Question about Vizio VSB210WS Soundbar
My tv is an LG42 and I bought A vizio V200 soundbar.....i am using the red and white rca jacks and cannot get any sound to come out??? what's the problem???
2 Suggested Answers
brianw74
  • 400 Answers
SOURCE: how to connect a laptop 3.5mm audio out to a Vizio soundbar
You need a 1/8" stereo jack to rca....can get on at walmart....hook it from your headphone jack on your pc to the input on the sound bar....input 1 or 2....make sure you have the right iput selected for the sound bar and you should be in business
Posted on Mar 10, 2012
Testimonial: "yes!!!"
I bought a wireless soundbar to hook up to my Smart flat screen tv, and the manual does not state anything on how to really do it...too simplistic and not enough info for one.
Find the Audio Out connections on your TV and run the dual RCA cable (Red/White) to the Input RCA jacks on the back of the sound bar unit. You may have to go into your Audio or Sound menu on the TV and turn off the TV's speakers in order for the Audio out on the RCA output to turn on.
Feb 23, 2016 | Ematic ESB212 Wireless SoundBar with...
Having problems connecting using RCA cables (TV to Sound Bar) - No sound on Sound Bar
I assume by using your phone (cable rca to mini jack) the sounbar functions normal. Next time give more info like tv and soundbar make and model no and what connections are available on both components and if its input or output connections.
On the tv make sure the rca cable (tv to soundbar) is plug into the stereo output of the tv and not in a av input. Some tv's have a mini jack out and not rca. Some have a earphone socket which could also be used.
Some tv's only have a digital or optical output port. Iin basic sound work and can be connected with the following combinations .
Minijack to minijack
Minijack to rca
rca to rca
digital to digital
optical to optical
Oct 26, 2015 | RCA Televison & Video
How dd I connect my soundbar to my TV using the red and white RCA plugs
Hello. On the back of your TV look for RCA Audio jacks marked "Audio Out". Connect the cables from that to the RCA Audio Input on your sound bar. If your TV doesn't have the RCA outputs, see if it has an optical output. Your sound bar probably has an Optical Audio input. You would need to buy an optical cable for that.
Aug 15, 2015 | RCA Televison & Video
How to connect soundbar to a TV with a skybox
Connect the soundbar either to the TV's optical output. Or use an Optical to stereo phono/RCA converter box and then a pair of stereo phono cables (red & white) to the soundbar.
If it's a very basic soundbar with just a headphone jack input then you can go from the TV's headphone output instead.
As for the Sky box, just leave it connected via either an AV lead or better still a HDMI cable direct to the TV. The TV will send sound out to the soundbar.
Sep 04, 2014 | Televison & Video
I have an older home stereo system that i would like to connect to my vizio tv. I have a 3.5mm audio to rca plug. Coming out of the headphone jack on the tv, it plays no sound out of the system. Although...
I suspect what you're wanting to do is take the audio output from the TV and run it through your stereo system to leverage the large speakers. Correct?
I suggest using the RCA audio jacks (red and white pair) on the back of the TV. Most TV's still have these. Some are tied to a specific component, and some are general for all sound coming out of the TV. You connect this to the input RCA jacks on your stereo system.
The headphone jack on the TV could also work, but I suspect it may have a low level output. I don't understand how you say your MP3 player plays fine through the headphone jack, as that's an output, not an input. Unless there's some other jack?
Sep 22, 2013 | Vizio 29in Class LED 720p TV - LED TVs
Connecting an LG soundbar to non optical digital tv
I'm pretty sure your soundbar has more than 1 input. Check your manual. There probably is AUX input on soundbar and that will allow you to connect to TV, assuming that your TV has any audio out. It could be either white and red RCA connectors or headphone jack.
Mar 07, 2018 | LG Audio Players & Recorders
How to connect a laptop 3.5mm audio out to a Vizio soundbar
Mar 10, 2012 | Vizio VSB210WS Soundbar
I am trying to hook up the mvd2016 to a visio tv that is hooked to our cable converter box. I hooked it up, i have the tv but no sound.
your RCA jacks from the DVD player....should be connected to the Vizio a/v 1 in the back of TV (yellow to yellow, red & white to red & white)... now to view using the remote to TV switch to a/v (play a DVD, you should now have a picture and sound)
Dec 19, 2010 | Memorex MVD2016 DVD Player
To play laptop thru samsung tv I am attempting to play laptop movie thru tv. I have tried the rca y cable with 3.5 mm plug from headphones of laptop to red and white audio in on the samsung tv., no sound....
So you are connecting the laptop to the TV using VGA port of the TV, right? To get sound in the PC input mode, you need to use the PC audio input jack (green jack, mini 3.5mm jack) not the RED and White RCA audio input, they are for Composite Video AV inputs. That is how I have my laptop and TV setup to watch Netflix.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jun 16, 2010 | Samsung LN52A850 52 in. LCD HDTV
Tv soundbar with a 5.1 receiver
The Onkyo has a center channel pre-out that you can connect the sound bar to. How does the sound bar connect to the TV? Is it two rca jacks, 1 red and 1 white or black? What brand and model is the sound bar?
May 16, 2010 | Onkyo Tx-sr507 A/V Receiver
Vizio VSB210WS Soundbar Logo
106 people viewed this question
Top Vizio Audio Players & Recorders Experts
Marvin
Marvin
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Vizio Audio Player and Recorder Expert? Answer questions, earn points and help others
