Question about Car Audio & Video
I have a 1992 pontac grand am.actually my girfriend,her steering column has alot of play,vertically.it is equiped with tilt steering,i tried locking the tilt,but did not work
    President:
  • 2,309 Answers
There are 4 bolts in the column holdin the tilt head on, sometimes they come loose, you will have to dissassemble the column to repair, be warned its a tricky job!!!!
Posted on Jul 29, 2010
Steering column feels loose on 1999 grand marquis
Here's a company that has a description of how to rebuildthe upper portion of a Ford steering column (for a small fee). They are broken down into step by stepdetailed instructions with pictures. Although the example is for a 2000 Mustang,the column is identical to yours (tilt and non tilt use the same housing) http://www.steeringcolumnservices.com/steering-column-repair-how-to-instructions/ford/upper-housing-bearings%20replacement-instructions.phpI hope these instructionshelp you.
Aug 21, 2011 | 1992 Mercury Grand Marquis
We are ttrying to remove the ignition tumbbler on a 92 pontiac grand am can you give us any tips
Hi!!
Here are the steps to follow in order to remove and replace the ignition lock. Also I'm including a diagram of the Ignition Lock for easier component identification.
  • Disconnect the negative battery cable.
  • Remove the AIR BAG fuse.
  • Remove the left side insulator panel.
  • Disengage the two yellow 2-way SIR connectors.
  • Remove the tilt lever, if equipped.
  • Remove the upper and lower steering column trim covers.
  • Insert the key in the lock and turn it to the ON position.
  • Remove the lock cylinder by pushing against the locking button on the back of the bearing/housing assembly, and pulling outward.
To install:
  • Install he new lock cylinder into the housing. Gently push the lock cylinder into place while rotating counterclockwise.
  • Install the upper and lower column covers.
  • Install the tilt lever, if equipped.
  • Engage the two yellow 2-way SIR connectors.
  • Install the left side insulator panel.
  • Install the AIR BAG fuse.
  • Connect the negative battery cable.
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 03, 2010 | 1992 Pontiac Grand Am
How do I change the ignition switch in my 93 plymouth van?
FIRST OF ALL, TURN OFF RADIO,DISCONNECT NEGATIVE BATTERY CABLE. IF EQUIPPED WITH TILT STEERING COLUMN,REMOVE TILT LEVER.CAREFULLY REMOVE THE UPPER AND LOWER STEERING COLUMN COVERS. REMOVE THE 3 TAMPER PROOF TORX IGNITION SWITCH MOUNTING SCREWS USING SNAP ON TOOL TTXR15A2 OR EQUIVALENT. GENTLY PULL THE SWITCH AWAY FROM THE COLUMN AND REMOVE THE 2 ELECTRICAL CONNECTORS FROM THE IGNITION SWITCH. WITH THE KEY IN THE LOCK POSITION, DEPRESS THE KEY CYLINDER RETAINING PIN FLUSH WITH THE KEY CYLINDER SURFACE. ROTATE THE KEY CLOCKWISE TO THE OFF POSITION THE KEY CYLINDER SHOULD NOW BE UNSEATED. ROTATE THE KEY CYLINDER COUNTER CLOCKWISE BACK TO THE LOCK POSITION, AND REMOVE THE LOCK CYLINDER. ( TO INSTALL ) CONNECT THE ELECTRICAL CONNECTORS TO THE IGNITION SWITCH. BE SURE THE CONNECTORS ARE SECURELY LOCKED IN PLACE. MOUNT THE IGNITION SWITCH TO THE COLUMN 3 SCREWS FOR VECHICLES WITH THE TILT STEERING COLUMN THE SHIFTER MUST BE IN THE PARK POSITION AND THE PARK LOCK DOWEL PIN AND THE COLUMN LOCK FLAG MUST BE INDEXED BEFORE THE SWITCH IS INSTALLED. PLACE SHIFTER IN THE PARK POSITION. PLACE THE IGNITION SWITCH IN THE LOCK POSITION. THE SWITCH IS IN THE LOCK POSITION WHEN THE STEERING COLUMN LOCK FLAG IS PARALLEL TO THE IGNITION SWITCH TERMINALS. POSITION THE PARK LOCK DOWEL PIN OF THE IGNITION SWITCH SO IT ENGAGES THE STEERING COLUMN PARK LOCK SLIDER LINKAGE. APPLY A LIGHT COATING OF GREASE TO THE PARK LOCK DOWEL PIN AND THE COLUMN LOCK FLAG. POSITION THE IGNITION SWITCH AGAINST THE LOCK HOUSING OPENING ON THE STEERING COLUMN. BE SURE THE SWITCH PARK LOCK DOWEL PIN ENTERS THE SLOT IN THE PARK LOCK SLIDER LINKAGE INSTALL THE RETAINING SCREW AND BRACKET. TORQUE THE SCREW TO 26 INCH LBS. INSTALL THE STEERING COLUMN COVERS AND THE TILT LEVER IF REMOVED. WITH THE KEY CYLINDER AND THE IGNITION IN THE LOCK POSITION INSTALL THE KEY CYLINDER INTO THE SWITCH UNTIL IT BOTTOMS. RECONNECT THE NEGATIVE BATTERY CABLE AND THE CHECK THE IGNITION SWITCH FOR PROPER OPERATION OF HALO LIGHT SHIFT LOCK IF EQUIPPED AND COLUMN LOCK.ALSO CHECK FOR PROPER OPERATION OF THE IGNITION SWITCH ACCESSORY, LOCK OFF, RUN AND START FUNCTIONS.
Sep 18, 2010 | 1993 Plymouth Voyager
How do i remove the steering column cover to get at the ignition tumbler on a 1993 dodge dakota
CAUTION Disconnect and isolate the negative (ground) battery cable. This will disable the air bag system. Failure to disconnect the battery could result in accidental deployment and possible personal injury. Allow the system capacitor to discharge for two minutes then begin air bag system component removal. To install:
  1. Engage the electrical connectors to the ignition switch and make sure the switch locking tabs are fully seated.
  2. Before attaching the ignition switch to a tilt steering column, the transmission shifter must be in the PARK position. Also the park lock dowel pin and the column lock flag must be properly indexed before installing the switch as follows:
    1. Place the transmission shifter in the PARK position
    2. Place the ignition switch in the LOCK position. The switch is in the lock position when the column lock flag is parallel to the ignition switch terminals.
    3. Position the ignition switch park lock dowel pin so it will engage the steering column park lock slider linkage.
    4. Apply a light coating of grease to the column lock flag and the park lock dowel pin.
  3. Place the ignition switch against the lock housing opening on the steering column. Ensure that the ignition switch park lock dowel pin enters the slot in the park lock slider linkage in the steering column.
  4. Install the retaining bracket and ignition switch mounting screws, then tighten the screws to 22-30 inch lbs. (3-4 Nm).
  5. If the vehicle is equipped with a tilt steering column, install the tilt lever.
  6. With the key cylinder and the ignition switch in the LOCK position, insert the key cylinder into the ignition switch until it bottoms.
  7. Insert the ignition key into the lock cylinder. While pushing the key cylinder in toward the ignition switch, rotate the ignition key until the end of travel.
  8. Install the retaining screw into the bracket and lock cylinder. Tighten the screw to 22-30 inch lbs. (3-4 Nm).
  9. Install the steering column covers, then the tilt lever, if equipped.
  10. Connect the negative battery cable.
  11. Check for proper operation.
Jul 30, 2010 | 1993 Dodge Dakota
Diagram on to change turn signal arm on 1994 chevy cavalier , do u have to pull the sterring wheel
1991-94 Cavalier
See Figure 5
This procedure covers removal and installation of the headlamp, headlamp dimmer switch, turn signal and hazard switches, as well as the cruise control switch.
  1. If equipped, disable the SIR system. For details, please refer to the procedure located in of this repair guide.
0900c1528003bf08.jpg enlarge_icon.gif enlarge_tooltip.gif Fig. Fig. 5: View of the steering column showing the turn signal switch location
  1. If not already done, disconnect the negative battery cable.
  2. Unfasten the horn pad, then remove the steering wheel. For details, please refer to the procedure earlier in this section.
If necessary, using locking pliers with a piece of rubber (such as a spark plug boot) between the jaws to help prevent damage to the tilt lever during removal.
  1. If equipped, remove the tilt lever from the steering column by grasping the lever firmly and twisting counterclockwise, while pulling it from the column.
  2. Remove the upper and lower steering column covers.
  3. Remove the dampener assembly, then unfasten and remove the switch assembly from the vehicle.
To install:
  1. Position and secure the switch assembly.
  2. Install the dampener and the upper and lower steering column covers.
  3. If equipped, attach the tilt lever to the column.
  4. Install the steering wheel, then fasten the horn pad.
  5. If equipped, enable the SIR system, as outlined in of this repair guide.
  6. Connect the negative battery cable.
Nov 15, 2009 | 1994 Chevrolet Cavalier
How hard is it to change the Ignition Key Lock Cylinder? Do I need to take off the Steering wheel or does the guts just come out from the Steering Col with a pin, or something?
this is the oldest info I have. should be similar
Section 11-05: Steering Column Switches 1994 Town Car, Crown Victoria/Grand Marquis. Workshop Manual
REMOVAL AND INSTALLATION Ignition Switch Removal
  1. Disconnect battery ground cable. Remove the upper steering column shroud by removing the four or five self-tapping screws. Remove tilt steering column lock lever (if so equipped).
  1. Remove lower steering column shroud.
  1. Disconnect the ignition switch electrical connector.
  1. Rotate ignition switch lock cylinder to the RUN position.
  1. Remove the two screws retaining ignition switch.
  1. Disengage the ignition switch from the actuator.
Installation
NOTE: A new replacement ignition switch assembly will be set in the RUN position as received.
  1. Adjust the ignition switch by sliding the carrier to the ignition switch RUN position.
  1. Check to ensure that the ignition switch lock cylinder is in the RUN position. The RUN position is achieved by rotating the ignition switch lock cylinder approximately 90 degrees from the LOCK position.
  1. Install the ignition switch into the actuator. It may be necessary to move the ignition switch slightly back and forth to align the ignition switch mounting holes with the lock cylinder housing threaded holes.
  1. Install retaining screws. Tighten to 5.6-7.9 Nm (50-69 lb-in).
  1. Connect electrical connector to ignition switch.
  1. Connect battery ground cable. Check ignition switch for proper function, including START and ACC positions. Also, make certain that the column is in the LOCK position.
  1. Install upper steering column shroud.
  1. Install the lower steering column shroud and tilt steering column lock lever (if so equipped).
Nov 06, 2009 | 1992 Lincoln Town Car
My father is outside now trying to pop out the ignition lock to my 1996 Mazda B2300 to replace it. And a piece of it broke off inside of the terminal that the ignition goes into. What and how do we need to...
this model the colum has a split plastic shell that come apart screws are in some holes philups screwdriver or torx driver#15 plastic will come apart and u can access the ingnition switch
Jul 01, 2009 | Mazda B2300 Cars & Trucks
Loose steering wheel, 1989 Jeep Grand Wagoneer (FSJ)
it sounds like all you need to do is as follows, remove the steering wheel and behind it inside the column you will find a couple of screws or bolts that hold the tilt steering assembly together, they have most likely come loose and just need to be retightened , I would recomend that when you have the bolts out that before you reinstall them you put on some kind of thread locker (ie) lock tite. this should solve the problem
Feb 09, 2009 | 1988 Jeep Grand Wagoneer
Steering column removal procedures on a 1994 grand am manual trans with tilt steering.
  1. Remove Air Bag Disconnect battery ground cable and remove left instrument panel sound insulator, lower trim panel or duct assembly, and steering column collar, as equipped.
  2. If column is to be disassembled, remove horn contact pad and steering wheel
  3. Push back seal to expose flexible coupling, then remove coupling pinch bolt.
  4. Remove lower column support bracket bolt, then the upper bracket to instrument panel support bolts and lower column.
  5. Disconnect column electrical connectors and shift indicator cable, if equipped.
  6. Disconnect shift cable at actuator and housing holder, then remove steering column.
Dec 03, 2008 | 1994 Pontiac Grand Am
Car Audio & Video Logo
35 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
