Resetting Router to default Is it really possible (suggested by one of your techs on here in the past) that if you don't remember the pword/ username on your router you can sometimes reset the router to defaults, thereby also resetting the password and user name to the default user name and pword when the unit is first setup the 1st time (factory condition by downloading the correct upgrade from the manuf's site to your desktop, then executing the patch while actually being connected wirelessly to the network? (no dumb comments please, I know about reset button on back of router) Thank you.
  • JOE Jul 29, 2010
    Thank you for clarifying this issue.
    Genius:
  • 1,341 Answers
That is right.When you use the reset option, it brings the router to a factory default, that is username, password and encryption type is brought back to original options.Hope this helps.
Posted on Jul 29, 2010
  • 2 more comments
  • JOE Jul 29, 2010
    I would like you to be more specific, by downloading the patch for the firmware upgrade for the router model, if I run that file by saving in to desktop then running it while Being Connected to the Wifi network (No Ethernet Cable Used) what are the chances of the router being set back to defaults w username +pwd login thereby being reset to factory defaults?
    Thanks for your rapid response, I will wait for your reply.
  • heeman mohun Jul 29, 2010
    It is best to upgrade firmware when connected via a wired connection to the router. There is no guarantee that it will not reset the username and password, so it is best to be ready to set it up again via the router settings control panel.
  • JOE Jul 29, 2010
    You meant there is no guarantee It Will Work will being connected Wirelessly w no cable to the router?
    I mean that the username, password and encryption may revert back to original factory settings after a firmware update. It is a good practice to update the router while it is connected via a wired connection, this will ensure there is no interruption to firmware update. Bear in mind that a wireless connection may lose connection at any time which could result to an unusable router.I hope I have answered your question this time.
I want to know how to turn off the fire wall on the router. I don't remember the router password or how to find it.
If you don't remember the password it sounds like it may be possible you did not change the defaults on your router when you set it up. Google the manufacturer and default password. Should be plenty to point you in right direction. If you did set up a more secure user and password. The information you find in the search should get you what you need to reset router to factory settings and start over. Depending on the router How to turn FW off could vary. If it's a home router I'd suggest leaving it on and adding sites you may be having difficulty with to trusted sites. Reset instructions should be as easy as a second search. Either way you should be able to navigate to your routers firewall settings on the console once you can log in.
Jan 15, 2018 | The Computers & Internet
I don't know how to reset password for d-link DIR-625
Section 1 - Product OverviewHardware OverviewConnectionsUSB Connect a USB 1.1 or 2.0 flash drive to configure the wireless settings using WCN.Reset Pressing the Reset button restores the router to its original factory default settings.LAN Ports (1-4) Connect Ethernet devices such as computers, switches, and hubs.Internet Port The auto MDI/MDIX Internet port is the connection for the Ethernet cable to the cable or DSL modem.Power Receptor Receptor for the supplied power adapter.D-Link DIR-65 User Manual
If you don't know it you can check our list of default router and modem password list here.
If you have changed it and don't remember it you may have to reset your device to factory default using the reset button on most routers.
Sep 23, 2011 | D-Link DIR-625 (790069292637) Wireless...
Router kicks me off the internet after 50 minutes.
1.Ensure your router is secure if not you will want to secure your router in case someone else is stealing your internet to do that copy and paste link inside your browser.
http://vectrosecurity.com/content/view/49/26/
2.Powercycle your equipment ( Unplug power wait 15 seconds then plug back in)
3.Update Firmware to do that open your browser in the address bar type 192.168.1.1 then hit enter
find Firmware Update and update your Firmware.
4.Tether your connection (Plug Ethernet Cord directly into computer bypass router)Ensure that it is the router that is disconnecting you.If internet disconnects after being tethered it is an issue with your network adapter and you will need to take your computer to manufacture or local tech.
5.If known router issue reset your router to do that you will need to press and hold the reset button located on the back of the router for 15 seconds or until router resets, "Remember by resetting your router will reset to default settings you will want to secure your router again copy and paste web address and follow on screen instructions. Good Luck
Feb 19, 2011 | Linksys Wireless-G WRT54G Router
I am unable to connect my nextbook to my wireless network. I get the message that I am using the wrong password even though I am using the pword I thought I programmed in.....how do I check the pword?
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
There a great article at General Router Setup.
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Jan 21, 2011 | Linksys Wireless-G WRT54G Router
I am looking for my wep key, I got directed to the router site by typing in 192.168.1.1 like everyone on the internet suggests. When prompted to enter my Username and Password, I have used every...
Some routers have a RESET button that will reset the router back to the factory defaults. If you provide me with the make and model of your router, then I can give you the exact details on how to restore the router back to the factory defaults.
Nov 18, 2010 | Computers & Internet
I can't remember by password and can't open 192.168.2.1 any suggestion
by default it has No Password, however if you cant remember the password you can reset the router to its factory default just press and hold the small reset button at the back of the router usin a pen or a paperclip for 5-10 secs. Just remember if you do it all the save settins on the router will be back to default
Jul 30, 2010 | Belkin My Essential (ME1004-R) Wireless...
I lost my wrt350n rooter password. Are there way ...
think you need to reset the router and reconfigure it . There is a small reset button on the router. Press and hold it for 30 seconds. Remember if you reset the router, you will lose all the router settings and you will need to reconfigure it . Follow link to reset linksys router
May 21, 2010 | Linksys WRT350N Wireless Router
I forgot my password. Can you assist?
In the worst case if u really do not remember your password, then the best way is to reset your router to it factory default configuration setting. To do this, you must use the Default Reset button on the rear panel of the router:
1) Press and hold the Default Reset button until the power light blinks on (about 10 seconds).
2) Release the Default Reset button and wait for the router to reboot.
If the router fails to restart or the power light continues to blink or turns solid amber, the unit
may be defective.
YBC (/\)
Oct 02, 2009 | NetGear MR814 Wireless Router
Wrt54g router, default pword not working?
I had this issue and did not work untill I downloaded the software provided by linksys see if you download it and may work for you as we need to go step by step to fix the issue or you can get it from linksys too at: http://www.linksysbycisco.com/US/en/products/WRT54GL
Let me know if that work for you and please do not forget to rate the service so we can improve on it…
Sep 15, 2009 | Linksys Wireless-G WRT54GS Router...
Forgotten network key to log on to secured wireless g router
Password recovery isn't really possible. Pushing the rest button in the back for a few seconds will reset the router to factory defaults. You will need to reset all the wireless security and such so best to do this with a pc connected directly to it. Default IP for it if you have changed it is 192.168.2.1.
Dec 26, 2008 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Computers & Internet Logo
Alun Cox
David Payne
David Payne
