Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
Delonghi magnifica - I've turned machine on and self diagnosis has appeared and then it shuts down. What does this mean. ? Thanks
5 Suggested Answers
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Posted on Jul 08, 2010
  • 6 Answers
SOURCE: delonghi magnifica, wont turn on!!\r\nwas going
I have the same problem.
Posted on Nov 08, 2010
  • 1833 Answers
SOURCE: delonghi Railto 4500 - I've
According to you your coffee maker doesn't turn on. So first try to
check the machine for any loose connection to the lines. If there is
no fault then reset the machine. after that plugged it out for two min
the plugged it again and turn it on. this may solve your problem.
Posted on Mar 29, 2011
  • 3235 Answers
SOURCE: Delonghi magnifica - I've turned machine on and self diagnosis has appeared and then it shuts down. What does this mean. ? Thanks
Broke... is what it means...!
(a model number would have gotten a closer look to parts sources (but you can look yourself on eBay, amazon... and a bunch of parts houses I'll post at the bottom (Bing search)).
Hello Buzzy Grunthal,
As exotic as our comic book understanding of artificial intelligence is... a program is actually about as EXOTIC as a ladder.
You have a control board with some wired or sequenced primary logic... that is failing at a very early stage (a rung is missing).
If you are handy with a screw driver... My first suggestion
on WATER APPLIANCES is to have a look-see for water contamination... then a cold solder joint... progressing immediately to a WHOLE board replacement...
Corrosion can easily be cleaned off with a tiny bit of vinegar... followed by some anti-corrosion compound (I use WHITE lithium grease, very sparingly). A simple soft pencil "lead" could also be used.
Cold solder... if found...
the real treatment is to clean & re-solder...
If you are not GREAT with an iron... save your old board and look for a new one (you can do more damage than good).
Guessing about $60 to $260 depending on your model & board.
Hope this helps.
https://www.bing.com/search?q=delonghi+magnifica+control+board&form=EDGEAR&qs=PF&cvid=347b2c8595214fef89095ad4b7329d49&pq=delonghi+magnifica+control+board&PC=DCTE
Posted on Oct 28, 2016
Hope this helps.
Oct 28, 2016 | DeLonghi Coffee Makers & Espresso Machines
Internal water pipes leaking on my Delonghi magnifica. Where can I buy the pipes? Will I be able to replace the pipes myself?
DeLonghi Magnifica water leak problem - YouTube
? 2:37
https://www.youtube.com/watch?v=_mNGPs79ajY
Feb 5, 2011 - Uploaded by shellway2005
My DeLonghi Magnifica ESAM3300 is not making shots. Wateris instead coming out of the front bottom via a ...Missing: pipes
DeLonghi Magnifica leaking water pipe Questions ... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > DeLonghi
DeLonghi Magnifica coffee makers & espresso machines leaking water pipe related questions and answers. ... Delonghi Magnifica My steam arm drips when I make coffee. ... Not sure if water is leaking from water tank or internal water line.
DeLonghi Magnifica leaking water Questions & Answers ...
Order DeLonghi Parts‎
www.ereplacementparts.com/DeLonghiadvertiser rating
Buy DeLonghi Parts.
Fastest Shipping - Low Prices.
Jan 07, 2016 | DeLonghi Coffee Makers & Espresso Machines
Is my coffee maker fixable?
go to the manufactures web site.
go to www.ask.com
type Delonghi Magnifica coffee makers self diagnosis than shuts off
see if any one else has had that problem
you could also look under www.youtube.com/coffee_maker_self_diagnosis_than_shuts_off
Mar 25, 2015 | DeLonghi Magnifica Coffee Makers &...
Delonghi magnifica door won't stay shut
I had this problem. The door didn't snap when I shut it and it would pop open and stop the brewing. It was an easy 5 minute fix.
I removed the drip tray and the black plastic bin where the spent coffee grounds are expelled. With a flashlight I could clearly see 1/4" to 1/2" caked coffee grinds lining the back of the cabinet at its base. This residue kept the bin from seating correctly. Because the bin wasn't all the way back into the cabinet it put pressure on the door and kept it from latching. I cleaned out the buildup with a small spatula and a brush and the door latched perfectly again.
Apr 01, 2012 | DeLonghi Magnifica 3300 Espresso Machine
Lost the instructions / booklet and cannot recall how to clean / descale my DeLonghi ( Magnifica Model) Coffee Machine. Are you able to assist? Many thanks
fill water right to line ... turn unit on ....when its ready to use push and hold the descale button for approx 5 secs the lights wer cups are should stay on.... now place descaler in water ......put a larg container under steam pipe..... turn vaule open fully... it will run for approx 10 secs then stop for at least 15 min...until water runs out ... when light for water comes on fill tank up again with clean water place back into machine and it will flush through until empty .... when light for water comes on again ..job done ..turn vaulve to shut. ///
Feb 06, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
1,098 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
