Question about Panasonic DP-8020E Black and White Copier
I have a Panasonic DP-8020E with a consant wrench light on. I have recycled the power and it did nothing. It also is asking for paper have you ever heard of that?
  • Panasonic Expert
  • 1,326 Answers
The wrench being displayed is most likely a P.M. counter or a cleaning web counter. It will soon lock the copier up, till the counter is reset after replacing the parts that are needed. The copier maybe looking for paper in the manual feed tray. Try puting paper in the manual tray and see if the problem goes away. Good Luck
Posted on Jul 29, 2010
  • tnrtt Mar 06, 2011
    The 8020 doesn't have a cleaning web.
    You most likely have a broken paper lift motor. Common in this model
    Open the lift motor assy and you'll find a gear housing on the base cracked
  • paul mcarthur Nov 19, 2011
    its the fuser that locks out the machine go into service mode reset the fuser unit function 9 then 6 reset fuser then switch off on reboot you will here the paper feed start to lift comon faulty also reset the maintance counters in f7 for the spanner issue
Panasonic DP-8020 problem is E03-10
Posted on Sep 13, 2010
What to do when the Panasonic DP-8020E Black and White Copiergreen light and the red light are blinking at the same time on a
Hi
One of two possibilities. No 1 it could be that the paperlift motor is faulty and does not lift the paper tray uo, thus not detecting paper.
in this case you will need to contact your service agent for a repair or replacement.
Should the red spanner light also be lit it could mean that the fuser needs to be reset. This is done by going into the service mode : Press and hold function, original size and 3 buttons in that order. you should see F1 on the screen. press the 9 button and the start button. scroll down to ram initialize and press start. scroll down to LBP Fuser reset and press start. press 1 for yes. switch machine off wait and switch machine on again.
should the problem persist contact your service agent.
hope it helped
Aug 19, 2014 | Panasonic DP-8020E Black and White Copier
Dp8020 wrench icon flashing and add paper red light on
Press the "Function", "Original Size (Ledger/A3)", and "3" keys simultaneously to enter the Service
Mode.
3. Enter the password, if required and select "OK" button (default password is 000 or 0000).
4. Enter the Copy Service Mode F9-06 and select LBP Fuser reset. Execute by pressing the green start button.
5. restart the machine after completion
Sep 26, 2012 | Panasonic DP-8020E Black and White Copier
You have a problem in paper casette,mechanical problem.Remove the paper casette and verify jamed paper or paper sensor blocation.
Apr 12, 2012 | Panasonic DP-8020E Black and White Copier
Panasonic DP-8020E error message U15. What must we do?
Two weeks back change developer and toner powder. Now printing quality is very dull means printing quality is light
Jan 19, 2011 | Panasonic DP-8020E Black and White Copier
I want panasonic DP 8020E drive that runs on window 7
<a href="http://panasonic.net/pcc/support/mfp/dp-8020/index.html...FOLLOW">http://panasonic.net/pcc/support/mfp/dp-8020/index.html...FOLLOW</a> LEAD TO SITE IT HAS ALL YOU NEED ....LUCK A
Aug 27, 2010 | Panasonic DP-8020E Black and White Copier
Controlling printer behaviour when the correct tray runs out.
yep!
you can check it on printing preferences of your panasonic printer.
at the basic tab you will see a paper source section.
just select your desired paper tray and that's it.
it will print only from that tray.
Oct 11, 2009 | Panasonic DP-8020E Black and White Copier
Panasonic DP-8020E Black and White Copier Logo
598 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
