Question about GE Microwave Ovens
Micrwave will not heat I replaced megatron and diode also turn table will not turn
  • sanooyen Aug 01, 2010
    After a few different ideas yes it was helpful --I wish I would have come here first --it would have saved me more money than trying this on my own.
  • GE Master
  • 2,605 Answers
Welcome to FixYa.
Sorry to hear you`ve already replaced those parts...unfortunately to no avail and likely unnecessary based on your description, I`d say you`ve got a faulty cavity temp. cut-out failure.
If it fails the turntable will stop nor will the unit heat...exactly what you`ve described. They vary from model to model so I don`t want to generalize.
Can you provide the model number of your particular microwave.
I`ll watch for your next post/reply.
macmarkus :)
Posted on Jul 29, 2010
  • 15 more comments
  • sanooyen Jul 29, 2010
    GE Model JVM1730DM1BB
    GE MODEL JVM1730DM1BB
  • Mark MacDonald
    Mark MacDonald Jul 29, 2010
    Hi again, thanks for providing the model number.
    This unit is full of hi-limit cut-outs. ( I assume you checked the obvious one on the magnetron...right ? )
    That being said, it needs to be determined which one is which and since I don`t have a diagram in front of me, I`ll start by directing you to "searspartsdirect.com" and in the space to enter the model number ONLY enter the JVM1703.
    This will bring up a list of model`s where you can identify yours by exact numbers/characters.
    Now open up the illustration and with your wiring diagram ( inside the unit behind the control panel...usually ) you can identify which thermostat`s should be in the "open" position and which one`s should be in the "closed" position.
    Depending on which one you identify as open or closed when it should be the opposite should allow you to test the unit by either "jumping" it our or "opening" the circuit.
    Let me know if this is helpful to you...you should only need a multi-meter to check the thermostat`s and it likely will be the one of either up top of the cavity or the one on the base behind the control.
    I`ll watch to see what you find. Good luck.
    macmarkus :)
  • sanooyen Jul 30, 2010
    i found the wiring diagram in the microwave --I believe I tested all T.C.O`s it has 4 and it looks like to me they are all good???? what next ??
    As before when I push time to cook ----light comes on times starts to count down I can hear a click but the table will not start and it doesnt start to heat
  • Mark MacDonald
    Mark MacDonald Jul 30, 2010
    That is very unusual. I have to ask so please don't take it the wrong way. You checked all these with at least one wire off the tco's right ? Also one or more of those should be "normally open" according to the tech sheet...or no ?
    If so, I'd be checking the secondary door switches ( if it where the primary the fuse would blow ) as they too can cause those symptoms, just less common in my experience. The tech sheet should tell you the "state" they should be in as well and you will need to check for continuity only.
    Let me know what you find.
    macmarkus :)
  • Mark MacDonald
    P.S.
    Do you what year you purchased the microwave ? Approximate age ?
    I did not remove a wire on all --they are all normally closed except for the hood TCO which is normally open --dont worry about hurting my feelings im new to this I went to school for electronic but 14 years ago
    purchased in 2007
    I did what you said just pull one wire and check it --when I tested the cavity TOC it worked for a couple of seconds then quit --did I mess something else up??
    and went back to what it was doing --trying to start but not heating
  • Mark MacDonald
    You mentioned something that sparked a thought when you said "I did what you said just pull one wire and check it --when I tested the cavity TOC it worked for a couple of seconds then quit --did I mess something else up??". Explain exactly what you did there, did you remove a wire and it worked when you reattached it ? What is the door like ? I mean can you move it up and down slightly by the handle ? If so try this while it's running and listen for the mag to kick in ( it's usually a distinct sound, even better if you have a clamp-on ameter ). If so this could be the problem...the door latch isn't contacting the secondary switch enough to allow the control an ok signal/voltages. While you where checking the tco you mentioned it worked briefly...that sounds like a switch and not a tco.
    macmarkus :)
    well I pulled one wire from the Cavity TCO put a jumper from that wire to the other wire that was still attached to tha TCO plug in unit --after pushing cook the tray started to turn and sounded like every thing came on --but after a few seconds it when back to what it was doing -- tray not turning or heating
  • Mark MacDonald
    Did you try the door movement suggestion ? I wondered if the door hinge had some wear to it, hence intermittently or more often than not, not contacting the door switches properly. (specifically the secondary switch).
    Because it does appear to work time to time as you alluded to while testing the tco, it sure sounds like a door alignment/switch issue.
    Let me know.
    macmarkus :)
  • sanooyen Jul 31, 2010
    Well not really time to time just one time --I tried playing with the door working it up and down opening and closing it but it still not working --any more suggestions
  • Mark MacDonald
    Mark MacDonald Jul 31, 2010
    Hello again,
    Sorry I haven`t been able to reply sooner, other commitments...you know how it is.
    I think at this point I would be changing the three switches for the door latch assembly, monitor wb24x830, primary...or lever switch as it can be referred to by some # wb06x10128 and secondary #wb24x829.
    Simply testing these switches for continuity can be misleading as well, at least if you remove them.
    Testing should be done while intact with the door closed and wires removed, thus giving you an actual reading of the position when the door is closed.
    In the worst case scenario it could be the control board relay, however if that where the case it usually manifest in a manner whereby only the display accept`s a command and counts down without the light or turntable or mag coming on...it doesn`t sound like that is the case.
    Only because when one is faulty they should all be changes as they do work in unison. I`m certain the info you have will confirm this to be true.
    I hope you can appreciate this can be a process of elimination and trying to do so from afar makes it that much more challenging and time consuming, but I`m going on info through you I could typically determine through my own testing.
    The good news is all three of those switches are less than $35US and should be available at "searspartsdirect.com" or "repairclinic.com" among others.
    Let me know how you make out. I`ll continue to guide you until it is resolved or as much as I can.
    Good luck once again.
    macmarkus :)
    Well I check the continuity of the switches with the door closed and guess what you were right the primary interlock switch on the bottom of the door was bad---I ran down to a local appliance store purchased a $6.00 switch and it WORKED!!!! Now I just have to replace the dish that I broke when I pulled the darn microwave out. Thanks for the help I wish I would have done this first before buying a the Megatron and Diode --again thanks for the help
Silvercrest microwave, table dont turn no heating
follow the steps, use the VOM for fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Jun 17, 2013 | Microwave Ovens
Our microwave has stopped working for the second time in two years. When you try to heat something, it hums but not quite like it is heating. There is also a funny smell.
SAFTY FIRST
UN -PLUG IT,,,,, THAT "FUNNY SMELL" SOUNDS LIKE IT IS SHORTING OUT
PERHAPS THE MEGATRON HAS GONE BAD, THE MEGATRON IS THE
HEART OF ANY MICROWAVE
AS A EX- FIREMAN, I KNOW FROM FIRST HAND EXPERIENCE THAT
"A FUNNY SMELL " OR " UN-USUALL SMELL COMING FROM AN ELECTRICAL
ITEM IS A SIGN OF DANGER
Feb 05, 2011 | GE Profile Spacemaker JVM1871 Microwave...
It won't heat water,but it will turn around
Sounds like you lost your HV diode. Magnetron could be bad but these days they are pretty good. Diode costs about $5 at www.mcmelectronic.com . It is located in left side near the rear and should be straightforward replacement. Let me know how this works out. Thanks for using FixYa. Contact me if you need more info.
hardrocko
Feb 11, 2010 | Hotpoint RVM1435 Microwave Oven
Microwave wont heat food. Everything else works.
Micorwave doesn't work when the megatron tube is out. That's probably why it won't heat up. Either replace microwave or the tube. You can get the number from Sears for the megatron tube by calling customer support.
Nov 09, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Danby microwave does not heat food and makes loud constant noise
IF the noise is a sound coming from the oven area, its the megatron tube. Typically, replacing the megatron tube is more expensive than replacing wiht a new unit and a new warranty.
Nov 06, 2009 | Danby DMW112 Microwave Oven
GE Spacemaker XL1800 hum/buzz noise but heating works
the magnetron needs replacement my friend, although you can still heat up food but eventually it will soon fail.
appreciate your kind comment
Apr 12, 2009 | GE XL1800 1100 Watts Microwave Oven
The microwave does not heat and the turn table does not turn
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Feb 24, 2009 | Maytag MMV4205 Microwave Oven
Microwave will not heat any thing.
the plate has nothing to do with the microwave heating up the food
but the magnetron that heat the food is bad and will need replacing
I would ask a electronic shop how much they would charge to replace it , and if is not worth it to you then a new one would be a good call
Dec 01, 2008 | GE Microwave Ovens
Whirlpool Micrwave, model #mh6150xls-1
On this model, it should be a defective secondary (top) door switch or the door switch mount.
If this switch fails to be activated, the oven will seem to run but not heat and the turntable will not work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
I'm confident this will be a FixYa! We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Microwave Ovens
Microwave Ovens Logo
77 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
