Question about Diesel Case 1370,1470,1570 Tractor Piston & Sleeve
Engine RPM run away
Case 1370 (1977 or 1978 model year): Engine RPM run away. Using tractor in the field, the engine raced to full throttle (red line) and would not shut off. Had to put tractor in road gear and hold brakes to stop engine. Pulled tractor to the shop and tried to restart it later--same results. Does anyone know the cause? What to repair? (FYI: There were no gas fumes at either location.)
    New Friend:
  • 12 Answers
Govenor is bad!
Posted on Aug 22, 2017
    Top Expert:
  • Diesel Master
  • 52,162 Answers
Indicates governor failure
have an accredited professional diesel shop remove the fuel pump and do a complete overhaul and calibration on the pump and have the injectors done as well
2 Suggested Answers
jdlipscomb41
  • 157 Answers
SOURCE: 646 case tractor with 16hp onan engine if i hold
sounds like the fuel pump is bad or try cleaning the fuel filter and carbarator
Posted on Oct 26, 2009
3 cylinder perkins gas engine 1960-65 for massey ferguson 135 tractor
Without cranking it, can you take the air filter off and see the throttle plate move as the throttle is moved ?
If someone else cranks it, can you be at the carb and move the carb throttle directly at the carb and control the rpm ?
If so, check your throttle rod for slack, missing spring/connection, something broken.
Sounds like the carb has nothing stopping the throttle from being sucked full open.
Dec 09, 2017 | Cars & Trucks
Why doesn't it develop full rpm under load?
Hi Roger:
What kind of engine are we dealing with?
Maximum RPM is limited by the amount of load imposed on an engine. No load lets a 1 hp Briggs and Stratton scream at 6000 RPM when you bypass the governor, or your weedeater with no line sound like a ninja race bike. Add some load and they both slow way down.
So, reply as a comment to this post and we'll try to figure out what can be done for your circumstance.
Cheers.
Jan 03, 2016 | Cars & Trucks
I have a charging problem with JD L155c lawn tractor. The battery is new and the voltage to the battery is 12 volts. Not enough to charge the battery. How do I check the ac voltage & what should the...
There are several possible Mowers of the "L" 155 versions.
John Deere LA155 garden tractor lawn mower. These stopped being made in 2010 (they started production in 2009, and so enjoyed a run of 2 years on the assembly lines). The JD LA155 is powered by a Briggs and Stratton 2 cylinder, V twin engine. This engine is 0.656 liters (40 cubic inches) in size and produces 22 hp.
1998 - 2001 LT Series
John Deere LT155 Engine: Kohler 1-cyl gasoline
2006-2006 L155c, This series was produced only in 2006.
Briggs & Stratton gasoline, 2-cylinder air-cooled, 724 cc [44.2ci ], 25 hp
Model 445777-0168E Code 021125YC, these are the engine numbers from a 25 hp twin cylinder, B&S.
Notes on these engines from parts supplier ereplacementparts.com:
Briggs and Stratton 445777-0231-E1 Engine: The proper flywheel part number and/or the alternator magnet size will determine the alternator type or output.
This 25 hp engine has 3 different possible alternators, standard circuit, dual circuit, tri-circuit. I would need the exact engine model numbers in order to precisely answer your question. Often mower models have choices for the engine they come with. In this situation the engine model is more important than the model of the mower.
Testing an alternator is fairly simple; all you need is a multimeter for testing.
  1. Disconnect connector from stator.
  2. Set multimeter for AC volts.
  3. Attach RED test lead to either pin on stator side of stator connector. (On single wire leads, attach RED test lead to the single pin.)
  4. On two wire lead models, attach Black test lead to the other pin. On single wire stator connectors attach the Black test lead to the engine ground.
  5. Prepare the lawn tractor for engine start (set parking brake, blade off, etc). Start engine and run at full throttle.
  6. Check output. Output for engines of this general size run in the 30 to 50 volt range. For instance the B&S V twin 22 hp AC output at full throttle is 30 Volts minimum. Other B&S on these machines spec 40 Volt minimum.
If your voltages are not in the manufacturers range, or non-existent, your stator is partly shorted or completely burnt out (open circuit). Either way you have to replace it.
A. In the picture is a single lead stator connector.
B. In the picture is a two wire stator connector.
Mar 15, 2015 | Garden
Cub cadet tractor diesel filter plugged with nasty stuff, I have change the filter and it still wont start
First bleed it? Than you may have crack the lines hook to injectors
Oct 19, 2014 | Garden
How correct toro l/mower engine racing
Check the idling setting screw is not holding open the throttle butterfly common fault to fix if the engine races esp when no load is applied the idle throttlexpostion is to high thus the engine runs faster at idle turn the screw located on either the butterflyistelf so less screw threes is against the carb body this should start lowering the idle speed of the engine it should be around the 900 RPM approx for idling and top rev of 3500 at full throttle a rev counter is displaying a extra high rev count the it's the oil governed at fault or malfunctioning or sticking this will cause and engine to race badly to the point of engine destruction eventually
You may need to adjust the movement of the governing leavers etcetera best done by qualified servicing personnel a lawnmower mechanic etc
Aug 03, 2014 | Toro Garden
High idle
This can happen when extra air is entering the engine. If you have a vacuum leak the engine will race because it is like the throttle is open further than it actually is,
You can try using a water spray from an old spray bottle and when the engine is running, spray along the gaskets, vacuum lines, and switches until something changes your RPM. Then you would have found the leak,
Now on some engines a part called an ICS, or idle control solenoid is in the intake manifold and it has valving which can get stuck. Removing this part and cleaning with WD-40 can help. Use the Web to get a picture of the ICS for your year and model. Google with those terms to get helpful info.
Mar 26, 2014 | 1992 Mercury Grand Marquis
2005 neon hard brakes engine races
While your car is running.......pop the hood and find the throttle body. The throttle body is where your air filter tube/hose goes to the engine. Locate the throttle position sensor which should be on the side of the metal throttle body. This should be the item causing this. If you grab the plug that is on the sensor and wiggle it while the car is running then the engine should rev and act up if thats the problem. If not let me know and I can direct you further. Thanks.
Sep 13, 2012 | 2003 Dodge Neon
Hello when mowing i have to run full throtle to get blades to spin fast enough to cutt good 24 hp 46 inch cutt
You do not have a problem. Air cooled small engines are designed to be run at full throttle in order to mow correctly and to cool the engine properly. Running it as less than full throttle will cause the engine to overwork and possibly overheat thus shortening it's life. It will also not cut properly as you have found. The engine has a governor that prevents you from running it too fast. Run the engine at full throttle at all times when you are mowing which is the optimum speed for proper operation. You may think you are helping your engine by running it slower but in reality you are harming the engine. It is air cooled, not water cooled, and needs the revolutions in order to cool itself properly. Also use 100% synthetic oil in this air cooled engine for more protection. Change your oil/filter once a year or every 50 hours.
Apr 03, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I start the engine and it sputters at fast idle and then eventually shuts off.
I think that after you start the engine you need to move the throttle lever off what you are calling fast idle (which is full choke). Simply slide the throttle lever down until it smooths out and runs properly.
Oct 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John Deere LA145 B&S 22Horsepower engine starting and running
You may simply need a new fuel cap,vacuum in the tank will rob your fuel and stall it engine,try taking off the fuel cap and see how it runs.If this does not help you may need a new fuel pump,which runs off of crank case pressure and should take over from the choke once the tractor has started.
Jan 19, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Diesel Case 1370,1470,1570 Tractor Piston & Sleeve Logo
63 people viewed this question
Top Diesel Garden Experts
Dennis Key
Dennis Key
john h
Are you a Diesel Garden Expert? Answer questions, earn points and help others
