Question about GPS
My car is a 1997 Mazda capella 1800 cc 4cyl. I have fitted a dry HHO cell with a PWM. The 02 sensor has 4 wires. I have a Dual EFIE Delux with 6 wires Q. Can anyone help me to wire the EFIE To the car ? Thanks Graeme
  • graemew200 Jul 29, 2010
    Efie devices ARE legal
  • 560 Answers
Yo, Waz up, my fellow fast lane living, high RPM a whining, wide torque curve a screamin----4 cyla-motor giving up all she's got.....;....and now you want a "tittle-bit" more.... tweaking O2 signals to your ECM.....and more...
Follow the link I've left below, to enlightenment, knowledge, and fact...
The answer you seek (and more) is there....no BS...just the facts.. follow the directions to a tee....(seriously)....or your ride might run like ****....Sincerely, 2coolrick...
http://efieo2.com/pdf/DualEFIEO2Deluxe.pdf
Posted on Jul 29, 2010
    Brigadier General:
  • 4,090 Answers
Please note that EFIE devices A) are not legal for use on public roadways and B) have been found by me and others to be of very little value anyway. ECUs are much too smart for such a simple device.
If a vehicle is equipped with dual o2 on a single cat, you only need to offset the one before the cat. The only time you need dual O2 EFIE is if you have dual cats or dual O2 my car is a 1997 - ccd2793.gifsensors before the one cat
These units dont really work anyway, but you wont belive it unt6il yo8u try I guess.
Thanks for using FIXYA
Need torque for big end bearings on mazda capella 1800 cc engine
you can get the whole knowledge from service and repair manual which you can get from the given link http://toolsnyou.com/
May 03, 2018 | Mazda Cars & Trucks
Hho no mpg increase on turbo diesel
Hi, try to hook up the hho gas hose into a vacuum line of the crank case (with t-connector) NOT directly b4 the turbo. That might help. Its not getting enough vacuum to "pull" the gas from the cell. How much hho production do you get right now? Greetings, ****
Dec 18, 2008 | 1996 Mazda MPV
ABS, Traction control and handbrake light is on. Car was running on 3 cylinders previous to the lights coming on. 1999 Mazda SP20 Familia (323)
I have a Mazda Capella (626) 1998 and had similar problem other than it was running on 4 cylinders and the hand brake light was not on and the ANSWER was a speed sensor which is to do with ABS system needed replacing. You can determine which one is broken by putting volt meter over each of them.
Nov 17, 2008 | Mazda 323 Cars & Trucks
1998 mazda capella.injector pulse no spark. 4 cyl
Sherylpuha,
Have you checked the coil from where the spark comes from and the computer sensor fuse block?
Oct 16, 2008 | 1998 Mazda 626
HHO generator wiring
the hho generator power and ground does not go to the maf sensor. what you need is a maf /map regulator, but it has no connection with the generator. it is just helpfull by saving gas if a hho generator is installed. If you have o2 sensors in the exhaust pipe, you need a EFIE first!!! more questions, no problem, hydrotuning@gmail.com, greetings, ****
Oct 05, 2008 | 1995 Ford Aerostar
2002 ford mustang gt map sensor enhancer connection? (for HHO)
MAP enhancers usually wont do the trick for long - the computer will learn the adjustment to the MAF and overide within a day or so usually less than a few minutes.
The computer is best altered using an EFIE to adjust the O2 sensor(s), usually adding between .2 and .3 volts to the O2 sensor signals does the trick - each combo of the HHO and car is slightly different - you have to play with it to find your best setting. You only need to alter the signal on the O2 sensors ahead of the cats as they are the ones the computer uses to adjust the fuel.
Aug 12, 2008 | 2002 Ford Mustang
GPS Logo
117 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
