Question about Garden
Each time PTO on my Broadmoor Lawnmower, Model 1694473 is engaged a very loud vibration noise is heard coming from underneath;I have changed a damaged belt but the problem persisted.
    Problem Solver:
  • 4 Answers
This sounds like an unbalanced blade. Replace both blades with new ones.
Posted on Jul 29, 2010
I have a troy Bilt riding mower and When we turn pto on to engage it will engage but the noise is so loud. And the pto will not stay in the on position.
check and look at deck [ unit not running and key in pocket ] for loose ,damaged ,debris or out of alignment==belt ,pulley , mandrel,tention/actuator pulley or blades
May 04, 2017 | Troy Garden
Why is my lawnmower new pto not engaging? it is a dealer item and i installed it in reverse order how i took the old one out.
The voltage at the electric needs to be checked. You have a bad switch or electrical connection.
Another way to check the pto is to apply 12V battery voltage directly to the clutch's electrical connector via jumper wires. If engages fully doing then you an electrical problem before the clutch.
Aug 09, 2014 | John Deere L100 Series
Cant get the switch to acctavate the mower deck on a cub cadet lawnmower
Check the fuse, tan/blue wire coming off ig switch or tan coming off PTO sw.
If it keeps blowing, check wire going to PTO unit for shorts or defective connection to PTO.
Apr 16, 2014 | Cub Cadet Garden
Bolens riding lawnmower st100 pto won't engage?
check for power to the clutch if yes the clutch could be bad or a wire going to it if no power check the safety switches
May 17, 2012 | Briggs & Stratton Garden
I had just started cutting grass with my John Deere L120 riding mower when the blades stopped turning. I thought the belt had broke or come off so I pulled into my garage to investigate. I turned the mower...
You have several safety switches on your unit. The engine should not start if the PTO safety interlock is engaged. Be sure PTO switch is off.
If the sarter Does Not Work Or Will Not Turn Engine Brake pedal is not depressed.
or the PTO is engaged.
Battery terminals are corroded. or Fusible Link in starting circuit is blown - (Not likely unless bad wires) Here is a link to your wiring diagram (maybe your model)
http://www.postimage.org/image.php?v=Pq1tOfiS
Notice how the starting circuit goes through the brake pedal (must be depressed) and the PTO switch (must be disengaged) and that the PTO only works with operator present. Print that page while link still works.
Aug 11, 2010 | Garden
Hi i removed my carb 2 clean it out on my 04plate gilera runner vx125 i refitted it and it's started vibrating and been very loud every time i wind it on. Could someone help me please. Thanks
The only thing that comes to mind, as you say " is very loud when you wind it on". Check to make sure the carby is connected to the air box, air filter properly, this loud noise you are hearing is probley air intake leak. check your air filter system.
I have never heard of such problems, ' it's started vibrating and been very loud every time i wind it on.' Coming from removing and cleaning out a carby? Just look things over carefully, you will spot the problem im sure.
Good luck
Jun 18, 2010 | Motorcycles
Loud periodic buzzing
Are you sure this noise is not just the ice maker trying to cycle without water? If it is not turned off it will dry cycle every 15 min or so.
Jan 18, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Garden Logo
133 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
