Ibico Pouchmaster (laminator)
I have a Ibico Pouchmaster 9 laminator and when i try to laminate something, it takes in the plastic through one end, but doesnt feed it back out the other end. I dont know what to do. Is it faulty?? or is somthing stuck inside it??
  • Anonymous Jun 09, 2008
    laminator paper stuck in laminator
SOURCE: ibico 2700 wide roll laminator
Mechanic service code number
Posted on Feb 12, 2008
SOURCE: ibico 2700 laminator
I need to replace the rollers on my IBICO 2700 laminator. I will need to order the new rollers can you help?
Posted on May 29, 2008
  • 199 Answers
SOURCE: Laminator
ok we think again
Posted on Jun 22, 2009
M2Tech1
  • 313 Answers
SOURCE: I was given a laminator but it does not have
the main way they work is that you have the laminate pouch into which you slide your paper then make sure that the pouch is put between the guides closed side first the machine will take a while to warm up after you have plugged it in when the green light is on push the pouch in slowly the motor should turn and feed the pouch in automatically.. the important thing is to make sutre the pouch is correct for the type of machine you have and that when feeeding in the pouch it goes in closed end first otherwise it could open and jam.. Good luck A>>
Posted on Jul 31, 2009
paulrelliott
  • 69 Answers
SOURCE: paper stuck in laminator reoccuring problem
try different paper it may be too thick!
Posted on Sep 22, 2009
How do we remove plastic laminate from our ceiling fan blades?
If the laminate is just a "protective shipping" laminate, you should be able to peel it of.. if its not that.. I would not try to remove it... it may cause the blades to de-laminate ..or other wise start to "fall apart".. and thats NOT something you want to happen in ceiling fan blades..at high RPM..
Aug 10, 2017 | Dryers
User manual for ibico pl-330 ic
http://office.manualsonline.com/support/other/laminator/laminator-manual-required-2292677
Oct 12, 2014 | Office Equipment & Supplies
Scotch Thermal Laminator not heating up.
well it sounds like you may have cut a wire or pull one somewhere. i would go ahead and take it apart carefully and check everything. may have unplugged something hopfully! let me know whwat happens!
Jan 31, 2014 | 3M TL902VP Scotch 9" Thermal Laminator...
What is a laminator?
A laminator is a tool used to plastic coat documents to protect them. Your social security card may have a laminate coating.
Jan 28, 2013 | Office Equipment & Supplies
A laminate and paper jam in a Gbc HeatSeal H425 Laminator
You need to loose the vertical plastic wall on the left side, and pull it up and to the left, only then you would be able to take pink rollers and metal piece away. Step by step do this (BTW, make pictures of each step if you think you will not be able to assemble it back) :
Download parts scheme here (if link is broken I can send you; write to ororeivis [at] g mail com):
http://www.gbcconnect.com/assets/docs/H425_PARTS_POUCH_LAMINATOR.pdf
Take the lid (3) off and hang it on the corner.
Next goes off (42) part.
Now focus on the left side. Take to the side part (30) with 7mm wrench. Then both parts (14) from both sides [4 in total]. Then both parts (2). Then take out screws that are holding this vertical plastic wall place. There is two screws from the outside of laminator in the bottom!
Then black roller (36) you lift up and take out by sliding to the side. Then two long black metal pieces.
Now you should be able to pull up and move to the left that vertical plastic wall on the left side of laminator. If not, try loosing some screws that are in this wall.
Be careful taking melted jammed stuff away from heating panel. Do not over-scratch it, as it is very sensitive.
floating cowboy
Jun 26, 2012 | Gbc HeatSeal H425 Laminator
Hi, Our Ibico IL19VT Laminator (A2) has paper jammed inside of it. There are no reverse mechanisms on the laminator. The only feasible method is to open the laminator up at this point, whether or not...
You can open this yourself but i recommend sending it for repair. If you decide to do it yourself here is how: turn the unit over and on the end with only one screw (not the power setting side) take it out using a Philips screwdriver. Next you will need size 3 and 4 hex bits. Use size 4 to undo the 4 hex screws. Hold the non power end and it should slide off. You will see four rollers two on each side of the heater element. Using the size 3 hex bit undo the 4 hex screws at the exposed end and lift up and out the 2 housing bits. Careful as these are made of plastic and break easy. Remove the offending material and then put everything back together.
Simples!
Aug 21, 2008 | Office Equipment & Supplies
Ibico 2700 laminator
Apr 24, 2008 | Office Equipment & Supplies
949 people viewed this question
jasbo
jasbo
