Question about Homelite Plumbing
How does one oil squeaky hinges on a security door (in front of the primary house door) since the two halves of the hinge is inaccessible?
    Guru:
  • 479 Answers
Are hinges totally inaccessible even using WD40 aerosol with with straw attachment?
Posted on Sep 04, 2010
How to stop a squeaky door
Spray a little wet type contact cleaner or WD40 onto the hinges.
Apr 25, 2014 | Vehicle Parts & Accessories
Tip
Fix Anything, House doors hinges, car door hinges ETC...
If you work around the house and around cars a lot like i do, next time you find a squeaky door, leave the WD-40 alone, go for the petroleum jelly instead, like vasoline. Remove one hingpin at a time, if they are eaisily removed and clean it, Then lightly coat it with the petroleum jelly, and reinstall. Move on and do the next one. If the pin can't be removed, brush it on right at the bushing or hinge split. It lasts a heck of a lot longer than oil and does not run. I did one of my most used doors, in my home, a few years ago. The thing is still as silent as a church mouse. My wife hates it, because she always thinks i am sneaking up on her. One of these days i will do the rest. I gave my gmc pickup door hinges the same treatment. It has 207,000 miles still on the original door hinge pins with very little wear.Good Luck. Bob.
on Jan 04, 2010 | GMC Sonoma Cars & Trucks
Canon a1100is camera battery door replacement
Kurt- I have successfully completed a d-i-y battery door replacement on my Canon A1100IS, and I make no claims about being an "expert." My training was watching u-tube videos of guys disassembling digital cameras (other models). Here's how to open the case on the A1100is, which is not really much different than opening the case on most any compact digital camera.
Using a size #0000 phillips screwdriver (Sears sells a set of 6 minis--slotted and phillips--for $10), I removed the nine screws from the side and bottom of the case plus one inside the mini-usb cover and the one inside the battery compartment.
Then, I gently worked the front and rear of the case apart (the top of the case halves have two snap clips that hold them together. Unlike some cameras, the A1100IS does not have any flexible cable straps between its front and rear covers.
With the case halves removed, I then used a tweezers to move the straight end of the hinge spring out of its original place next to the tripod socket. That released spring pressure on the hinge and I could then easily remove the hinge pin with the tweezers.
Then, it's simply a matter of placing the replacement door's hinge/spring combo in the proper location and inserting the hinge pin to hold it there. I purchased a new door from Canon for $8.42 plus shipping). Then, I used the tweezers to position the straight hinge spring end in the slot next to the tripod socket.
The only thing left was to wipe my fingerprints off of the LCD screen and then gently replace the front and rear case halves--snapping the case's top together and then replacing the nine screws.
Feb 26, 2012 | Canon PowerShot A1100IS 12.1 MP Digital...
I have preloaded the replacement hinge, but it appears that to remove the old hinge it must be unloaded. If that is true, how do you load the new hinge while it is on the door?
Ovens come in many varieties including freestanding units and stacked models that are inserted into a wall. Kitchen oven units that get a lot of use or are getting old may have problems develop, such as a loose or squeaky door which may require replacing the hinges. You can replace the hinges on the door to your oven by first removing the door from the rest of the oven.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderate Instructions Things You'll Need:
  • Screwdriver
  1. Step 1 Open the oven door and examine the hinges to see how the they are secured to the door. Some oven doors slide into the hinge assembly or have a locking mechanism that secures the door to a latch on the main unit.
  2. Step 2 Remove the door from the oven by disengaging the locking mechanism and then pull the oven door out. You may need to release a catch on the door or remove a pin from a hole in the hinge.
  3. Step 3 Place the door on a flat surface such as a table or the floor.
  4. Step 4 Remove the screws that hold the sections of the door together to access the hinges.
  5. Step 5 Remove the hinges from the door. The hinges may be attached to the door with screws or they may be held in place when the door sections are tightened or secured.
  6. Step 6 Insert the new hinges into the door and secure them with the screwdriver or place the section of door back on. Tighten all of the screws securing the sections together.
  7. Step 7 Place the oven door back into place by sliding it on the same way that it came off.
Regards
Iversh
Jul 24, 2010 | Ovens
Sqeaky fridge door hinge after we replaced the camber on the bottom hinge.
If the door is lined up well,maybe a little vegetable oil on a Q Tip put on the squeaky part will help. Just a suggsetion.
Wayne
May 24, 2010 | Amana SXD524VW Side by Side Refrigerator
How do we fit a new hinge to a Hotpoint WM64P washing machine
Remove the wire clamp that secures the door seal to the front of the washer.
Pull the seal of the front. and double it back inside the washer.
Undo the 2 screws that secure the door hinge to the front of the cabinet, keeping hold of the hinge support plate behind the cabinet front.
Remove the door, and undo all the scews that hold the 2 halves of the door together, then prise apart the the 2 halves..
Replace the door hinge.
Reassemble in reverse order.
Please rate my solution.
Thanks.
Nov 24, 2009 | Hotpoint Washing Machines
Fit a new door hinge
Remove the wire clamp securing rubber seal to front of washer, pull seal of front of washer, this will give you clear access to tjhe door hinge, ondo the 2 screws securing the door hinge, remove door ,and seperate the 2 door halves by removing the screws securing it together
Replace with new hinge, fit back in reverse order.
Thanks.
Nov 12, 2009 | Creda W120VW Front Load Washer
How do I fix a squeaky car door?
Some good old WD40 would take that nosie away or you can use soe motor oil on the henge. I hope this helps.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 09, 2009 | CRL Fixed "All Glass Look" Window-Side and...
Broken door hinge replacement on Hotpoint Ultima
Remove all the screws securing the 2 door halves together, and gently prize apart the two halves with a screwdriver or similar, be careful not to drop the door glass.. You will probably be better off removing the door from the front of the m/c altogether.
Replace broken parts as req'd.
Plz rate my solution
Thanks.
Dec 27, 2008 | Hotpoint Ultima WD72 Front Load...
Fixing of door hinge?
undo screws holding both halves of the door togethet then hinge can be removed. hinge is just held onto the cabinet with a couple of screws
Aug 14, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Plumbing Logo
61 people viewed this question
Top Homelite Plumbing Experts
DROPNDEAL
DROPNDEAL
richie46
Gil Shultz
Are you a Homelite Plumbing Expert? Answer questions, earn points and help others
