Question about Xerox Phaser 8500N Printer
I keep getting error code 08,035,42:21723 on my 8500 xerox printer any sugestions?
  • 2072 Answers
SOURCE: Maintenance kit for Xerox 8500
Contact the company that you purchased the maintenance kit from.
They should have the solution or send you a replacement.
I know of no way to change the Xerox printer to match up with a non Xerox maintenance kit. They would not set the machine up to accept non Xerox products since that voids warranties.
Posted on Jan 15, 2008
  • 7 Answers
SOURCE: error code 09.036.44:38950
09,03x 35 = Cyan 36 = Magenta 37 = Yellow 38 = Black The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Posted on Jun 10, 2009
wrinaldo
  • 185 Answers
SOURCE: Xerox Phaser 8500 error code 07010.43:24708
The most dependable fix for this is to replace the Process Motor 127K53240 and 2 camshafts, 008K02160 and 020K14800. Yes, you need all 3 parts.
This one is so common that it follows this solution 80-90% of the time
You may need help realigning everything properly afterwards.
Posted on Mar 16, 2010
indus3
  • 212 Answers
SOURCE: xerox workcentre pro 5225 exrror code 026-714
the Xerox error code 026-714 means that the printer cannot access a remote proxy-server. if the printer has been configured to use this remote proxy instead of your local one (or none at all), none of the mentioned network functionalities will work supposedly.
Posted on Apr 20, 2010
SOURCE: Printer Error Fuser Temp. in xerox 3100mfp
SISODIYA COMPUTERS "I AM SOLVE THE PROBLEM FUSER TEMP ERROR "
BUTTON FAST PRESS STEP BY STEP
LET'S START
PREES- MENU BUTTON
* BUTTON(THIS IS STAR BUTTON)
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
^ BUTTON(THIS UP ARROW BUTTON)
OK BUTTON
YOU LAST BUTTON PRESS OK AND POWER "OFF" AND WAIT UNTIL 15 MINUTE AND PRINTER START PROMBLEM IS SOLVE FUSER TEMP
Posted on Jul 04, 2010
LET'S START
PREES- MENU BUTTON
# BUTTON
1 BUTTON
OK BUTTON
STOP BUTTON
MENU BUTTON
# BUTTON
OK BUTTON
Mar 12, 2010 | Xerox Phaser 3100MFP/S Laser Printer
Error code 10-356
Hi
10-356 code i pws mode
remplace the fuser
Feb 09, 2010 | Xerox DocuColor 12 Printer
Help me for error code u4 for xerox 5921
The U4 codes for Xerox machines are for the fuser (heat roller) unit. It's rarely something that you can fix yourself I'm afraid.. Sometimes it pops up from overwork and powering off the machine allows it to cool down but if it keeps coming back you need to get it checked out properly..
Oct 05, 2009 | Xerox Office Equipment & Supplies
Printer Error 13,327.42.16752
It Sounds like its a bad printhead but run these trouble shooting steps first.
Troubleshooting Procedure for 13,264 to 13,327 Error Code (Printhead)
Step Questions and Actions Yes No
1 Check that the ambient room temperature is
within specifications (
Is the room too cold or too hot?
Go to Step 2.
2 Ensure ground integrity
Are all components grounded properly?
Go to Step 3. Resolve
ground
integrity.
3 Run the Printhead Reservoir Temperature
test.
Did the test pass?
Go to Step 4. Replace the
Printhead.
4 Check and reseat all wiring to the Printhead.
Did this correct the problem?
Complete. Replace the
Printhead.
Mar 27, 2009 | Xerox Phaser 8500/DN Printer
E7-03 error code on work center xe88 xerox
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Xerox WorkCentre XE88 Laser Printer
Xerox 8550 Error message 19,003.48:121016
19,003.48 Scale and offset voltage error too large. Something is wrong with the Electronics Module or Wave Amplifier.
that is pretty straight forward. More then likely the elsctronics module has failed. Wave amplifier is pretty unlikely.
If you do not have a maintenance agreement or under warranty, that is a very expensive module to replace.
Check @ 1-800-835-6100 to see if you are under warranty or have coverage.
Apr 22, 2008 | Xerox Phaser 8550DX Laser Printer
Xerox Phaser 6250DP sensor not cleaning
Is there a specific code coming up? That can make it easier to pinpoint the exact problem.
Apr 19, 2008 | Xerox Phaser 6250DP Laser Printer
Error code sc 202
This code is a problem with your machine polygon motor it is defective or the cable running to it is defective , it is quite a big job getting to that motor so i sugest you get a profesional to fix that up for you .
Jan 02, 2008 | Ricoh CL4000DN Laser Printer
Xerox Phaser 8500N Printer Logo
244 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
