Question about Bosch 24 in. SHE44C05UC Stainless Steel Built-in Dishwasher
Our Bosch model SHE44CO dishwasher run cycle has progressively increased. It now runs twice as long as it once did. Help????
  • Bosch Master
  • 2,605 Answers
Based on your description I'd say the issue is with the control. Bosch has had a history of this exact problem I'm about to lay out for you and this is the first thing I'd be looking for if called out to service the unit with the symptoms you've described.
As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
My first suggestion would be calling in an authorized bosch servicer if that is an option for you and your budget however, If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.**
Hope this answer`s your question, let me know if I can assist you further.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
macmarkus :)
Posted on Jul 29, 2010
  • tinkermonger Feb 25, 2011
    I had this exact same problem and resoldering the relay fixed the problem. It's been running for over a year now with no more issues.
    Ray L
    Problem Solver:
  • 17 Answers
First...make sure you visit the Bosch dishwasher recall website as this model is under the recall with a faulty controller which may cause a fire! Check your model under http://microsites.boschappliances.com/safetyrecall/dishwasher/
then call 800.856.9226 to setup a recall repair appointment. We just found out about this recall and was never notified by Bosch even though we registered our unit after we purchased it...talk about poor customer service! Hope this helps!
Posted on Oct 18, 2010
Runs through cycle, but dishes and glasses do not dry, they are soaking wet.
10 Tips to Help the Dishwasher Run Better - Cleaning Tips ...
www.thekitchn.com/10-tips-to-make-yo...
Apartment Therapy's The KitchnFeb 24, 2014 - Well, we're here to help, with 10 tips for making your dishwasher run its best. ... loading up to help reduce particles stuck on dishes once the cycle is over. ...water to flash dry and not roll off your dishes, taking the ends of the dirty bits with it..... but can lead to damage, particularly of any glasses you put in the ...
[PDF]Dishwashers - Frequently Asked Questions ... - Bosch
www.bosch-home.com/Files/Bosch/In/in/Document/Bosch.pdf
this cycle the dishwasher dries the dishes. 3. ... dishes. During this time, you do notneed to be around the dishwasher as it ... Does it also dry the dishes after the wash?... You can put utensils that are made out of steel, ceramic, glass, plastic which is ...No, the dishwasher runs the whole washing programme automatically.
Why is My Dishwasher Not Drying the Dishes? ' Dr ...
Dec 03, 2015 | Dishwashers
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
How do i run a test / diagnostic mode for the bosch sge63e05uc (evolution series) dishwasher?
Are the instructions on how to run the diagnostic test listed in the manual? FYI, I couldn't run the test on my Bosch DW because it was just too broken. Over the years the dishwasher essentially fried its own circuit board with excessive heat, which I learned is a problem common to Bosch DW's. Bosch told me the lifespan of my model was 10 years; mine was 11 years old (but was repaired once or twice). I replaced it with a Miele; no problems yet after 4 1/2 months.
May 22, 2014 | Bosch 24 in. SHU53 Built-in Dishwasher
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch dishwasher starts, pumps, stops and says it's clean
We have the exact same problem with our Bosch SHE5AL06UC/05 dishwasher. Works great when it works, but we are increasingly having a hard time getting the wash cycle to start.
Apr 13, 2012 | Bosch SHE5AL06UC 24 in Builtin Dishwasher
I have a bosch she44co 5uc and I am not getting any water with the wash. All of the water going to the dishwasher is on and there are no obstructions.
Hi Brad, welcome to Fixya. What happens when you "start" a cycle, do you hear any sounds from the dishwasher at all ? You may have a faulty water inlet valve in the dishwasher, but I would first like to know if the unit comes on at all or even "calls" for water. I'll watch for your reply. macmarkus :)
Jun 21, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch SGS5332GB dishwasher. drain pump runs all the time
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Nov 06, 2017 | Bosch Dishwashers
Our dishwasher does not progress beyond the wach cycle to the rinse cycle. It will run for hours and still has soap in it.
I'm positive of this, but your dishwasher may qualify for a somewhat recent recall. Call bosch to see. If you can get it to drain manually and put into rinse and hold manually, but it won't progress on it's own, then it's the control board. Hope this helps.
Nov 28, 2009 | Bosch 24 in. SHE43C05UC Stainless Steel...
Model SHU43C06UC
hi there sounds like your dw is in flood protection remove the poliestirene float compleatly and make sure the lever that sits on top of it is in the down position, hope this is of some help.
pat no for new float is 165301
Nov 11, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHE44C05UC Stainless Steel Built-in Dishwasher Logo
623 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
