A lot of programs I try to install, which I have the correct requirments for, end up with an error near the end of installation saying that "my system has not been modified"??...what is going on??
  • 975 Answers
Let see if this helps , you need to update your OPERATING SYSTEM , for example "WINDOWS XP" the update is "WINDOWS SERVICE PACK 2" .
Posted on Apr 24, 2008
First time start up error message
indicates a problem hard drive not allowing the boot up to complete
take it to a computer repair shop for a proper diagnosis
Apr 24, 2017 | Fujitsu LifeBook AH531
Tip
When in windows and a program doesn't install or run correctly (if at all)
Whenever you have issues running or installing software always either try right clicking the program and click "Run as administrator".
You can also try right clicking the program, click properties, then go to the Compatibility tab. Somewhere near the bottom of the window will be a check-box for "Run this program as an administrator".
In this situation if it still isn't acting right, click the check-box also for "Run this program in compatibility mode for:" and select another version of windows.
on Mar 11, 2015 | Microsoft Windows
When trying to install Fix-It Utilities 10, I get the error message 1935. "An error occurred during the installation of assembly" 'Microsoft VC90.CRT,type"win32" and it won't...
Sorry Martin. We don't have a lot of choices here! After re-starting your computer, check you have enough hard-drive space if in doubt, Clear all junk in memory, close all programs running, go 'off-line' (it may require you to go back on line later to Register) Then check disk is clean and unscratched, and try to install again. If it fails you will have to return to your supplier for a replacement. good luck!
Aug 02, 2011 | Avanquest Fix-It Utilities 10...
Error "msi_check: 0x80280002" ,
Error "msi_check: 0x80280002 i tried installing windows live messenger
Feb 17, 2011 | Microsoft Windows Live Messanger
I can install ms office enterprise 2010.... when i try to install it says "setup cannot find the required setup controller file.Either there was a network error, an error reading from CD,DVD, other...
the same problem i faced with my one claint. the problem diagnosed is problem with "RAM". its looks funny. But the fact is true. the Ram is not flushing the memory correctly. just try replacing the RAM. best of luck.
Jan 28, 2011 | Microsoft Office 2010 Home and Business...
When I go to install this program it says No Product Selected
Insert CD. When the Windows prompt that asks if you want to install or view the contents of the CD, choose the latter. Find and click on a folder named "setup." Now click "autorun." Near the very bottom of the folder will be another setup executable. Click this one. The program will install just fine!
Jun 24, 2009 | Broderbund 3D Home Architect Deluxe 5.0...
Error 1920 installing Mcafee 8.5
Good morning! If you receive a "1920" error regarding failure to start a McAfee Service when trying to update or install Mcafee VirusScan, follow the instructions below.
WARNING: This procedure involves editing the Windows Registry. Using Registry Editor incorrectly can cause serious, system-wide problems that may require you to re-install Windows to correct them. Use this tool at your own risk.
Solution
  1. Uninstall McAfee VirusScan Enterprise using the "Add/Remove Programs" option in the Control Panel.
  2. If present, delete c:\Program Files\Network Associates and c:\Program Files\Common Files\Network Associates
  3. Go to the Start menu, select Run, and type regedit .
  4. Find and delete the registry key HKEY_LOCAL_MACHINE\SOFTWARE\Network Associates.
  5. Restart the computer.
  6. Install McAfee VirusScan Enterprise and update the software.
Best regards
May 07, 2009 | Computers & Internet
I am attempting to install Publisher Pro 2.0, Vista operating system, I get to the end of the fourth cd, I get the following error message: Error 1935.An error occurred during the installation of assembly...
http://support.quickbooks.intuit.com/support/pages/knowledgebasearticle/a5fe2972
You might need some additional program. Click the link above(or copy & paste). Might need .NET Framework 1.1 or it might just be some bugs in Vista that is not compatible with the program your trying to install. Vista still has some problems.
Feb 18, 2008 | Computers & Internet
43 people viewed this question
jasbo
jasbo
