Question about Home
Decina spa bath with electronic touch pad will not start pump, pump light does not come on when you push spa control, heat light comes on, power light is on
4 Suggested Answers
  • 105 Answers
SOURCE: whirlpool spa bath touchpad wiring
you need to acquire a wiring schematic from the manufacturer for your tub,....get all info you can think of i.e. model#, serial# name, etc. so when you reach a human on the phone, you can give them all of this required info they'll need to get you the right info you'll need to re-wire this thing,..good luck
Posted on Jan 31, 2010
SOURCE: Need parts for HoMedics BMAT-2 Bubble Spa
I'm missing the hose and now desperatly want to use Homedics BMat bubble Spa which is now currenlty not in stock. Can you sell the hose to me. 4189kv4r6yl._ss400_.jpg
Posted on Aug 12, 2010
  • 85 Answers
SOURCE: Monarch spa bathe control panel
call your maintenance personnel.
Posted on Feb 02, 2011
Control panel not responding
Your spa side touch pad/ topside control panel is failing. It is only a "Communicator" the buttons are shorting between them. This is usually the problem when symptoms are manifest like yours.
Jan 26, 2014 | Dream Maker Spas Pool & Spa
Lanark spa bath
Not really sure but it sounds like there is a sensor that may not be reading properly preventing the pump to turn on.
Rod @ US Parts Center
May 12, 2013 | Pool & Spa
Pump wont start, airswitch innop, can it be started manually
What you need is an Air Switch for a Bath Pump. There is a Parts Center with those.
These are latching air switches which interrupts the power source to the pump. When you push the air button on the lip of the bath tub it turns the pump on and push it again it will turn the pump off.
Rod
US Parts Center
888-521-6183
Mar 26, 2013 | Pool & Spa
Why won't the spa jets turn on when I touch the touch pad? The light will not turn on and there is no response when I touch or push on the pad anywhere.
Do you have the operating instructions?
It may be that your topside controls are locked. Check your instruction manual, it should hopefully tell you how to unlock the controls.
Kind Regards,
Ian, from http://hottub.synthasite.com
Jun 07, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Savannah Spa Sunset Dlx control pad doesn't respond
What does it mean when the word SPA comes up on the control pad window and locking up the control pad.
May 23, 2010 | Aqua Pool & Spa
Whirlpool spa bath touchpad wiring
Dec 17, 2009 | Crane & Co Crane Plumbing 2386W Oval...
Spa wont heat
Check the pump make sure that it is getting power. If there is power to the pump and nothing is working then pump is bad. Also this could be your computer board is bad, a inline fuse. or the Jandy is bad
May 20, 2009 | Jandy Aqualink Rs4 One Touch Control...
One year old window heat pump unit will not power
Is it not coming on? If it isn't, is the control pad lighting up? Is any of the electronics lighting up? If not, then the control board is probably bad. You will need to check voltages to the control board.
Apr 11, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Home Logo
344 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
