How do I locate the water pump on my Samsung SW68asp. I think there's something stuck in it.
    Genius:
  • 1,028 Answers
Pump on samsung is better acessed from back remove rear panel that should at least give you abetter idea
Posted on Apr 27, 2008
How can I find out if there is something stuck in the machine. Things still wet after spin.
It could be two problems. Check the hot and cold water inlet valves, it should be completely close at the final spinning cycle. Another thing is water outlet pump it should be run on the spinning cycle. Something might be stuck in the water pump.
Feb 01, 2015 | Washing Machines
Se code
You're on the right track - SE error code on a Samsung dishwasher means "drain error". If you can get to it, try removing the drain pump. Chances are there is something in it that is blocking or impeding the impeller, or may be stuck at that end of the drain hose (where the check-valve is located.) Good luck!
Aug 01, 2014 | Samsung Dishwashers
Samsung sw68asp manual
Hello & Welcome to FixYa
Please click on this link to download the manual. Please get back if you have any other questions.
Kevin
Nov 24, 2012 | Samsung Washing Machines
Samsung washing machine J1045 water over filling
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.
Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.
Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.
This solution will solve your problem
Apr 08, 2010 | Samsung Washing Machines
Once the wash is done I can hear a great deal of water still in the tub as I spin to check for stuck cloths. how can i get all the water to drain?
check to see if you have a filter you can clean if not check the water pump it may have a filter on it if all clear check hose from tub to pump to see if anything is stuck like a sock or something if this is clear check outlet hose if still no problem you may have an inefficient water pump which will need to be replaced let me know how you go
Nov 12, 2009 | Samsung WF203ANW Front Load Washer
I have frigidaire FWT449GFSI,the water can cont come out
HI, check the following to address this issue.
1. Clogged drain line or water pump Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Sep 23, 2009 | Frigidaire ATF6000ES Front Load Washer
WE have a Frigidaire top loader about 4 - 5 years old, and it went into a spin cycle with the tub full of water. any ideas? It threw water everywhere. I'm thinking stuck contacts on timer.
sounds more like you have something stuck in the drain pump or drain hose. use a shop vac and attach it to the end of the drain hose and see how easy or hard the water comes out.
if it comes out easy possible small object stuck in the pump. if the water comes out slow or none at all there is a piece of clothing or something in the drain hose that comes from the bottom of the tub to the drain pump
Sep 21, 2009 | Frigidaire Washing Machines
The water does not pump or drain out after the wash is done
you have something stuck in the pump i think.maybe a sock or something. try looking at the the pump....its clear so you should be able to see if anything is stuck in the or use a wire hanger and get up in there and pull out whatever it is thats in there
Jan 08, 2009 | Admiral 24 in. DWUA651 Built-in Dishwasher
Kenmore 90 washer won't drain
Check first drain line or water pump to see if they are clogged.
2. Water Pump
Jan 14, 2008 | Washing Machines
Washing Machines Logo
199 people viewed this question
Top Washing Machines Experts
