Question about Refrigerators
I have a kenmore coldspot 106.56666501 and the freezer coils keep freezing up. I have defrosted it with a hair dryer twice in the past six months. My guess is that I have to replace the defrost heater, but wanted confirmation before I do.
    President:
  • 1,891 Answers
You hit the nail on the head . if heater is ok then the defrost themo is bad or the timer . any of the 3 can cause a defrost problem . but heater is most common . mm
Posted on Jul 29, 2010
Freezer coils are freezing up and need to be defrosted evey few days with a hair dryer. It's a Kenmore model # 2539658011. What do I need to replace?
Refrigerators are sealed systems, most have no ports to recover refrigerant or perform service. The problem could be several things, the only really repairable problem could be the fan (if there is one) but most likely the problem is from either: the superheat metering device; the charge (amount of refrigerant present in the system) is low, indicating a leak; or the compressor is failing. It is probably more cost effective to replace the refrigerator rather than to repair it, especially if it is a standard residential type
Oct 01, 2012 | Kenmore Refrigerators
Kenmore coldspot refrigerator 10673183302, drain keeps freezing up even after complete manual defrost
most likely it is the heater un plug the heater coil and check coil with ohm meter
Nov 18, 2017 | Kenmore Refrigerators
We have Kenmore/Coldspot side by side model 106.44259401 Over the last few days the freezer has 'blizzard' conditons. Frost accumulating on top /sides/packages. Also appears the refridgerator side...
Sounds to me like your defrost heating element is shot. Unplug the refrigerator. Empty out the freezer take the screws off the back panel and remove panel. Defrost the cooling coils with a hair dryer. At the bottom behind the shield you will see a glass tube. Unplug it and bring it to your local app repair shop and let them match it up because making the phone call with your make and model doesnt always work but bring those numbers with you as well.There was some models made with single heating elements that had to work twice as hard to get the defrost job done so they burned out more often. Your repair store will probably have a new dual tube for ya. Hope this helps. Almost forgot..Make a temporary plug with a paper towel and stick it in the water drain just in case you drop a panel screw down the drain(not fun) good luck!
Jun 26, 2011 | Kenmore Side by Side Refrigerator
Kenmore Coldspot freezer too warm
Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
Hope this helpout......
Jul 28, 2010 | Kenmore Refrigerators
My evaperator keeps freezing solid every 3 months
No your problem is the defrost solenoid it is not make it's function well
Apr 14, 2010 | Maytag MBF2556HEW / MBF2556HEB /...
Freezer not defrosting
You got the right idea. your fridge have a deforst problem, and it can be cause by a number of items. 1. the timer, 2 the defrost temperature control. 3 the defrost element itself.
Before you use the hair dryer when there is ice forming in the back panel, try to turn the timer and see wheather you can set it to defrost cycle manually if you can then the timer need to be change. the 2 and 3 item is a bit more work for normal people to deal with, you better call in a serviceman and watch him how he handle it so you can try it yourself next time. God Bless
Jul 14, 2009 | Freezers
Our freezer keeps freezing up and it causes it to
If you tell me the model number found in locations in photo below I can help you.
Jul 13, 2009 | Refrigerators
Fridge and freezer not cold and frozen up
Can you remove the back panel inside the freezer and defrost the coils. Use a shop vac with the hose in the blow position instead of the vacuum position. And blow on the coils to defrost quickly. Hair dryers work also but prolonged use will burn up hair dryers. Now turn back on and see if the inside the freezer fan works. It should be running to keep the coils from freezing up. Also could be defrost timer. But this will be enough to get you going. Let me know how it goes. ken
Jan 12, 2009 | Samsung RS2630SH Side by Side Refrigerator
Kenmore Coldsport freezer drain repeated freezes
probably the easiest fix for this is install a drain probe to transfer heat from the defrost heater into the drain hole to prevent ice build up. take a peice of 10 or 12 guage solid copper wire and wrap one end around the defrost heater pretty tight and put the other end down in the drain line 2-4 inches.
Dec 15, 2007 | Refrigerators
Refrigerators Logo
307 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
