Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
Operating manual operating instructions for Raypak R337a pool heater
  • 760 Answers
Posted on Jul 29, 2010
Testimonial: "thanks for the info."
What diameter size galvanized pipe do i use for installing my new Raypak 266,000 btu gas heater?
Refer to the owners manual as the pipe size is dependent upon the length of run the pipe will be, the pressure your fuel system operates at and the fuel you'll be using. If you do not have the manual you can find a copy here. Refer to page 20.
John
Jun 05, 2011 | Raypak 2100 Pool Heater Gas 266000 BTU'...
How do i install my raypak pool heater Model
Yours is an in ground pool, right???
Break the return line between the filter output and the pool. That is where your heater goes. If you have a chlorinator ... it should be between the heater output and the pool (chlorine is the last thing to go into the water before the pool). You will need a fuel line of appropriate size for the heater and either 110 or 220 volts of power. Your heater shold have a safety built in that prevents its operation unless there is water pressure.
Jul 05, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak pool heater is making a knocking noise
low water flow check manual bypass in heat exchange if spring broke letting too much water bypass and overheating water in unit also see if pump ok and filters
Jun 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
RayPak 2100 series digital pool heater Code "EOL".
press the mode button until the display reads "off". Remove the four screws holding the control cover on. Swing panel down so that the back of the board is visible. Press the mode button until "RESfl" appear. Press and hold both "up" and "down" buttons for 5-7 seconds until three dashes appear (---). This resets the fault history and clears any stored faults.
Sep 05, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Have a 010253F replcement kit for a Raypak model 335a heater. Need wiring instructions.
Go to the RayPak web site. They have a pdf of the instructions for replacing the board with what you have.
Sep 04, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak pool heater RP2100 error message CLK
you are in fireman switch mode,which means pool timer is ready to shut down pump. clk shuts down heater approx 15 minutes before pump shuts down. this lets heater cool down before pump shuts off.
Jul 05, 2009 | Raypak 130,000 BTU Propane Gas Pool...
Where is the pilot light on Raypak versa pool heater, i need to light it manually?
In side the front on the lower right is a long 3/8" wide tube about 5 inches long...you'll need a special lighter with an extended wick.
May 18, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
439 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
