Question about Whirlpool Calypso GVW9959K Top Load Washer
My washer will wash but when it reaches the rinse cycle the water comes out very slow and the clothes are still soaked.
  • 171 Answers
It is probably due to a clog in the pump or hoses or the pump has gone bad. not hard to replace but somewhat costly
Posted on Jul 30, 2010
Kenmore 70 series washer
If you can see a constant water pressure from the hot and cold, chances are the water solenoid valves are ok.
I would look towards resetting to factory and checking the main control unit.
May 11, 2014 | Washing Machines
Maytag bravos mvwx600xw0
It is possible that poor water flow may be the culprit. Most washers operate on a water level system. The water levels have to be reached before the next cycle begins . If the water flow is slow this can extend the run time. To remedy this shut water off to unit disconnect hoses at unit. There usually are screens inside each hose connection on washer gently remove these and clean them.reinstall in washer. Before reattaching hoses put the unattached ends in a pail and turn the water on to flush out the hoses. Then reattach them and see if this solves the problem. Hope this helps.
Dec 31, 2013 | Washing Machines
SM 8525492A whirlpool washer rinse cycle no water comes out, just hums
when the washer goes into rinse cycle it only uses cold water so clothes don't rinkle,so most likey you have a problem with your cold water,do this,shut down the water to the washer,remove the water lines from the back of washer and mark them so you know how they came off,stick the hoses into the washer if they reach or a bucket,turn on the cold water to see if water is coming out of hose,if water does come out of hose good then stick the cold water hose back on the washer and run it only on cold,if it doesn't fill then you know you have a problem with the water valve on the washer and it's not the house water valve that's bad,and usually if you have a problem with the washer water valve it will just hum and no water will enter the washer so if you hear a humming sound it will be the water valve.tried looking up the model number you sent but it doesn't come up on the parts lookup
Apr 25, 2013 | Washing Machines
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Clothes are not completely rinsed (they're soaking wet) at very end of spin cycle.
Try to fill minimum water level in your machine with out adding detergent or clothes and complete cycle and see if it is any watter inside. Could be a water pump.
Dec 29, 2009 | Roper RAX7244KQ Top Load Washer
Doesn't Wash Clothes, But It Rinses Clothes
hello. i can help you.
Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Jun 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Ultimate Care II - Rinse Cycle does not start
sounds like a lid switch problem. is there a clicking noise when you open and close the lid?
if not then the lid switch may need to be replaced; inexpensive.
this could also be caused by a bad timer.
also try a different speed for the rinse cycle, it may be a bad motor and it is not going into a certain speed. instead of gentle or slow speed try fast or normal, something like that.
Jun 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
63 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
