Question about Duke 59-E4Z Electric Single Oven
Hi, the elements on my duke e101-e 240v single phase convection oven keep going out every 3 to six months...is there any other reason why they would go out so often?
  • 106 Answers
Check that the elements are high quality, dont use cheap elements, also replace all the elements and all are working, do not leave the door open while heating for along time. Do not power cold water on them while hot to clean let them cool down gradually.make sure the termina conection to are not loose during replacement. swicth off when you dont need to use for a long
Posted on Jul 29, 2010
What causes a duke E101 convection oven to not cook evenly?
If it's getting hot, but it isn't cooking as fast as normal, your convection blower/fan may be out. If you can hear the fan running, but the oven isn't getting hot enough, then you most likely have a heat element or thermostat problem.
Fan and blower problems tend to be a bit more common with convection ovens.
Jul 19, 2014 | Duke E101E E Series Single Convection Oven...
Electric Phases for Hobart Oven
you must understand this : your electric oven must be indicate if it is a single phase( use 3 wires for 230 2 hot wires + 1 Neutral see the diagram like dryer? you must sure about this. Normally any appliance for home are single phase NOT 3 phase.
2) If you electric oven, say 3 PHASES( use 4 WIRES, 3 hot wires+1 Neutral wires) this for industrial application +comercial 270266c5-a0ad-44dc-9f40-e963255d47f5.jpgNOT for home
However if you system is 3 phase you must need to install 3phase transformer.ba1c9d4d-85e3-4744-8ce5-2f25c6e34ad3.jpg
Jul 18, 2013 | Hobart HEC501-240V Electric Oven
Wich is the power supply 120v, 208 1 phasse or 208v 3 phase.
Most Baxter BXA ovens have separate power supplies, usually 120v for the controls and lights, a 120v output on a circuit breaker for the roof fan, and a 208VAC 3 phase supply for your convection motor. Older Baxter ovens may have a 3 phase service disconnect inside the electrical/burner compartment, if I recall correctly the BXA models do not and the only way to shut it off is via the 3 pole breaker at the service panel.
Feb 04, 2011 | Baxter BXA2G Stainless Steel Gas Single...
How do you rewire a 3phase hobart convection oven into a single phase
Here is your answer :
From 3 phase con you took just one phase of this 3 phases and a blue vire and earth wire you should use allso! for the safety against electrick shock,
I hope this will help you
Sep 23, 2010 | Ovens
Have had 4 Neff oven elements in 2 years, why does this keep happening ? B14241 single oven element keeps blowing, grill and light are fine, any ideas please ? is it time for a new oven ?
If you are not fitting genuine
elements, this is probably the reason they are failing so quickly.
You will pay a lot more for the genuine article, but they will last a lot longer.
Also make sure the fan is working o/k, as this can cause premature element failure.
please rate my solution.
Thanks.
Feb 07, 2010 | Neff B1421 Electric Single Oven
Duke Convection Oven won't heat past 250 degrees
Why should the cooker burn that hot, when you can cook most things at a max 220Celsius
Sep 27, 2009 | Duke 59-E4Z Electric Single Oven
Need to change oven from 440 3 phase to 220 single phase hobart cn90 oven
It can be done with a transformer, 480/ 240 single phase transformer to get the lower voltage. Then the oven will require some wiring changes to get all the elements and controls connected to two hot wires instead of three. The transformed will be sized to the wattage rating of the oven. This is a only basic description of what needs to take place.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 05, 2009 | Hobart Ovens
Problem with duke 613 commercial oven
http://www.4emweb.com/search.asp
try this web site. I found a list of wiring diagrams here..If you have a problem getting there, let me know and I will give steps as to how.
Good luck.
May 23, 2009 | Duke 613-E1V Electric Single Oven
Vulcan vfbi2 flashbake oven change from 3 to single phase
Are you sure it says that in the manual? I have a single phase. Look at the plate on the motor on the back. If it is 3 phase, forget about changing it over.
Charles
Aug 16, 2008 | Ovens
Duke 59-E4Z Electric Single Oven Logo
258 people viewed this question
Top Duke Ovens Experts
Dennis Boxerman
Raymond Richards
Raymond Richards
Andrew Taylor
Andrew Taylor
Are you a Duke Oven Expert? Answer questions, earn points and help others
