Question about GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black
The water dispenser stops flowing or is very slow. I still get ice with no problem. We had a service call some time ago. The guy used a heat gun to "thaw it out". It only last a short while. What can I try? Can I get a picture of the water supply tube?
    President:
  • 1,891 Answers
If using a het gun corrected the problem before / the ck the freezer tempt it may be to low . adjust to 0 to 5 deg in freezer . if you still have problem we sometimes run the tube through anothe larger tube.. this helps freezing . mm
Posted on Jul 29, 2010
Water dispenser running slowly
Hello Cynthia;
My name is Peter. I am a retired field service refrigeration technician.
You have a water pressure problem. You need at least 60 PSI water pressure to open the solenoid valves. I suspect you are getting small ice cubes.
If you have well water you are not going to get the pressure for fully dispenser flow.
I have experienced bad water filters. One time our techs received a large shipment of bad water filters. Remove the water filter and test the water dispenser.
With low water pressure you may not want to use a water filter
Dec 08, 2014 | LG LFXS24623S 24.0 cu. ft. French Door...
We have a Pure Source Plus model, no manual as it came with the house we purchased a year ago. Things worked fine then. A few months ago the water pressure lowered and temp changed(became warmer) for the...
the ice maker slows as the tempt in freezer gets warmer . icw cream get softer ect . ck for ice build up in back of freezer and the evap fan motor may be running to slow causing poor air flow . ck these first . mm
Aug 10, 2010 | Frigidaire FRS3R5EMB Side by Side...
Water dispenser doesn't work
Replace the water valve on the refrigerator. The valve solenoid is stuck open causing water to flow freely. This should fix both issues with icemaker fill tube freezing and water dispensing.
May 05, 2017 | Whirlpool ED5SHAXM Side by Side...
The ice maker was turned off for a few weeks and when I turned it back on, the water wouldn't feed the tray. So no ice. I put some water into it manually and it made the ice dropped it into the bucket but...
Have you checked to see if the water inlet inside the freezer compartment at the ice maker is frozen? This is pretty common.
You can thaw it out with a hair dryer (carefully), then cycle the arm, wait for a little while and see if the ice tray fills.
Next thing to check would be the water line and fill valve, but try the above first.
Dec 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
Icemaker/water dispenser not working.
Just had to defrost the water tank inside the fridge for a few minutes. Using a waterproof heating pad with extension cord did the trick. Even a fridge needs a warm blanket from time to time.
Oct 21, 2009 | Jenn-Air JFC2089HE French Door...
About a week ago, ice making slowed way down.
changed the water filter. cost $43 for a new one. crazy.
Jun 17, 2009 | Aspen Refrigerators
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Ice Maker not working at all
I have the same refrigerator and was having a very similar problem. My water would dispense just fine, but the ice maker suddenly began making partial cubes of ice, then quit making ice, than started again before finally stopping again. At first I thought it was because the fill tube coming from the back of the frig was frozen, but after clearing it the problem persisted. I traced the problem back to the valve at the back right corner of the frig. I disconnected the power inputs and water lines, then took the valve apart. On the side that feeds the ice maker there is a small washer inside of the valve with a very small hole that only allows a limited amount of water flow through it. A small pieced of rubber had broken loose from another section of the valve an was clogging this small hole. I cleaned the entire valve system and reassembled it. The ice maker is now back in action!!! The fill tube going into the tray had frozen because of the small trickle of water that was going into it was not sufficient to keep it from freezing. Make sure this is still clear before turning everything back on. I hope this helps several of you out there, as this seems to be a common problem.
Dec 06, 2006 | KitchenAid Superba Architect KSCS25INSS...
GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black Logo
140 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
