four zeros in a row and hit enter on your PS3. They should now synch, the main thing people forget to do is actually select that item inside your PS3 to synch. Hope this helps. Happy Gaming
Feb 04, 2011 | Video Game Consoles & Games
My ps3 shuts down after two minutes. It won't turn on when I press the ps button on my controller. I don't get a blue light at all, and when I do turn it on I get a message that says it was turned off...
when that message appears press the PS button on your controller and your controller will turn on, follow the steps on the screen after shutting it down it should be back to normal, all you have to do is hold the O/I button for 2 seconds, it will turn off after that press the PS buton on your controller and it will turn back on
Apr 14, 2010 | Sony Playstation 3 (PS3) Console
My PS3 tries to turn on... but won't
Generally its an overheating Problem send it back to Sony to fix
Mar 19, 2010 | Sony Playstation 3 (PS3) Console
When I press the PS3 button to start the game, it
try resetting your controller settings, don't load any game into the blue-ray slot, while on the XMB screen press and hold the PS3 button and the settings should appear. after resetting or adjusting your controller settings turn of the ps3 and turn it back on.
Dec 03, 2009 | Sony Little Big Planet
Will not play games or dvds- menu screen will not come up the screen just shows the red wavy lines not the blue like it is suppose to
1- Disconnect the PS3 from the internet.
2- Turn the standby switch off so the red light turns off too, then you turn the system back on
3- Then place your finger on the power button for a total of 4 beeps to access the recovery menu. It might not work on the first attempt but it will on the second.
4- The display will instruct you to connect your controller to the PS3 and press the enter button. A list of menus will appear on your display. The choices are as follows: Restart System, Restore Default Settings, Restore File System, Rebuild data base, Restore PS3
5- Select Restore Default Settings.
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
Completed ps3 update to 3.00, controllers stopped responding
If you still have the PS 3 manuals, try pairing the controllers to your console again by following how to synch it or push the reset button from the back of the controller.
Sep 10, 2009 | Sony Wireless Controller for PS3
Boots up to Safeguard blank blue screen..loggin failed
This generally indicates a hard drive failure. You will need to replace the hard drive and reinstall the operating system.
Jul 01, 2008 | IBM ThinkPad R40 2723 Notebook
My controller for my ps3 will not synch with my ps3.
Okay umm the PS3 has to register the PS3 controller to work. So the controller you got from the PS3 box you need to use that Controller to register the other Controller just go to Options go down to Bluetooth Devices and go to Register a BlueTooth Device and follow everything there.
Apr 29, 2008 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
128 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
