Question about Brother HL 1850 Laser Printer
Brother hl 1850 Laser Printer show message sost.gr.fus kit 1ac .....do you know what does that mean? Thank You Very Much ..
SOURCE: How do you clean the drum?
Brother had me take a tissue and wipe the drum. You can spin it with the gear on the left had side of the drum. Then they had me slide the blue tab 30 times back and forth.
Also take a soft cloth and clean the lens on the inside of the printer. First take out the drum unit. The lens in toward the back.
Posted on Mar 11, 2008
SOURCE: Paper jam with Brother HL-2030 laser printer
Being a retired electronics technician, I located and downloaded a copy of the service manual. Then proceeded to hunt for the reason why the Paper LED was staying on. I put the printer into the Production diagnoses mode, then by process of alimination opened and closed each panel and cheack each sensor switch one at a time. At which time it was apparent the problem was the rear door sensor. So I started to disassemble the printer getting instructions from the Service manaul, as most electronic equipement there is a sequence process to accompliah this. and once I found that the method of the rear door sensor operated I found the bracket was not in the right position. I put the sensor bar back into it's proper position and put the printer back to normal opperateing mode, I found my problem was solved. So I reassembled the unit and plugged it back into the compter ran a couple of test sheets and cleaned and aligned the printer head(s) made a few adjustment and everything was back to normal.
I must say that locating the Service Manual was a feat, but worth every cent I paid for it which was $9 USD. Personally i think all service manuals should be available for all Brother products for a fee, then a large number of problems can be fixed by the owners without much bother to Brother.
I ahve two of these printers and would still purchase a Brother colour printers, my next purchase is going to be a Brother color laser printer. Out of all the printers i've used on my computers I like the brother the best.
Posted on Mar 22, 2008
  • 13433 Answers
SOURCE: where can I get brother hl-2030 LASER PRINTER DRIVER
Hey,
The brother drivers and software require for the machine is available at
http://www.brother.com/E-ftp/info/index.html
Let me know if you need anything else.
Thanks,
Ekse
Posted on Mar 05, 2009
SOURCE: Brother HL-5270DN PF Kit Problem
I found the answer in another group, from Sunshine3240:
Open the front cover and leave open while completing the following steps:
Turn the printer off.
Hold the 'go' button while turning the printer on. All panel lights should be on.
Release the 'go' button.
Press the 'go' button 2 times.
Pause.
Press the 'go' button 5 times.
The toner light should be off.
The paper light should be on.
Close cover. The ready light should be the only light on.
Posted on Mar 13, 2009
  • 526 Answers
SOURCE: Brother HL-1440 LASER PRINTER requires ''Service Call A''.
currently, the error you have is not a service errorl, ready and alarm blink means that you have either a paper jam, no paper, or a paper misfeed.
do you get this error only when you try to print?
according to the service manual the lights can not alternate in blinking.
Posted on May 31, 2009
HL-5250 report shows fuser and laser life at 0% and PF kit 1 at 12%
The fuser is a separate component to the drum and toner in this printer. It has a much longer life than them but will run out eventually. Sadly a fuser unit is not a commercially available consumable for this printer either. I would recommend contatcing a printer technicain or Brother directly for a quote on replacing this part.
Apr 12, 2013 | Brother HL 5250DN Laser Printer
The message on the printer brother hl 1870n is replace pf kit 1 whats the meaning and what i must do
Replace Kit1 means Paper feeding kit..You may contact technician to do this job for you or you may download this link http://www.freeprintermanuals.com/PM/Brother%20HL-1850,%201870n%20Service%20Manual.pdf as your guide on how to do it, it is on chapter 4 3.3..
Nov 15, 2010 | Brother HL 1870N Laser Printer
Comes up with replace Laser
That error means that the laser scanner assembly needs to be replaced.
I can tell you the cost of the laser unit will be at least $320.00 + labor.
Thank you and please rate this message.
Jun 18, 2010 | Brother HL 7050 Laser Printer
Brother 4040CN
This message will appear if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one
May 21, 2010 | Brother HL-4040CN Laser Printer
Brother HL-1670n failing to feed paper.
I am facing problem for my "Brother HL- 1670N" printer with error E52.
Please help me out!
rj_rrohanjag@yahoo.co.in
Nov 04, 2009 | Brother HL 1670N Laser Printer
Where is tray one?
I reported the same problem and decided to check one last time before I scrapped the printer. I pulled out Tray 1 (the bottom (large capacity tray) to really check closely. I discovered that there seemed to be a space between the end of the paper and the printer tray. I simply squeezed the space closed and NOW IT WORKS! I keep kicking myself for being dumb.
Jul 11, 2008 | Brother HL 1850 Laser Printer
RESETTING FUSER LIFE ON BROTHER HL5140 PRINTER
How to reset the pf-kit message on a brother hl-5140.
May 17, 2008 | Brother HL 5140 Laser Printer
Feb 27, 2008 | Brother HL 1850 Laser Printer
E50 error
E50 is fuser code, it has blown the heat lamp or thermal fuse. the best solution is to replace the fusing unit. let me know if this helps
Nov 15, 2007 | Brother HL 1850 Laser Printer
Brother HL 1850 Laser Printer Logo
41 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
