To further clarify my prior problem, the TV was plugged in, but powered off. I am assuming I need to power on before adjusting the voltage but I don't want to accidentally fry anything. General tips would be appreciated.
  • 6,993 Answers
your TV is having a power problem. The power supply board is defective that's why the TV won't power up. Its receiving power but it cannot transfer the current to the necessary part of the TV because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the TV might not come on.
If you know about TV repairers, I would suggest that you open the TV and read the power board/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
I wish you good luck.
Posted on Aug 06, 2010
SEIKI SE322FS LED TV won't turn on, but power light is on
From your description there are blown electrolytic capacitors on the power supply board,a visual inspection will show bulged burst or leaky caps.I am assuming there is no sound or pic and no visible light from the screen.I must assume you have no prior electrical service knowledge and warn of possible high voltages being present on the primary side of the power supply at the 400volt filter cap
also be sure to unplug the set before removing the back pannel
keep safe
Len...
Oct 13, 2014 | SEIKI Digital SE322FS 32" LED TV 1366x768,...
I havea27" Westinghouse LTV-27w2 LCD TV. I am with AT&T Uverse along with internet service. I believe I have a power supply problem. There is absolutely no power to my TV. Everthing else is...
Do you know how to use a meter? If so the first thing to do is take the back off and check the AC fuse, if this is blown replace it and see if the set works. If it blows again you have a short in the primary power supply and replacement of the power board will be required. If the ac fuse is good you will need to check all the plugs coming out of the power supply for voltage, if you have voltage coming out then you could have a bad main board or power supply. If you have no voltage coming out and the fuse is good then replacing the power supply is required. Let me know what you find and I can help you further!
Tim Nolan
Sep 23, 2008 | Televison & Video
Picture one day, no picture the next
try resting the device again for few hours n then try
Aug 19, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Video boards
Have you checked it using a different input device such as a DVD player? Have you ensured that the replacement board is exactly as per the original and the voltages at connectors are in same position and rating? If there is a voltage drop in any of the pins, look further in that direction and you can catch the culprit and conclude.
Aug 13, 2012 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
Panasonic th-50px75u no power
Ensure there is proper voltage on the power outlet. Try changing the TV to a different power outlet you are sure that works. Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Dead set (no indication lights coming on when I push the power button.
Hi Gwendolyn,
First of all thank you for posting your question here at Fixya.
I'm assuming here that you're TV is a Vizio L32 HDTV.
My initial advice is to ensure that the AC source(outlet) is live. Please plug the unit to a known working outlet, if you are using a surge protector, directly plug the power cord of the TV to the outlet to confirm that the AC source is not the issue here.
If you've confirmed that the AC source is not the problem, then the fault is inside the TV and most likely the power supply. Most of the TV with a dead set symptoms that I've encountered is a power supply issue but of course needs to be confirm.
If your unit is not under warranty period (if so, avail it because the manufacturer will fix it for free, opening the rear cover will void the warranty), open the back cover, check the internal fuse of the power supply board, this is near where the AC power cord's directly connected. Check its continuity using the multimeter/ohmmeter, if you found it open, replaced it with a new same current rating that is printed on its body itself. Sometimes internal fuse fail due to voltage surge/flactuation, aging, etc, replacing with new one resolve the issue, however if the fuse blow again, this is an indication of more serious problem on the power supply board, it needs to replaced the entire board.
If the fuse is intact, you have to measure the output voltage of it through connector J1 (pin 9,10,11). You should be getting 5 Volts. If there's no voltage at these pin, you're power supply board is dead, replaced the entire board. If the 5 volts is present, replaced the main board.
I've provided you a links for the power supply board and mainboard below.
Vizio L32 Power supply board
Vizio L32 Mainboard
Let me know if you need further assistance.
Rating and feedback are highly appreciated!
Hope I helped you.
Good luck and take care!
Have a nice day!
Kind Regards,
Jdvillanueva
Dec 13, 2011 | Vizio L32 32 in. LCD HDTV
When I went to turn on my 20 month old 46in LCD LN46A500 it made the loudest high pitch screeching sound that no one would like to hear and the picture was black. The remote buttons and the TV control...
The power supply board have fail badly,all that high pitch screeching sound,it came from those high voltages gaps from those tranformers,that giving ur tv high voltages.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Samsung LN46A500 46 in. TV
Tv won't turn on
I assume you do not have any red light showing on the front of the TV to indicate it is receiving power? Again assuming the your mains electric supply is functioning & the fuse in the TV plug is ok, if there are no signs of life & then most likely a fuse in the power supply may have blown. If you have a multimeter you could remove the rear of the TV & check the fuses in the power supply, if these are ok then you will need to check any supply voltages coming from the power board. If one of the fuses are open circuit, check some of the doides or transistors for any short circuits. If you are not comfortable doing this, then it would be advisible to contact a repair service centre.
Jul 28, 2009 | Televison & Video
Charger in not charging the battery
You can get an A/C adapter online on various websites or Ebay for around 20-30 dollars plus shipping. That should rule out whether the problem is your adapter or the laptop.
Nov 16, 2008 | Acer Aspire 5610-4648 Notebook
Astar ltv-1701
It sounds like your power source module is defective. I suggest you try to replace it from one your might find at a second hand store. Look on the back side of the power source device. It should list the output voltage (usually DC or direct current as opposed to AC or alternating current) and also lists the current in amps that it produces. Also inspect the connector to your TV so you can try to match the connector when you buy a replacement. Armed with that information (output voltage and current ability from the power source) pick through the modules you find at a second hand store. Make sure the voltage exactly matches. You can also purchase a power module which can produce more amps of current, but never less. If you are successful in finding a match, buy it - but you may need to cut off the old connector and some of the wire that plugged into your tv so that you can reuse the connector on the used unit you just bought. You will need to splice the old wires from the tv connector to the wires coming out of the used power unit. Assuming the connector on the used unit you purchased did not match your tv connector, you will also need to cut off the connector and splice the tv connector to the wires coming out of the used power unit you just bought. If this is too complicated, go to the manufacturer and try to buy a replacement or look at other places like eBay for a matching power unit to the original TV unit.
There is a possibility your TV itself has a short and is defective, although from you comments I think it is more likely you power source unit.
Jan 23, 2018 | Astar LTV-1701 Television
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
