Question about Garmin Nuvi 255 GPS Receiver
Garmin Nuvi is plugged into the electrical outlet in my car. It appears that it is not having a good electrical connection because nothing comes up on the screen like it is charging. Unsure if it is dead, broken, or just having a simple, technical issue.
  • 1,514 Answers
If the lighter socket is working ok then it may be the fuse in the charger plug that's gone. It can be replaced by unscrewing the silver ring at the end of the plug and removing the fuse. A replacement fuse should be available from garmin dealers.
Posted on Jul 29, 2010
HOw do you charge it?
This unit comes with a charger (AC). There is alxo a car charger. Both have a USB connecter that plugs into the side of your unit.
Sep 20, 2011 | Garmin nuvi 350 GPS Receiver
Don't have a manual. Charging in electrical outlet at home and don;t know how long to charge for. Plug in shows a red and green lite, both on and I have been charging for over 4 hours. Comments
Most garmin nuvi satnavs take 4 hours to charge with a mains charger or a car charger. It takes 8 hours with a computer. There's a batter indicator on the screen that shows WHERE TO and VIEW MAP. It will probably only appear when the charger is disconnected if it's the same as other garmin nuvis.
You can get the manual in Adobe Reader format from http://static.garmincdn.com/pumac/nuvi680_OwnersManual.pdf
Jun 14, 2011 | Garmin Nuvi 680 GPS Receiver
Garmin 765t can charge garmin with usb port, however, once garmin is connected to vehicle outlet, garmin will not charge and looses full charge within 30 minutes. fuse is good in vehicle, and works on...
It's most likely that the fuse in the plug of the charger lead has blown. There's a ring at the top of the charger plug. Unscrew this and the plug comes apart. You'll see the fuse inside. Be careful not to lose any parts.
Sep 27, 2010 | Garmin nuvi 765T GPS Receiver
When I turn on my Nuvi 1300 the Garmin logo appears. But after that, nothing happens. It appears that the unit freezes up Thanks, Curtis
A Garmin Nuvi 1300 that won't start, freezes, or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Jan 06, 2010 | Garmin nuvi 1300 Car GPS Receiver
Plugged device into car outlet. Device comes on, shows Garmin name and then shuts off and does nothing more. Prior to this happening screen displayed "battery low".
DC power will not properly charge the battery. It is possibly damaged. Change i. Preferably charge it via AC before using on DC.
But change battery....
Jul 05, 2009 | Garmin nuvi 205W GPS Receiver
Garmin nuvi 5000 wont turn on. I can plug up the usb up to the computer and the screen shows garmin logo with a gps connected to a computer like its charging. But when i press the power button weather it...
Your nuvi 5000 does NOT have a internal battery and that means that you cannot operate it unless it is connected to a 12 volt power source. Connecting it to your computer via USB allows you to install map updates, check for firmware updates, etc, but you will not be able to use it as a gps while it is connected to the computer. There is nothing wrong with your gps.
To use your gps in the home you need to purchase a 12 volt adapter, there are several types, plug the adapter into your wall outlet and connect your gps to it. If you can sit near a window it will help in picking up the satellite signal. Just keep in mind that you cannot connect the 12 volt power supply and use the usb cable at the same time. Enjoy your gps.
Jun 11, 2009 | Garmin nuvi® 5000 Car GPS Receiver
Garmin nuvi 200 appears dead
hit the reset button on the bottom
Nov 29, 2008 | Garmin nuvi 200W GPS Receiver
Garmin NUVI 660 power problem.
To charge a nuvi, use one of the following methods:
  1. Connect the nuvi to the suction cup mount and the vehicle power cable.
  2. Connect the USB cable to the nuvi and the computer. The computer will charge the nuvi as long as the computer is on. However, the unit will be in Mass Storage Mode and normal operation is not possible.
  3. Connect the AC power cable and the nuvi to a wall outlet.
Please note: All of the nuvi series will come with a suction cup mount and vehicle power cable to charge the nuvi. However, only some of the nuvi models will come with an AC power cable and/or USB cable. If they did not come with the nuvi, they would be optional cables and would be a separate purchase. Garmin only recommends using an AC power charge that is purchased from Garmin. Third party power cables may not charge the nuvi. These cables may be purchased from Garmin or Garmin's dealers.
Oct 11, 2008 | Garmin Nuvi 660 GPS Receiver
Can I find a copy of the Garmin Nuvi 350T manual online please?
Yes. There are 3 ways to charge the Nuvi. Computer USB cable, 120VAC transformer wall plugin, and the cigarette lighter DC 12V plug for your car.
May 24, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 255 GPS Receiver Logo
110 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
