Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Stinking drip pan sludge - Frigidaire FRT21H8 Top Freezer Refrigerator
    President:
  • 1,891 Answers
Clean it and bleach.in tray . the do have clorine tabs for this problem .. .. mm
Posted on Jul 29, 2010
Model# kfcs22evms8 kitchen aid fridge- how to clean drip tray? Can't get at it.
Clean Refrigerator Drip Pan, Clean Walls - YouTube
? 2:55
https://www.youtube.com/watch?v=I9YP0iH_zho
Aug 5, 2008 - Uploaded by Handyman Matters
Scheduled Home Maintenance: clean refrigerator drip pan and wipe ... leaking,Kenmore,Sears,Whirlpool,KitchenAid,Roper,10677292790 ...
How to Find the Drip Pan on Refrigerator ' Home Guides ...
homeguides.sfgate.com > Real Estate Rentals & Leases > Get out of Leases
The drip pan on your refrigerator is a receptacle that catches condensation flowing from ... Occasionally you may need to get to the drip pan to clean it, remove a ...
KitchenAid refrigerator drip pan Questions & Answ
Dec 16, 2015 | Refrigerators
How do i remove a drip pan from a kenmore refrigerator
The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
Instructions
Rear Access
1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
Front Access
4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
6 Pull the drip pan out from under the refrigerator.
Apr 20, 2012 | Kenmore Refrigerators
I lhave a leak in the passenger floorboard of my 2001 nissan frontier. it drips when the ac is on and only then. I was told that the drip pan is cracked and has to be replace. This is costly and the dash...
Before going ahead and replacing your drip pan, double-check to see that the external drain hose isn't clogged, which would cause condensate to back up, overflow the drip pan, and leak into the passenger compartment. Often, these drains fill with "gunk" (mold, mud, sludge) that slows or completely stops water flow. You should be able to find the drain opening if you look under your Nissan--it probably looks like a little rubber tube that extends out 1/4 to 1/2" from the underside. Sometimes, in rear wheel drive cars, the drain hose is routed into the hump for the transmission / drive shaft--in those cases, it can be a little trickier to spot. You can also cheat and just run your A/C for a while, then look under the car for a spot that's dripping water.
You can use a variety of tools to check to see whether the drain is clogged--I used a wooden chop stick once because I was worried about tearing the hose--but a lot of these hoses have some twists and turns that make it impossible for a straight tool to probe all the way to the drip pan. I've had the best luck using bursts of high pressure water (garden hose pressure is just fine) up into the hose and letting it drain out. Often, a few bursts of that will blow out a surprising amount of gunk and increase drainage flow.
It's possible that whoever investigated your problem has already checked the drainage tubes (though I bet they only looked at the last few inches that were easily visible from the outside; clogs often form right at the drain inlet in the pan itself). If you really do have a cracked drip pan, I can't think of a way of patching the pan without taking off part of the dash to get at it it. At that point, there's little cost savings in repairing the existing pan over simply replacing it, since it's more the labor, not the cost of the part, that makes this an expensive job. Plus, if your repair doesn't hold, you'll need to remove the dash again to finally replace the pan.
May 29, 2011 | Nissan Frontier Cars & Trucks
Have model number FV4BNB006 air handler and condensate is not running down the coils and into the drip pan. It is falling directly on to the filter and into the air box creating a large water issue.
Be sure the unit is tilted slightly to the rear and that the back drain
is clear. Also the floor of the unit should be clear of sludge,etc.
so the water can drain from front to rear and out the drain.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 31, 2010 | Carrier Heating & Cooling
How do i change the oil filter on a 1991 cutlass calais? any special tools?
YOU NEED 4.5 QUARTS OF OIL WITH NEW OIL FILTER.YOU NEED OIL FILTER WRENCH YOU NEED WRENCH TO REMOVE OIL DRAIN PLUG.YOU NEED A DRAIN PAN CATCH OLD OIL.NEED LATEX GLOVES TO KEEP GETTING OIL ON HANDS.OIL DOES CAUSE SKIN CANCER.NOW YOU CRANK CAR UP LET IT IDLE 5 MINUTES TO LOOSEN UP OIL AND SLUDGE.TURN OFF ENGINE.SAFELY RAISE SUPPORT VECHICLE ON LEVEL SOLID GROUND USING JACK STAND.PLACE DRAIN PAN UNDER OIL PAN THEN REMOVE OIL DRAIN PLUG LET OIL DRAIN OUT UNTIL IT STOP DRIPPING. PUT OIL DRAIN PLUG BACK IN OIL PAN. THEN SLIDE DRAIN PAN UNDER OIL FILTER REMOVE OIL FILTER LET OIL DRAIN UNTIL IT STOP DRIPPING.TAKE CLEAN PAPER TOWEL WIPE OIL FILTER SEAL SURFACE MAKE SURE NO DIRT ON SURFACE.TAKE NEW OIL FILTER POUR NEW OIL IN FILTER UNTIL ITS ALMOST AT TOP THEN.RUB CLEAN OIL ON NEW OIL FILTER SEAL.THEN PUT NEW OIL FILTER IN PLACE HAND TIGHTEN IT.POUR 4 QUARTS NEW OIL IN ENGINE CRANK CASE USING A FUNNEL.WHEN DONE.CRANK THE ENGINE CHECK FOR LEAKS AT OIL FILTER AND OIL DRAIN PLUG.IF ALL IS GOOD JOB WELL DONE.
Aug 11, 2010 | 1991 Oldsmobile Cutlass Calais
Excessive water dripping from exhaust
Try to use 3oz pure accetone available at sally beauty supply and 1 oz of Xyline available tat Home Depot, Thay will clear your engine from sludge. Use cheap oil and repeat copule of times.That is per 10 gallons of fuel.
Feb 10, 2010 | 2004 Ford F150
My 1999 jeep 4 7l is knocking bad any sugestions
In most cases, this will be due to restricted oil flow that can be caused by motor oil sludge build up. this will happen if you don't change your oil regularly for a long period of time. i would drop the oil pan and, have a look inside of the pan. if you notice a black gum or thick sludge build up on the bottom of the oil pan, this will confirm sludge build up in this engine. this is very bad and, it can keep the vital parts form receiving proper lubrication during run time. This could also be bad rod bearings or worn crank shaft sleeves as well. main bearings could be worn also. This sludge can ruin a engine very fast and, it is almost impossible to remove. if you are noticing any smoke coming form the tail pipe, this will confirm this.
Jun 13, 2009 | 1999 Jeep Cherokee 4WD
Cannot remove drip pan
im sorry but that drip pan cannot be removed you might have to do the best you can with it in there.
Jan 03, 2008 | GALAXY Microsystems 63702 Top Freezer...
I cannot get to the drip pan under refridgerator to empty it. It is filled with sludge and smells bad
Thank willie for helping with one: "Well, it looks like the pan is a seperate plastic pan and not the compressor mounting pan like some of the newer ones are. It appears that you have to remove the condensor fan motor and mounting bracket then maybe the pan will left up and over the compressor, or maybe there is enough room to lift the pan up and out the front over the condensor coils"
Jun 04, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
79 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
