Question about Kenmore Washing Machines
Kenmore Series 80: Machine does not drain or spin at the spin cycle.
  • 5,081 Answers
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Courtesy:Js Rock a senior expert in fixya
Posted on Jul 29, 2010
My kenmore series 80 washing machine makes a clicking sound during the spin cycle.
Might be something lodged in the drain pipe on the drum, such as a coin or similar object.
Dec 20, 2011 | Kenmore Washing Machines
We have an 80 series washing machine that will go through all cycles until it is supposed to drain then nothing happens. It wont go any further .
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 29, 2011 | Kenmore Refrigerators
My kenmore 80 series washing machine will not always drain out on the spin cycle and sometimes when it does there is dirt in the tub under the clothes. why?
heatman101
Apr 02, 2011 | Washing Machines
Make sure there is voltage present to the motor when the cycle is ON>
If not the program controller is faulty, If yes the motor must be checked for errors.
Since both the drain and spin is not working the fault seems to be from the program controller as there is no output to the drain and motor.
So check the controller for the lack of output, try choosing a different program cycle to confirm..
Sep 27, 2010 | Kenmore Washing Machines
I have a Kenmore 80 series top load washer. It will not drain during spin cycle. If I run it through a second spin cycle it will usually drain. Any ideas
heatman101
Sep 18, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
Kenmore washing machine will not drain
Replace the timer.
This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
Mar 13, 2009 | Kenmore Washing Machines
Machine will wash but not spin or drain-Kenmore series 80
needs a new drain pump you can replace it easily by leaning the washer back at a 45 degree angle then right at the front panel you will see the 2 hoses hooked up on the drain pump there is a clip on top and bottom of it unclip them and slide the pump off the motor shaft then undo the hoses and do in reverse order to replace and please rate me
Jan 05, 2009 | Kenmore Washing Machines
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
138 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
