Question about Garden
WHATS THE BEST WAY TOO CHANGE BLADES ON A ZERO TURN BAD BOY MOWER?
5 Suggested Answers
  • 11 Answers
SOURCE: I have a craftsman zts 7500 zero turning radius 26
i going to assume that yr tractor does have the hydrolic p.t.o. that controls the drive and cutting mechanism's???... if so you might start with checking the hydrolic fluid in the resevior. or you might check into replacing the hydrolic p.t.o. pump , if you ran the tractor in heavy work without any hydrolic fluid in the p.t.o. pump the pump is probably burnt up. if so im sure you can beat the cost of a new pump by rebuilding it yrself with a kit.
Posted on Jun 24, 2009
pippall
  • 1486 Answers
SOURCE: my rzt 50 series cub cadet zero turn mower slows
The saftey wires wont cause it to slow down.Thats more of a fuel problem.Check the carb remove and clean the float chamber.Also check advance and ****** springs are still in good working order on carb.
Posted on Jul 06, 2009
SOURCE: Woods 6170 zero turn mower. The mower blades stop
MTD RH 125/92 mowing belt jumps off guide wheels when disengaging mower (even when really gentle disengaging). I understand there's an additional belt guide available from manufacturer - would that be any good?
Failing that can anyone advise?
Posted on Aug 10, 2009
SOURCE: Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Posted on Nov 24, 2010
How do you get the hub off to change the spindle seal? this is on a bad boy lawn mower 2300 series hydro gear, hydrolic driven zero turn mower?
Can you post a picture of the part you are trying to remove? Do you have a gear puller? It may be pressed on.
Aug 17, 2016 | Cars & Trucks
Blades want engage on bad boy zero turn
If the unit runs but the blades will not engage, means you have a safety switch bad. You will need to pull a wiring schematic and check the switches.
Jan 31, 2016 | Garden
Blades won't engage on bad boy zero turn
Do you have voltage going down to the electric clutch? Is the mower belt still in good condition and on all the pulleys?
If you need further help, reach me via phone at https://www.6ya.com/expert/john_73617967471ec7c4
How do i change the blades on a 42in zoom z turn
raise the front of the mower to gain access to the underside where the blades are, using the right size wrench undo the bolt or bolts that hold the blades on and remove them from the mower, replace the blades and tighten the bolts to the required torque, lower the mower to the ground and take it for a test run.
May 19, 2014 | Ariens Zoom 42 In 165 HP Briggs Stratton...
1250 woods zero turn mower
Wearing out a belt that fast must have a bad bearing or a misaligned pulley. Good luck.
Nov 28, 2017 | Garden
How do i change blades on the husqvarna zero turn mower model number LZ6127
Jack up your machine safely and unscrew the bolts holding the blades on..then reverse this order..
Aug 30, 2010 | Husqvarna Zero Turn Mower Z5426
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
721 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
