The water wont go out of washer. - Washing Machines
    Champion:
  • 207 Answers
  1. Turn of the machine and unplug it.
  2. Check if the filter is clogged.
  3. Check if the pump turbine is clogged.
  4. Check if the drain hose is close.
Unless the pump is dead it's most likely that one of those 3 are clogged.
Posted on Apr 24, 2008
Why wont the motor on a top load roper washer work after a flood
If the motor was submerged in water it's probably shot. They aren't made to function during and after exposure to water.
May 20, 2014 | Roper RAS8445KQ Top Load Washer
Washer wont fill
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
dhjd
May 20, 2010 | GE WBSE2090A Top Load Washer
G.e. washer wont **** out rhe water
I did all the tips to check the pump. Took washer a part and no luck. I was ready to haul it to the dump. As a last resort I put drain cleaner (dollar tree brand) in the tub and ran the washer on hot. After the cycle I lowered the hose inot a bucket and turned the washer on Drain. I heard a pop and the pump was free. Works like a champ now.
Mar 13, 2010 | GE WBSR3140DW Top Load Washer
Washer filles with water but wont change cycles
start filling the washer on the warm cycle,turn washer off,if the water keeps filling then you have a bad water inlet valve,if it turns off then you have a loose water level hose or the water level switch is bad-mike
Jul 21, 2009 | Kenmore 22422 Top Load Washer
Washer wont allow cold water
Mixing valve should lock out the hot water when on the cold water setting. Either your hoses are crossed, or the mixing valve is flipped. To see if one of these is true, try it on a hot water setting to see if cold water comes in, or try just swapping the water hoses.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
Water wont fill washer. The water currently in
The pump is probably clogged with a coin. Pull off the hoses and check the pump. Make sure you put a pan under the hoses to catch the water
Jun 27, 2009 | Frigidaire Washing Machines
GE Profile Washing Machine wont fill with water top loader
disconnect water lines from washer and check to see if sedement from water plugged up little screen filters
Jun 11, 2009 | GE Profile WPRE6100G Top Load Washer
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Water just drains, wont fill up washer
the top of the hose must be higher than the water level in the washer for proper operation
or
the drain house should be loose yet fit securely. do not seal the drain hose with tape the hoese needs and air gap
Apr 17, 2009 | Washing Machines
My washer wont spin out
kinked hose or blockage in the water pump you defininatley have material in the water pump
disconnect washer all together pull out after you drain the water by hand as far as can go use a dolly take out side drain the rest by tipping on side you might need 2 or 3 people to get the washer out with little water left when on side pull the water pump off look inside and pull material out with a pair of needle nose pliars that clamp you will need 2 people to pull out material one to hold the pump and one to pull material out with pliars
once done before you put back together do a lube on your washer with appliance oil this will insure good maintenance
what i decribed at top is the non costly way to fix your own washer if there is material stuck in water pump
Jun 13, 2008 | Maytag Washing Machines
Washing Machines Logo
Top Washing Machines Experts
