Question about Juki TL-98Q
I have lost the manual and i dont remember how to thread a bobbin. Pleas help me and thank you!
    Problem Solver:
  • 5 Answers
Juki TL-98Q
Loading the bobbin into the bobbin case:
Snap in the bobbin case latch, and put the bobbin into the bobbin case so that the bobbin runs clockwise.
Passing the thread through the **** of the bobbin case, continue passing it under the thread tension spring, and pull out the thread open end about 10 cm from the bobbin case.
Insert the bobbin case fully into the hook, and close the bobbin case latch.
You can obtain a copy of the manual in pdf format for free at:
http://www.juki.co.jp/household_en/pism/img/tl98q/download/98qim.pdf
Posted on Jul 29, 2010
Sewing serge it wont sew after i thread it it just keeps breaking the bottom thread I dont have the manual i lost it
change the needle--flat side to the back of the machine
check to see if
1. bobbin is inserted correctly
2. are there any burrs on the needle plate or bobbin area
3. change thread--use every thread guide
name of machine & model number is not shown
if this is a baby lock machine then go to the website & contact customer service about a manual
Mar 28, 2012 | Baby Lock Sewing Machines
Threading up a bobbin in a singer 560 sewing machine
I'm guessing it's probably the same as mine (8280). This is what the manual says: "Hold the bobbin case with one hand, insert the bobbin so that the thread runs in a clockwise direction. Pull the thread through the **** and under the finger. Hold the bobbin case by the hinged latch and insert into the shuttle." It's hard to describe, but if you've sewn before, it should come back quickly. To be more specific, hold the bobbin case in your left hand, insert the bobbin so the thread is coming up from underneath, pull thread through the **** and into the part where the hole is. If you slide the thread around, it will fit into the slot in there. Pull the latch out and insert it into the shuttle.
Hope this helps.
Mar 27, 2010 | Singer Sewing Machines
How to thread a bobbin on a my style 16 janome?
What brand of machine is it - google the brand, model
# and the word manual - if it is older you may be able
to find a free one.- Are you able to wind a bobbin and then have trouble? If that is the problem - make sure you keep your foot on your foot pedal and don't vary your speed at all - you want your bobbin wound evenly. If that is not the problem check with some of your friends who sew because most bobbins are wound the same - or go into a used sewing machine
store with the name of your machine - they should
be able to tell you how to do it or google it -how to wind a bobbin..
Feb 12, 2010 | Sewing Machines
Threading and Bobbing
http://www.brother-usa.com/manuals/default.aspx?ProductGroupID=3&WT.cg_n=Support&WT.cg_s=Manuals
Apr 07, 2009 | Brother LS-1520 Mechanical Sewing Machine
Cannot thread bobbin
If I remember correctly this machine has a little arm in the bobbin case area. You will need to open the slide plate, move that arm towards the middle of the bobbin. Thread your machine as normal, take the thread going through the needle eye and wrap it around the thumb screw a couple times, then start "sewing" your bobbin should begin filling, once started, you can release the thread wrapped around the thumbscrew. Once filled, you simply close the slide plate and that moves the arm back into place and start sewing.
Dec 23, 2008 | Brother LS-1217 Mechanical Sewing Machine
Riccar Model 15
Visit us at www.ifixmachine.com to avail for a new manual for only $10.00
Nov 16, 2008 | Sewing Machines
Thread bunching
I discovered that when the thread is knotting up on the underside of the material that it is usually the threading on top and has nothing to do with the bobbin.
Jun 29, 2007 | Brother LS-1217 Mechanical Sewing Machine
Juki TL-98Q Logo
519 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
