Question about HP Pavilion Slimline S3123W Desktop PC - REFURBISHED
DVD tray will not go in
The CD/DVD tray will not go back in on my HP Pavillion Slim Line. What can I do to make it retract or go back in. Nothing appears to be stuck inside there.
  • per24 Jul 29, 2010
    Will not go in when power is off and I cannot push it in when its on. It just stays out no matter if using the PC or not.
    Just tried turning off machine and that will not work either.
    Problem Solver:
  • 12 Answers
To verify there is nothing stuck in your drive, turn off your computer and try manually pushing the tray in GENTLY and feel if there is something blocking the tray moving. If there is nothing preventing the tray from moving manually push the tray in - start your computer and try it again. Use the eject function in windows explorer and try the retract button again. If teh button will not work try pushing the tray in manually again. Once the tray starts moving in it should automatically retract the rest of the way. If the unit will not retract on it's own by either method then the drive should be replaced.
Posted on Jul 29, 2010
  • OldGoat97 Jul 29, 2010
    I am sorry but this unit is beyond repair - the retract / eject mechanism is either jammed or broken. If you feel ambitious you can remove the drive and open it up to see if there is an object inside the drive blocking the mechanism.
    Good Luck - BTW - with the low cost of CD drives these days DO NOT PAY TO HAVE THE DRIVE REPAIRED
I have LG GP40NB40 Slim Dvd write, i installed LG writer with it own CD to my HP Pavillion. But wont play DVDs...WHY?
did you remove all of the original software as this can cause a software problem. you will need to remove the new software and the old software.then shut down the computer then. let it start up. turn back off again install the dvd writer then turn back on now should load the proper driver for the dvd rom. then install the software.
Sep 28, 2013 | Computers & Internet
How to change cd rw in hp pavilion 523n computer
If you can't find the button to eject the CD tray:
Open the Start Menu and go to My Computer (or Computer if you're on Vista or Windows 7). Right-click on your CD drive, and then click on Eject. The tray should eject. When you change the CD and still can't find the button, you should just be able to lightly tap the front of the tray, and it will retract back into your PC.
Jul 06, 2011 | HP Computers & Internet
Dvd writer & cd writer tray lights up but will not open on HP pavillion model no t760 uk
Go into My Computer and right click your DVD writer/CD Drive and click eject.
Mar 05, 2011 | HP Pavilion a1700n PC Desktop
HP Pavillion a6200n PC cd not working, but the DVD does work. When I put a cd in, it will not work. When I click on the drive, it asks me to insert a cd, it closes but does not play. The DVD works when I...
Your CD drive has an internal failure which is usually the laser head. It would be cheaper to replace the drive or use your DVD drive to read CD's then to have the laser head replaced in the CD drive. The disk tray motor system is not connected with the read write system in the drive and the tray ejecting or loading a disk is not an indication of the health of the drives logic system or laser head.
May 20, 2010 | Computers & Internet
My dvd will not eject on HP pavillion a1120n
You can manually eject the disk by inserting a straighten paper clip into a pinhole that is located in the front tray. Push the paper clip in until the tray pops out.
May 17, 2009 | HP Computers & Internet
Hp pavillion dv9000- cd/dvd rw drive not working
you have to send it back to hp to get it fixed, this is the second time mine had the same problem
May 10, 2009 | HP Pavillion DV9060US Notebook
I have a s3100n hp slim line pavillion and thru hp tech support was advised to do a system recovery. when i tryed to reboot my system some programs were missing and they hp said that i need the recovery...
You must go into the BIOS on boot up and choose to boot from CD-Rom instead of the hard drive. When you first turn on your machine and the HP comes up push F10 key to get into the BIOS. Look for boot priorities and put the CD/DVD Rom in the first boot position (directions on how to move these item up/down are at the bottom of the page)
Then your disks will be useful. Put one in and reboot. It should read you disc and follow instructions from there.
Hope this helps you, good luck
Apr 23, 2009 | HP Hewlett Packard Pavilion Slimline...
I need to reset the ram on a hp pavillion slimline but the cd tra
Just unscrew, remove the entire CD ROM, fix the RAM properly and while connecting the CD ROM ensure that all connections are snug tight...sodeep
Mar 19, 2009 | HP Pavilion Slimline S3123W Desktop PC -...
Cd/dvd drawer on Dell inspiron 531S will not go back in
It would be best to replace the drive unless you feel comfortable dissasembling it to clean out the gears that drive the tray. If you are able to look in the drive at all you might look to see if the "eye" popped up before the tray retracted all the way if so you might be able to manually push it back down and also just give a quick look at the exterior to see if the tray is caught up on anything and also look to see that it is moving in/out straght.
Dec 19, 2008 | Dell Inspiron 531S (DDCWGA1_5) PC Desktop
HP Pavilion Slimline S3123W Desktop PC - REFURBISHED Logo
186 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
