Home a/c intermittent during rain
A/c running well, then it rains .... and the inside unit and thermostat ok, but the outside unit continues to run and will not cycle off. Go to thermostat and use off switch ... nothing .... Must now go the the breaker box and turn off because outside unit still running. Just had a/c tech out and install new thermostat .... intermittent problems continues.
  • 674 Answers
You need to check the contactor. It sounds like the contacts may be getting close to the end of their usefulness and they are welding themselves closed. Check that and let me know what you find.
Posted on Jul 29, 2010
Why does my 2003 Mitsubshi Outlander misfire after a rain storm?
Check for water getting into electrical compnents.
Aug 30, 2014 | Cars & Trucks
My 2002 Toyota Celica fogs up and collects moisture on the windshield during or after a rain. Visibility is a major problem. Need help, this is truly unsafe.
Can be that your heater core or hose inside car is sometimes releasing alittle heat at the clamps. So long the inside of the floor is not wet or damp or car is not over heating. I would not worry about the heater to much inside unless this does not work...
Change the automatic climate control up or down to cooler or warmer i usually run it at least upto 10 or 20 degrees different than the outside anytime i drive mainly during rain or snow.. So if outside it is warmer means you need to be cooler and cooler means get warmer. Also If you don"t run that on a regular basis a quick Ac on and defroster front and back works well and generally fast.I really think that is all of your problem just get comfortable with your automatic climate setting. once in a while it may happen again only because of rapid temp. changing from outside air to inside air in your car..Rain X works really well for a couple weeks between apps.and saves wiperblades during raining times. Always drive safely and good luck 11_21_2011_5_34_27_pm.jpg
Aug 16, 2011 | 2002 Toyota Celica
I purchase a 1997 Salem camper trailer and just replaced the Duo therm 13,000 Unit BTU. Everything was good until it was time to connect the wires from the thermostat unit to the analog thermostat on the...
Pay attention to wires from control box itself at the ceiling assy. Sometimes they will use a different color from control box, to thermostat. For example: Green coming out of control box, is attached to a blue running to thermostat, so you would attach that blue, to "G" (fan) on thermostat. Match thermostat colors to what is at the control box originally, not what color they used to run it to thermostat from there. Most try to match them, but others don't. What model Ac unit, and what model of thermostat do you have?
Jul 30, 2010 | Dometic Rooftop RV Air Conditioner
Engine cuts out during heavy rains. This started happening a couple months ago during a heavy rain. As soon as the rain lets up (within mile or two) the engine settles down. Light to moderate rain does not...
If the check engine light is on have it scanned at Auto Zone to pin point the problem. If the check engine came on then went off it stored the code in the computer you can still pull it up.
Jun 07, 2010 | 2000 Ford Econoline
I HAD THE SAME PROBLEM BUT WITH AN ASTRO VAN. THE PROBLEM WAS WATER WAS GETTING INTO THE FUEL PUMP CONNECTOR UNDERNEATH THE VAN, NEXT TO THE FUEL TANK.THIS WAS CAUSING A SHORT, NOT BAD ENOUGH TO BLOW THE FUSE, BUT ENOUGH TO CAUSE THE PUMP TO SHUT DOWN. BEST WAY TO DUPLICATE THE PROBLEM IS TO FIND THE CONNECTOR AND SPRAY IT WITH WATER WHILE THE VAN IS RUNNING. ALSO DO A WIGGLE TEST, THIS IS DONE BY GRABBING THE HARNESS TO THE PUMP AND MOVING IT AROUND, IF YOU HAVE A LOOSE CONNECTOR OR A BAD WIRE THE VAN SHOULD SHUT OFF.
2004 Jeep rain sensing wipers continue to run regardless of setting or amount of rain
a couple of thoughts:
Has your windshield just been replaced?
The sensor is up by the rear view mirror, is it plugged in all the way?
Do you have the right size wiper blades on your vehicle? (too short of a blade misses the rain sensor and does not wipe it clean)
How good are your blades? ( as above, to turn off the rain sensor the blade needs to wipe it clean)
The rain sensor works by projecting multiple inferred beams to the inside of the windshield, like a prism, they reflect back to collectors. when there is a water droplet on the outside of the windshield it changes a beams trajectory and it misses the collector thust turning on the wipers.
(yes, this all happens in that little sensor up by the rear view mirror.)
check to make sure the wiper switch is in the right position.
also....I've seen rain sensors not work properly when the hood or doors are open.
hope this helps
Feb 01, 2010 | 2004 Jeep Grand Cherokee
98 Mercury Tracer starts missing and dies after 60 - 80 miles
U can go to any autozone, kragen or other chain auto parts stores and they will run the trouble code test for free, let me know what they find if anything, this also may be a fuel pressure problem
Mar 09, 2009 | 1998 Mercury Tracer
Rained on my new Onkyo - it wasn't plugged in tho!
No need for a repair shop. Just open the top (two big screws on each side and a few smaller ones in the back) Let it sit for another day that way and it'll be right as rain. Oops...poor choice of words.
Avoid the urge to touch the circuit boards on the inside. Static electricity could damage the circuits. Instead, put it next to a fan - or in a room with a ceiling fan.
When you're don, plug it in and enjoy your new stereo.
Peace.
Marco
Feb 06, 2009 | Onkyo TX-SR606 Receiver
Trane HVAC Unit
If your condenser blow air up through the top of the condenser and you are concern about rain water affecting the unit.
You can install a roof or rain hood about 4ft above the unit to keep the rain off, The unit must be able to blow air off without causing Hi head pressure to affect the unit, The condenser must breathe or desipate heat freely.
Tell me if your question answered or if it works for you.
Mar 31, 2008 | Heating & Cooling
RED SCREEN
Water damage irreversible - it might work sometimes
Oct 04, 2007 | SanDisk Sansa e200 MP3 Player
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
