Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
In the last hour or so or may be longer the refrigerator and freezer have stopped cooling.....however, the lights are on and it appears there is power
  • hholla Jul 29, 2010
    Is there some kind of fuse that may have blown?
  • 4,070 Answers
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Posted on Jul 29, 2010
  • 5,081 Answers
Do you hear sound like compressor running inside?
  • 8 more comments
    However, I can't hear the compressor....
  • INDIRA KUMAR
    INDIRA KUMAR Jul 29, 2010
    Both the freezer and refrigerator section is not cooling, am i right?
  • INDIRA KUMAR
    No my dear friend it cant be fuse... The various causes can be
    Bad Defrost timer.
    Defective starting relay
    OR defective temperature control...
  • INDIRA KUMAR
    You have rated before we finished our conversation. so kindly reconsider the rating you have given..
  • INDIRA KUMAR
    If you want i can send you a manual on how to identify which is faulty and replace them...Kindly reconsider the rating you have given..
    I did not attempt to rate you....how do I reconsider. This is my first time.
    Can I get the manual you alluded to in your previous post?
  • INDIRA KUMAR
    Yes i can send the manual . Did you opt for further expert advcie?
    If you did so it means you are not happy with my service.Did you get a mail asking that if so please go and reconsider the rating there?
    No I did not get any such mail......If I accept your solution does it erase the rating?
  • INDIRA KUMAR
    Yes it will
Maytag French door refrigerator not cooling refrigerator.
There is a defrost coil and timer to control it, you will have to check those to see if they work, If you are unplugging it to defrost it would take hours to clear the ice.
Jan 20, 2014 | Whirlpool GX5FHTXT Bottom Freezer French...
The ice dispenser no longer operates and in the dark of night the light turns on and the dispenser flapper starts flapping wildly on its own adn making a loud grunting noise. Do we need an exorcist
Check your fan next to the compressor if it's running ,also check your evaporator fan if it's running.
If both fans are running and you still have ice built-up then you may have a refrigerant leak
Dec 21, 2017 | Maytag MZD2766GES Side by Side...
When my fridge runs for a few hours it stops cooling although the lights will be on.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 02, 2011 | Refrigerators
It appears my refridgerator motor has stopped. The light works in the fridge, but it appears the motor has stopped. I had the freezer draw opened for a while to fix a draw - what should I do >
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Jan 23, 2011 | Viking Professional Series VCBB36 Bottom...
Freezer and refrigerator no longer cooling
Sounds like the start relay,capacitor and overload need replaced. If you would like my assistance let me know, Thank You, Sea Breeze
Nov 27, 2009 | Refrigerators
Fridge is no longer cooling. ER where the
Sounds like the FF(Freezer Fan) is wearing out or is worn out. This assembly supplies the circulation for the freezer as well as the refrigerator. When is slows down or stops the circulation of cold air to the refrigerator is the first thing that is effected. The minimum cost to replace this assembly is around $300.00
Jul 10, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
REFRIGERATOR MOTOR CONTINUES TO RUN AND WATER IS LEAKING.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
u
Mar 22, 2009 | Whirlpool ET8CHEXSQ Dryer
Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Aug 27, 2008 | Magic Chef Refrigerators
Error Code ER FF
FF is your freezer fan. You may need to defrost the unit.
Feb 28, 2017 | LG French Door Cabinet Depth Refrigerator...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
76 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
