Question about EliteGroup P4VXAS (P4VXAS-R) Motherboard
The light foe the power switch came unplugger and i need to know where to plug it in at
  • 110 Answers
According to the closest, existing model, (the P4VXAS2), look for a group of pins near the bottom right of the motherboard, labeled LPANEL. Connect the Power Light cable to pins 3, 5, and 7. (If you look at it vertically, with pins 1 and 2 on the top row, then it will be connected to the top left of LPANEL.)
Posted on Jul 29, 2010
I plug it in, flip the switch, and nothing.
test the c.breaker and reset. and try again.
2) If the problem persist, test inside the fuse and replace, test the flip switch with DVOM for faulty and replace
3) of course unplugg the power cord, and tight any wires loose and connector very well. and try again.
God bless you
Nov 22, 2012 | Exercise & Fitness
ERR on the treadmill when I switch on. how do I fix and get working
Any other codes displayed? Safety key fit firmly in? Go to the front of the treadmill turn off the power switch off and unplugg the unit for at least 30 seconds then plug in the unit turn power switch back on. If this does not clear the error code your unit will most likely need to be serviced.
Nov 16, 2011 | Kettler TX3 Folding Treadmill
On the screen is only /attention / entering sleeping mode/no video input what is a problem?
1.This means that your comp is supplying power to the comp...
2.check video cable...unplugg and replugg...
3.Still not resolved...unplugg all the devices from the back including the power cable...
4.then press and hold the power button for 20 sec...then connect the power cable keyboard mouse and the monitor cable...
5.then try to start the comp...
6.still not fixed...switch the voltage selector at the back...
7.still not fixed need to reset the ATX cable inside the comp...
8.Still not fixed can be a hardware problem...
Apr 06, 2011 | Computers & Internet
3 of my 4 windows in my 2006 impala are not working. the only one working is the passenger side. help!!!!
try the switch, get the switch out and check the plug for power, if you have power its the switch. always check switch first, then check motor power if it has power than motor is bad. start with fuses first...
Mar 16, 2011 | 2006 Chevrolet Impala
Power going to door switch-light goes off and on with switch, press start switch-switch makes contact but dryer does not come on. So when on switch is pressed unit does not power on.
unplugg dryer,take the 2 wires off of door switch connect them together with electrical tape,plugg dryer back in hit start switch dryer should come on ,that tells you that the switch is bad,this can also done with a tester
Jan 23, 2011 | Dryers
My 62hmx95 tv power dont go on light just blinks i
hi , ther is a lock out switch which prevents the tv from operating IF the LAMP cover door is NOT in it proper secured place... Check this..MAke sure when replacing the lamp, the main power cord is unpluggged..
Mar 20, 2010 | Toshiba 62HM95 62" HDTV
Fisher & paykel - SPIN light keeps flashing and machine beeps
could be a faulty off load switch
running off balance
machine not level
depends how old the machine is then
if none of those
worn machine motor or internals
might the the circuit board
Apr 16, 2017 | Fisher Paykel EcoSmart GWL15
HP won't power on at all~PSU light blinking, then solid, then off
Dead short on the machine causing the power supply to go into shutdown (Fold Back Protection)
Remove all of the connectors coming from the power supply (Label them so that you know here they go back to on the Motherboard and the DVD etc (Including the processor fan one)
Place all of them back one at a time starting with the main one if the led stays on then plug in another till you locate the short.
If the led dies when you plug in the main MB connector then you are in deep brown stuff
All you can do then is to remove the Ram and any other unpluggable device to see if that is the cause
Jul 05, 2009 | HP PAVILION A6230N DESKTOP PC
Will not turn on
unplugg everything from the back of the wii and unplugg the power/ac adaptor form the wall wait 2 minutes and plugg everythnig back in.....hopefully this works for you it worked for me!!
Aug 26, 2008 | Nintendo Wii Console
No power to the television
Dont know if this will help, try leaving it unplugged over night, thaught I saw that solution in a blog somewhere a while ago.
Dec 23, 2007 | Akai PT5598HD 55" Rear Projection...
EliteGroup P4VXAS (P4VXAS-R) Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
